Author Topic: Remember Radeon HD4870 ?  (Read 2213 times)
« on: Tue, 14 June 2016, 10:08:15 »
First Card I bought which HAD-TO-RUN at 100% fan speed to stay cool while gaming..
Otherwise CRASHHHHH
checked the sound level on my pc..  held up my phone to where the my ears are.
almost as loud as the lawn mower IMHO..
Anyone got old Loud Cards ?
139753-0
Re: Do you guys remember Radeon HD4870
« Reply #1 on: Tue, 14 June 2016, 10:14:11 »
I had one. Mfw died a day after warranty expired.
Re: Remember Radeon HD4870 ?
« Reply #2 on: Tue, 14 June 2016, 11:46:54 »
Died ?
Was it overheat death?
could probably be reflowed in the oven.. hahaha
Offline Badwrench
  • ummmm.....I forgot
« Reply #3 on: Tue, 14 June 2016, 12:51:21 »
I had a pny 660ti with the reference cooler.  It was basically just an aluminum finned block shoved under a shroud.  For some reason, this was the loudest card I have ever seen.  I wonfer if it was the neede max fan speed causing some resonance inside the cooler mixed with very turbulent airflow from all the shapes of the housing, but this thing sounded like someone stuffed a vacuum in my case.  It was loud from across the room.  Closed headset required.  I was able to find a reference evga cooler on ocn, slapped that on and the volume was more than cut un half.
Sent from my LG-H811 using Tapatalk
« Reply #4 on: Tue, 14 June 2016, 12:55:50 »
Um.. they're all like that.. hahahahaha..
The better heatsinks have a larger copper block section.. but aluminum block section is pretty much equivalent..
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #5 on: Fri, 17 June 2016, 05:30:30 »
Found a used 4870x2 and that sucker ran at around 100c at load. I had to replace it because it sounded like a helicopter haha
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
« Reply #6 on: Fri, 17 June 2016, 07:29:02 »
Yea, I don't know why they made the x2,   that's honestly dangerous.. way too much heat
