Author Topic: Mighty No 9  (Read 1402 times)
Mighty No 9
« on: Tue, 21 June 2016, 19:33:45 »
Kind of bland..  but maybe because I'm older now..
The younger Tp4 might be ok with it..
The movement seems to be about precision dashing.. but then the grab range is pretty large..
Without the height which makes up megaman maps though, this game is very -Flat- because you don't have the vertical capability..
Feels weird if you're expecting megaman.
I think this movement limitation is the largest drawback to this game..
You're essentially just dashing through 1 long tunnel...
Re: Mighty No 9
« Reply #1 on: Tue, 21 June 2016, 22:37:21 »
Look at you. Crying harder than an anime fan on prom night.
