Author Topic: VE.A in Massdrop  (Read 79872 times)
Offline Jin
VE.A in Massdrop
« on: Mon, 16 May 2016, 16:58:54 »
Korean ergonomic keyboard VE.A
•Base kit : $399
-Anodized aluminum
-Polycarbonate
-VE.A Type T pcb T-II
-75% layout
-SATA cable connection
-Compatible Cherry MX switches
-1.5mm SUS(stainless steel) plate
-RGB led (18piece)
-Switch  led
-Include bolts + nuts , SATA cable + Mini USB cable
•Housing color option
-Black
-Dark grey
-Silver
•Additional options
-Change to Black plate  (+10.00 $)
-Switches = Gateron(+22.00 $) / CherryMX(+42.00 $) / Zealios (+72.00 $)
-Keycap = Non-printed or laser printed Grey keycap , Cherry profile PBT (+20.00 $)
-Keycap = Non-printed or laser printed White keycap , Cherry profile PBT (+20.00 $)
-VE.A stand = Acrylic stand (+45.00 $)
•Additional Parts for VE.A - PCB (+55.00 $) / Plate (+25.00 $) / Black plate (+35.00 $) / Titianium Coated black plate  (+35.00 $)
•Shipping:
Shipping is $8.75 to US
Estimated ship date is Aug 8, 2016
•Where to buy
https://www.massdrop.com/buy/ve-a
« Last Edit: Mon, 16 May 2016, 17:06:46 by Jin »
Offline kiwi99
  • that's a gnarly dookie
Re: VE.A in Massdrop
« Reply #1 on: Mon, 16 May 2016, 17:03:31 »
Damn, cool to see a korean custom on massdrop.. but I can already envision  the massdrop "overpriced" comments by the dozen
Offline Jin
« Reply #2 on: Mon, 16 May 2016, 17:04:44 »
Yeah its pretty nice keyboard , many korean user want this keyboard sold on korea
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #3 on: Mon, 16 May 2016, 17:12:09 »
That acrylic stand is so pretty
Offline Jin
« Reply #4 on: Mon, 16 May 2016, 17:13:55 »
Yeah  its pretty and comfortable for VE.A
Offline trenzafeeds
  • **** off
« Reply #5 on: Mon, 16 May 2016, 17:22:41 »
Disappointed about the lack of color options  :(
demik will never leave.
Unless he gets banned.
Offline Jin
« Reply #6 on: Mon, 16 May 2016, 17:25:37 »
Yeah , need re-anodized
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #7 on: Mon, 16 May 2016, 17:26:10 »
What colors were available in the first run?
Offline trenzafeeds
  • **** off
« Reply #8 on: Mon, 16 May 2016, 17:27:25 »
I know henz and yuktsi have really nice green ones, not sure if any other colors were made.
Offline Jin
« Reply #9 on: Mon, 16 May 2016, 17:31:14 »
i saw a gold one is kbdlab  :thumb:
Offline kiwi99
« Reply #10 on: Mon, 16 May 2016, 17:32:15 »
http://kbdlab.co.kr/index.php?document_srl=3152205&mid=board_Lsno50
olive green, gold, red, (pink?)
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #11 on: Mon, 16 May 2016, 17:35:02 »
That pink with Miami would look amazing!
Offline Jin
« Reply #12 on: Mon, 16 May 2016, 17:37:42 »
yup you got a picture  :thumb:
Offline Jin
« Reply #13 on: Mon, 16 May 2016, 17:38:12 »
if we can re anodize will be better choice  :thumb:
Offline Niomosy
« Reply #14 on: Mon, 16 May 2016, 17:39:41 »
Looks great.  Wish I could afford it :(
Offline Jin
« Reply #15 on: Mon, 16 May 2016, 17:41:10 »
Will be good , its pretty nice keyboard
« Reply #16 on: Tue, 17 May 2016, 02:49:51 »
Guys, if you get this.
Don't waste your money on that stand..
Tenting requires a MUCH HIGHER stand, and across multiple axis for best fit and comfort.
This seems to only tent left-right but not up-down..
I had tried using my ergodox with only left right tenting, it did not fit my wrist well.
ONTOP of which, you need significantly more tenting then that picture.. something along the lines of 100mm in the middle..
« Reply #17 on: Tue, 17 May 2016, 02:52:15 »
IMHO,  this design compromises  Ergonomics to preserve keycap compatibility..
If you're gonna go this far and get a $400 ERGONOMIC keyboard,   but it isn't designed all the way for ergonomics.. What was the point ..
The right hand side would work fine, because you can get your hands around it.
But notice the left hand side 1x qwerty-keys are staggered away from direction which fingers naturally curl..  (here we see the compromise, to preserve cap compatibility)
« Reply #18 on: Tue, 17 May 2016, 02:55:38 »
For $400, I'd expect machined acrylic,  not laser cut acrylic..   and if it is laser cut,  I'd expect better cut than what's in the picture..
Those vertical lines show up because they're prioritizing cut speed over cut quality..  This is a highly tweak intensive process.. because different acrylics even within a single batch may require different cut speeds / cut temperatures for smooth edges..
The original ergodox does not have very good edges either, but for $200, I let it go..
Not @ $400
Offline trenzafeeds
  • **** off
« Reply #19 on: Tue, 17 May 2016, 12:11:27 »
triple posting aside, tp4 makes some good points. looking at the massdrop version, I'm not seeing a $400 keyboard. The korean version looked much higher quality.
Offline WNovizar
« Reply #20 on: Tue, 17 May 2016, 12:22:18 »
As far as I can see, there is no difference between R1 and massdrop version except for color options.
I like mechanical keyboards
Offline trenzafeeds
  • **** off
« Reply #21 on: Tue, 17 May 2016, 12:24:35 »
well there's the color options, and korean groupbuy also came with the option of having a metal tag with custom text on the back. also, could be my imagination, but I'm pretty sure the koreans had machined acrylic. It's little things, but it adds up when we're talking about this price point.
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #22 on: Tue, 17 May 2016, 12:24:52 »
And this one might fix the left spacebar issue
Offline Waateva
« Reply #23 on: Tue, 17 May 2016, 12:40:29 »
Zefyr has stated in regards to the Massdrop groupbuy...
Most of all, there is no acrylic laser cut part in VE.A. (Why somebody thinks there's one? I have no idea.)
Offline Niomosy
« Reply #24 on: Tue, 17 May 2016, 13:47:31 »
Personally, I'm fine with preserving cap compatibility.  I also like that it's preserving the ANSI layout.  I realize I'm a misfit here but I make use of all of those keys on the right side that get displaced with symmetric matrix layout boards.  In all honesty, all I want is a mech switch MS Ergo board.  This board would be fantastic for me so long as I can tent right-to-left.
Offline Data
« Reply #25 on: Fri, 20 May 2016, 09:40:38 »
It's machined polycarb.  Superior to acrylic.
