Author Topic: How many words per minute can you type?  (Read 15619 times)
Offline QuincyJones
« on: Wed, 18 May 2016, 19:39:12 »
http://typing-speed-test.aoeu.eu/
I get between 81-87 words per minute. You?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline FrostyToast
  • Litshoard
Re: How many words per minute can you type?
« Reply #1 on: Wed, 18 May 2016, 19:43:25 »
There have been tons of threads on typing speed but for this particular site I get 91wpm.
Quote from: elton5354
« Reply #2 on: Wed, 18 May 2016, 20:04:12 »
Welcome to Geekhack...
Where,
135wpm is Only the Beginning...
Check out my typing speed guide in my signature..
Offline FrostyToast
  • Litshoard
« Reply #3 on: Wed, 18 May 2016, 20:09:33 »
Where,
I'm surprised your typing guide doesn't just say "Ergodox" in all caps 48 size font.
Offline phoible
« Reply #4 on: Wed, 18 May 2016, 20:22:22 »
I still type a bit slower on my Ergodox because I'm getting used to it (only 63 on this test, which doesn't seem to be all that realistic).
Hopefully ortholinear will be faster in the long run.
Offline zcmy
  • I really should be working... not "working"
« Reply #5 on: Wed, 18 May 2016, 21:18:22 »
77WPM without touch typing. I have really bad typing habits using keyboards that probably need to get fixed.
Offline khirin
  • Do more, with less.
« Reply #6 on: Wed, 18 May 2016, 21:33:36 »
I got 91 wpm in this test, on the first try (5 mistakes).
Offline NewbieOneKenobi
« Reply #7 on: Wed, 18 May 2016, 21:42:26 »
Up to 100 wpm in tests that really go for the speed, if I go for the speed too and avoid making mistakes or getting stuck. Probably less with real punctuation and everything else. But what those tests measure is copying rate more than typing rate, and that's something a bit different. My lazy-typing rate is much slower, and my burst rates when chasing a deadline may well be faster. I would probably be 10-20% faster with a lighter switch; I find all of Buckling Spring, MX blue, MX black and Topre to be too heavy for me. Beam Spring isn't and browns aren't, but my accuracy suffers as I can't keep up with the speed then. And I'm faster on rubber domes than mech units, apparently.
Offline SBJ
  • Tactile pls
« Reply #8 on: Wed, 18 May 2016, 22:47:45 »
I got around this as well, I don't remember how many mistakes I made.
I'm still getting used to ANSI so I made a couple of mistakes, willl try again when I've got some more typing on this board.
Offline chryos1029
  • Don't stop me from buying keyboard!!
« Reply #9 on: Wed, 18 May 2016, 23:14:54 »
Around 120wpm on this site :)
\IBM Model M\Ducky Legend\IBM Model M SSK\FILCO MJ2
« Reply #10 on: Thu, 19 May 2016, 00:55:09 »
Meh, probably 160 on a good day and not at 2 am.
« Reply #11 on: Thu, 19 May 2016, 01:00:38 »
it's no linkbane, but it's impressive.
« Reply #12 on: Thu, 19 May 2016, 01:01:50 »
gonna go kill myself now
« Reply #13 on: Thu, 19 May 2016, 01:08:22 »
leave me all your stuff pls
Offline atarione
« Reply #14 on: Thu, 19 May 2016, 01:21:34 »
37 glorious words per minute... yes I am rubbish at typing it is true..
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #15 on: Thu, 19 May 2016, 02:11:15 »
demik back in the MX game confirmed.
« Reply #16 on: Thu, 19 May 2016, 02:22:46 »
ಠ_ಠ
Something responsible has to burn all this mx garbage.
Sifo is my Canadian brother, thus I need to be in charge.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #17 on: Thu, 19 May 2016, 03:43:09 »
I peak at 115~120 but am no trained typist.
« Reply #18 on: Thu, 19 May 2016, 03:46:51 »
Is it sheer practice or strong fingers or how do you actually do that? I've seen 220 wpm (a veteran secretary, court reporter or whoever it was in a Model M typing contest on YouTube), but I still can't wrap my mind around it. I guess I was meaning to ask how does one even get there?
Offline SKD
« Reply #19 on: Thu, 19 May 2016, 07:18:13 »
Around high 60s to low 70s on 10fastfingers basic typing, personal best was 84wpm. Around high 60s on the advanced tests and personal best at advanced is 71.
High 50s on typeracer, but they have completely random quotes which include punctuation which I'm not so great at still.
Offline dgneo
  • Supervillain
« Reply #20 on: Thu, 19 May 2016, 07:22:43 »
100-110 on average, but I can only get that on my HHKB. I've tried with my 55g 87u, my old 60%, and my FC660m, and usually top out around 80 or so.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #21 on: Thu, 19 May 2016, 14:51:24 »
Yea I've seen a few of these threads too /shrug 75-80 these days. My speed might increase with a mechanical I have no idea; I was hunting and pecking back when I used buckling spring keyboards.
« Reply #22 on: Thu, 19 May 2016, 15:06:17 »
Back when diablo 2 was serious business and VoIP wasn't as popular if you couldn't type fast you'd die. My mentality was that I'd type fast if I wanted to live in game, which is much more important than being alive irl so naturally 100 wpm became a breeze. In 2012 or so I got serious about actually trying to improve so I slowly went from like mid 120 to 130 to 140 to 145 to 150 etc until I peaked at 176 a few months ago... it's a pretty slow progress but I distinctly remember when I never thought I'd be doing 160 and now it ain't too hard.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #23 on: Thu, 19 May 2016, 15:08:04 »
70, although the board I'm typing on right now is not my fastest.
« Reply #24 on: Thu, 19 May 2016, 15:26:55 »
I managed to beat 170 WPM last semester, but I've lapsed down to about 120 due to lack of practice/need to type.
« Reply #25 on: Thu, 19 May 2016, 15:27:26 »
Tp4 calls dibs on Sifo's girlfriend's phone number..
Sifo won't need it where he's going..
« Reply #26 on: Thu, 19 May 2016, 15:29:34 »
don't have one right now sorry
Offline xondat
  • i'm not a star
« Reply #27 on: Thu, 19 May 2016, 15:42:07 »
High score is 86 but want to reach the 100 mark soon. :'(
Offline RobotMalcolmX
  • hackerman
« Reply #28 on: Thu, 19 May 2016, 15:47:59 »
I seem to average between 95-105 with different sites. I'll take this one gladly.
Offline need
« Reply #29 on: Thu, 19 May 2016, 16:08:35 »
That's a massive jump, you simply won't make it.
Offline xondat
  • i'm not a star
« Reply #30 on: Thu, 19 May 2016, 16:14:25 »
I've not had a good keyboard for a couple of months so absolutely love typing on my Realforce at the minute, just want to keep typing extended sentences for the sake of typing.
Offline Erzegovaz
« Reply #31 on: Thu, 19 May 2016, 16:24:19 »
cant change the language? In italian i do around 110-115 wpm, in english just 60-70 or something like that. I need training :D
« Reply #32 on: Thu, 19 May 2016, 16:27:29 »
What's the difference that makes the HHKB so much faster? Does the reduced form factor somehow do it in connection with something else I can't think about?
Wow. I've been typing and playing games all my life (well, at least since age 7 or 8, and I'm 33 now), including multiplayer RTS-es with a lot of typing, and somehow I've never been able to catch up even with those people who reliably exceed 500 chars per minute. Perhaps it's something of an individual feature? I know a guy who was in the same clan with the national team in Warcraft II and later had stellar results in Starcraft 2 and coded in free time (which obviously means 'when not gaming') and went on to become a professional coder. He had some really high APM, but I still don't think he can type faster than 120 wpm. On the other hand, in a roleplaying forum we had that teenage guy from Australia who hammered in excess of 900 CPM on a laptop board.
I'm pretty sure I must have reached 120 WPM burst on my best days when not paying attention to the speed, just racing against late deliveries, or 'flow', but 90-100 wpm in those tests has been my limit for at least ten years, and falling rather than rising, despite the nature of my work and my interests (which is a polite euphemism for typing 16/24). I've thought about getting some real training.
I think I get slightly better results in English than my native Polish, which may be because we use right-alt characters all the time. At least I don't have to remember 20 alt codes like back in the nineties.
« Last Edit: Thu, 19 May 2016, 16:30:20 by NewbieOneKenobi »
« Reply #33 on: Thu, 19 May 2016, 17:31:57 »
type faster on rubber dome than topre
if you were to spend the time to get used to it, blacks are probably the best mx switches for raw speed but for me they're not enjoyable to type on.
scissor switches are probably the fastest overall because you're hardly pressing anything
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #34 on: Thu, 19 May 2016, 19:03:32 »
I type at the speed of imagination.
Offline zcmy
« Reply #35 on: Thu, 19 May 2016, 19:22:15 »
Although iirc, those have the highest actuation force out of all the cherry switches, besides super blacks, right?
« Reply #36 on: Thu, 19 May 2016, 19:35:54 »
tp4 wrote a post about why blacks are theoretically the fastest cherry mx switches to type on
Offline jcoffin1981
« Reply #37 on: Fri, 20 May 2016, 02:52:57 »
I type about 60 to 65 words/min on most mechanical keyboards.  If I'm using the Logitech Illuminated Keyboard this goes up to 75 to 80 wpm.  Nothing to write home about, but I think the difference is there is no spaces between the keys and there is a shorter keystroke.  When I type fast I sometimes hit the edges of the keys and the logitech compensates for this.  However I've since retired the Logitech and don't use it anymore.
Offline need
« Reply #38 on: Fri, 20 May 2016, 05:13:13 »
I think I usually type at 520 wph.
Offline raymogi
« Reply #39 on: Fri, 20 May 2016, 05:14:40 »
Before joining GH (as a normal person with keyboard), I typed at 60wpm.
Today, after spending almost a year on GH, 110wpm.
Please feed my addiction.
Offline dgneo
  • Supervillain
« Reply #40 on: Fri, 20 May 2016, 05:19:47 »
Personally I feel it's a solid combination of the switches and the amount of time I use it. I find that I can type really fast and smoothly on my HHKB due to the switches being somewhat lighter for me, as I'm a pretty heavy typer, and I've had the board for almost a year now, using it 40+ hours a week.
Just feels right to me  :thumb:
Offline ander
  • I type, therefore I am
« Reply #41 on: Fri, 20 May 2016, 07:38:24 »
I think that to answer this question with any meaning, first you have to ask yourself why you want to type fast.
Is it to impress other people—e.g. to get dates with office babes who find typing prowess a turn-on, or to win valuable prizes in typing competitions (given that humans like to pit themselves against each other in all manner of odd things)?
Is it to get your work done as fast as possible so you can get the #*@! out of the #)@*! office and try to have a life?
Is it a desperate attempt to justify your existence by knowing you can do something as random as typing on a keyboard faster than someone else?
Is it because you've had too much coffee again because you have to do so many mind-numbingly mundane things just to keep a roof over your head and food in the fridge that you don't want to think about how much of your God-given talent you're leaving on the dung heap?
Is it because you just have to type fast because if you don't you'll go crazy and run around the room and go bouncing off the furniture like a pinball?
I'm trying to think of other reasons why it might be important to type fast. Only then do I think we can move on to attaching any significance to any particular typing speeds. Anybody else, feel free to chime in on this. Certainly there are a few of you out there who realize that typing speed, in itself, means nothing when it's not related to motive and/or content. After all, people on the up-curve of manic-depressiveness can talk impressively fast—but what are they saying? Does anyone take that into account?
Offline ander
« Reply #42 on: Fri, 20 May 2016, 07:41:20 »
It also seems to me that participating in a mechanical-keyboard forum so you can talk about how fast you type is rather like joining a book club so you can talk about how fast you can read. That's just my opinion, of course.
Offline zcmy
« Reply #43 on: Fri, 20 May 2016, 07:48:22 »
For me, it's not much more than. "I need to type quickly as a part of my job." When you have to write down almost every word that's said, and mistakes are not tolerated, you can't really be making mistakes or typing slow. I type much faster on the keyboard I use for work than the keyboard I use at home.  I can't "just do shorthand" since the notes need to be available for viewing within 5 minutes on the company server. So when it's a matter of losing your job, it gets taken seriously.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #44 on: Fri, 20 May 2016, 08:03:14 »
One of these days I'm going to sign up for classes again. Typing does keep me from bouncing off/on the furniture though :D
« Reply #45 on: Fri, 20 May 2016, 08:15:41 »
That seems possible in the light of my limited hands-on experience with the blacks in my sig, which has been my best buddy's keyboard for a couple of years now. It was a bit hard to avoid making mistakes on it, but otherwise it was pretty good for a piano-like technique (as opposed to the pecking technique). In other words, it was good for beginning to press another key before you got your other finger off of the previous key. This requires some resistance in the switch, and tacticility isn't ideal for it. Like I said, hampered accuracy was the downside.
I'm inclined to agree, though only up to a point. I've had rather extensive experience with the Natec Medusa, a very good, very solid, very well-designed, wonderfully affordable high-end scissors board for the equivalent of, like, twelve bucks. I've bought three so far, or four maybe, possibly recommended more. Caution: Medusa 1 may have been better than Medusa 2, and I've seen a guy claim the sound was better on 1, so there might be switch and/or case differences.
So, with Medusa 1, it was almost like typing on the desk itself — 9 mm height, low-profile keys… which was precisely the problem with it, eventually. CTS/RSI made me go back to the previous tall-key Logitech rubber dome (E110, IIRC), which I had previously replaced with the Medusa also because of hand pain. Later, I bought a Hama 570-something, which was a bit more expensive and a bit more bouncy — the switch was practically a typing accelarator. However, it was just that little bit too bouncy, and the architecture of the board (no wonder given <$20 price range) was not good enough for extremely fast typing — keycaps would fly off occassionally, because of the corners of neighbouring keycaps getting in the may of my fingers while releasing previously depressed keys.
And that was when my mech adventure started — still, won't ever say a bad word about scissors. It's a hybrid switch all right, and the scissor IMHO does fulfil the principal criteria to refer to it as a very basic mech switch (metal is not necessary), whereas the remaining presence of the rubber dome prevents it from being a mech board, of course, but doesn't somehow fail to make it a hybrid switch on the same grounds as IBM's old switches are, or even Topre; it only is, obviously, so much more basic. But the basicness and the low price and the low-key (no pun intended) marketing shouldn't distract our attention away from the fact that scissors are, in fact, a hybrid switch. It's a very affordable hybrid solution that's got an extremely good bang-for-the-buck ratio. And with the right scissor board you're probably typing faster and giving your hands a break.
Jokes being jokes, I kinda know a bit about that. ;) I'm a translator, which is different from a normal writer, as it's text in, text out. I always have an original ('source') that has to be converted into a different language, unlike typing from dictation or writing your own stuff.
Different translators have different techniques, but I, for example, often end up going back mid-sentence when I realize syntactical or grammatical differences between the languages are, after all, going to force me to change the structure of the sentence, or there is some better phrasing or terminology I think about on the fly, so I'm often in constant movement. In some of those situations, my typing speed (rarely below 70–75 wpm but rarely exceeding 90 and probably incapable of exceeding 110) is the bottlenecking factor, in others my thinking brain struggles to catch up with the rate my fingers want to type in (which contributes to just typing and then rewriting the sentence if necessary as opposed to stopping to think and then typing only the final outcome in). Translators rarely are slow peckers, but they also rarely exceed 300 characters per minute (~60 wpm). Hence my ability to type much faster due to a lot of non-translation writing, far less leisurely paced, gives me an edge, and I can sometimes translate the traditional norm of approximately 1500 words in one hour rather than one day. What's particularly interesting is that your fingers putting pressure on your translating brain can impose a faster translation rate and eventually teach you to translate faster, as well, comparably to simultaneous interpreting.
I could probably be a monster with Dragon Dictate, except I can't really dictate off the top of my head. I need to see the text right in front of my eyes, not in my imagination, and I'm a sucker for optimized, finalized syntax and vocabular, at least when at work. Besides, my English accent wouldn't be ideal for speech recognition, and I'm not sure fast-spoken Polish with flat articulation is going to be machine-recognizable any time soon. In fact, I'm not sure Transgaryens (Mothers and the occasional Father of Dragons) have any speed advantage on me at all. I'm pretty sure they don't feel vomit-inducing hand pain anywhere near as often as I do, though.
Drinking less also does that.  :p :)) ;)
Makes sense to me. I've been noticing the same thing with blues for me. Perhaps the previous switches were just too heavy or inconsistent or something else like that and/or just simply not enough time to get used to that one switch (especially considering the lifespan of cheap keyboards when you must have proper actuation on every key). Poor self-taught ten-finger technique can also be an impediment to higher speeds, I guess. Oh wait, I had a co-ordination impairment diagnosed as a child. That could be it. ;)
« Last Edit: Fri, 20 May 2016, 08:24:18 by NewbieOneKenobi »
Offline ander
« Reply #46 on: Fri, 20 May 2016, 09:05:11 »
Oops, this just got like the suburbs again.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #47 on: Fri, 20 May 2016, 09:22:15 »
Offline daerid
    • Rossipedia
« Reply #48 on: Fri, 20 May 2016, 09:56:41 »
~100wpm.
I used to be faster when I was a teenager, but then I got into programming, which ended up being much more thinking and banging your head against your desk than typing.
Offline wongie
« Reply #49 on: Fri, 20 May 2016, 10:28:10 »
I generally tend to get anywhere between 85 to 95 on average. Very rarely do I get anything above 100, I believe my highest ever, a few months ago, was 106. Crazy to think how some people can get 120 or more, that's like Cmdr Data-level fingery.
