Author Topic: I think that I killed my home built computer...please help.  (Read 5861 times)
Offline vivalarevolución
So I dove into my computer to remove the M.2 SSD from the bottom of the motherboard, and when I put everything back together and fired it up, nothing shows up on the monitor.  I'm wondering if I had some static in my hands, or if the parts still had some energy in them and got zapped when they contacted the metal case.  I wasn't exactly being extra careful in this situation.
  It's not a problem with the monitor because it works with other devices.  The power adapter, fans, and case buttons still work.   The motherboard still beeped when I removed the RAM.  So I'm basically not sure what I killed or what I need to replace.
 I would like to troubleshoot this before giving up and starting anew.  Ideally, I can identify the bad part and just replace that one part.  Any ideas, Geekhack?
Offline Skysophrenic
Re: I think that I killed my home built computer...please help.
« Reply #1 on: Mon, 09 May 2016, 12:52:24 »
Do the bios show up?
« Reply #2 on: Mon, 09 May 2016, 13:02:41 »
No, nothing shows up on the screen.  I'm assuming that the problem is either the motherboard, RAM, or Cpu if nothing shows up.  I've also read that the power supply go bad, but still seem like it is working
Another caveat: While I did unplug the power supply from the outlet, I did not unplug the power supply from the components when I removed the SSD. I know realize that was not too bright.
  • Live long and prosper
« Reply #3 on: Mon, 09 May 2016, 13:03:46 »
remove all but the vital components required to post
if post, add back devices until it no longer posts
if no post, it's one of the remaining devices (CPU, RAM, GPU, mobo)
tp thread is tp thread
« Reply #4 on: Mon, 09 May 2016, 13:43:55 »
It's a no post with the vital components.
Offline sek1ne
  • Sek-eye-n
« Reply #5 on: Mon, 09 May 2016, 13:49:23 »
Any noises at all? beep codes?
Biking is fun.
« Reply #6 on: Mon, 09 May 2016, 14:01:24 »
I got beeps when I removed the RAM.  I haven't tried turning it on with the CPU removed to check for beeps.
« Last Edit: Mon, 09 May 2016, 14:40:01 by vivalarevolución »
« Reply #7 on: Mon, 09 May 2016, 14:30:16 »
There are beep codes relative to POST, and they tell a particular story. Getting one or more beeps is already encouraging.
I would assume that something is not plugged in properly before I would assume that something suddenly died.
In the past I had motherboards that refused to POST without something silly like a fan plugged in.
- D Trump 2026-10-24
« Reply #9 on: Mon, 09 May 2016, 14:46:00 »
clear cmos
There is a cmos reset button, which I pressed.  I read to remove the cmos battery, but I figure with the reset button, that would not be necessary.
« Reply #10 on: Mon, 09 May 2016, 15:08:08 »
clear cmos
you need to remove battery, remove power cable, close power supply button,
AND HOLD the cmos reset button for 10 seconds.
« Reply #11 on: Mon, 09 May 2016, 15:28:48 »
clear cmos
Well, I'll have to find the cmos battery first...
« Reply #12 on: Mon, 09 May 2016, 20:54:16 »
I unattached something that seemed like the cmos battery, because it was the only battery looking thing that seemed to be on the motherboard.  It didn't work.
The motherboard actually seems to be okay because it beeps, powers a USB drive, and didn't work when I removed the processor, but did work when I put the processor back in.  I actually don't know if that means anything or if I damaged anything by doing that.
I'm thinking it might be the RAM.  The motherboard beeped at me off and on when only one of the RAM sticks is in, and then didn't beep when only the other RAM stick was in.  I might buy some new RAM and see if that does the trick.  If it doesn't, then I don't know.
Offline nugglets
« Reply #13 on: Mon, 09 May 2016, 21:08:06 »
Do you have on-board VGA? If so, remove the GPU and try using that to see if you get a video signal.
Try different RAM slots using only one stick. Alternate sticks if it doesn't work. Make sure they click in all the way on both sides.
« Reply #14 on: Tue, 10 May 2016, 07:07:21 »
I have a processor with integrated graphics and do not have a GPU.  I don't really need one for my computing habits.  it's a pretty basic setup.
I did the RAM stick shuffle, trying out each card in each slot, one at a time.  Sometimes it beeped with one stick in, sometimes it didn't.  Then I made sure that the sticks clicked all the way in and the beeping seemed to stop.  I put both in, made sure they clicked in firmly, but nothing still appears on the monitor.
Considering the earlier beeping with the RAM, I bought some new RAM.  Should be here by the end of the week.  If that doesn't work, I guess the problem is either the motherboard, processor, or power supply, but those don't seem like the problem, from what I can decipher with my amateur knowledge.
« Reply #15 on: Tue, 10 May 2016, 07:16:50 »
On another note, the universe appears to be conducting it's elaborate balancing act, because I found a working laptop in a dumpster that I can use in the meantime (I live near a university and went dumpster diving for items thrown out by students).  The Windows install seems corrupted, but it works with my USB sticks and SSDs that have Linux on installed on them.
Offline henz
  • What?
« Reply #16 on: Tue, 10 May 2016, 07:30:18 »
did you have the right source selected on the monitor? :)
usually if the computer starts yet nothing happens, it should make some kind of sound if something is broken,
if you suspect the graphics card is busted you can try plugging the monitor into the motherboards monitor port.
It can also be so that PSU is not providing enough power to make the computer function yet enough to run the fans.
« Reply #17 on: Tue, 10 May 2016, 07:36:19 »
Extraordinary luck finding a laptop!
When you describe "nothing" showing on the monitor, it does come on with a splash screen, probably with the name of the manufacturer, when it is first powered on? It would be a shame to tear up a computer because the monitor failed.
« Reply #18 on: Tue, 10 May 2016, 08:01:45 »
No splash screen, absolutely nothing.
The monitor is plugged into the motherboard. It works with other devices and also seems to scan all the inputs and automatically shows a connected device.  I also don't have a GPU, just integrated graphics in the processor.
I have considered that the PSU is failing.  Best Buy has a decent one on sale for less than $40 that will meet my needs.  My current PSU is overkill, anyways.  it has more power and connections than I will ever need.
Offline SBJ
  • Tactile pls
« Reply #19 on: Tue, 10 May 2016, 08:11:23 »
What type of beeps?
In the manual for your motherboard there are descriptions of what the different type of beep codes mean.
« Reply #20 on: Tue, 10 May 2016, 08:27:18 »
Longish, slow, repeated beeps.  They only occurred when I removed one or both of the RAM sticks.
The manual does not contain information on beep codes.  But I have read those types of beeps are related to RAM issues.
« Last Edit: Tue, 10 May 2016, 08:32:52 by vivalarevolución »
« Reply #21 on: Tue, 10 May 2016, 19:39:08 »
So the PSU is not the problem.  It either comes down to the RAM or the motherboard.  We'll see...
On another note, I have a used 500W EVGA PSU that still works, if anybody wants it...
Offline nugglets
« Reply #22 on: Tue, 10 May 2016, 19:42:27 »
To have two RAM sticks die at the same time would be extraordinarily unlucky. More than likely, if that's the case, your memory controller is bad. What CPU do you have? Sandy-Bridge/Ivy-Bridge and later have the memory controller integrated into the CPU while previously they were part of the "northbridge" chipset on the motherboard.
« Reply #23 on: Tue, 10 May 2016, 21:50:55 »
I have a Skylake build.  I just put this together late last year and decided to go with the newest generation of items, because why not.
Offline nugglets
« Reply #24 on: Wed, 11 May 2016, 17:33:28 »
You have any small, non-chain PC repair places in the area? They are usually pretty good about not charging or only charging very small amounts to swap a couple components real quick to test things like this.
Assuming, of course, you don't have another LGA1151 CPU laying around. And most retailers will only accept opened CPU's for exchange, no refunds, so I wouldn't want you to go out and buy one only to find out there is something else at play.
« Reply #25 on: Wed, 11 May 2016, 18:17:49 »
Yea, there are more than a few.  I can look into those.
« Reply #26 on: Sat, 14 May 2016, 16:55:33 »
Thanks to the help of a friend, we determined that the motherboard is dead.  Joy.  Not sure if I should buy a new motherboard or just get the a Mini PC that my heart has been lusting after for months.  I don't think that I actually need things like a super awesome processor or slot for a discrete graphics card.  I think that I can get by with a stock build.
Offline HPE1000
  • Keycap Paparazzo
« Reply #27 on: Sat, 14 May 2016, 17:21:09 »
what brand/model was the motherboard by the way?
Offline Darkshado
« Reply #28 on: Sat, 14 May 2016, 18:50:11 »
Wouldn't the motherboard still be under warranty?
« Reply #29 on: Sat, 14 May 2016, 19:06:07 »
if it's a skylake build,  it should be hahahaha.
« Reply #30 on: Sat, 14 May 2016, 20:16:19 »
I buy all my gear at Micro Center and they once gave me a new motherboard replacement that was about a week shy of being a year old.
And I hadn't bought the extended warranty.
