Author Topic: Lubing and sticker questions...  (Read 1658 times)
Offline Naweo
« on: Thu, 23 June 2016, 23:23:49 »
Heya,
I have recently learned how to change and replace and modify switches.
What does switch stickers really do?
What is the best way to lube switches without making them feel heavier/sluggish, or even better, make them feel more light? Thin or thick oil?
I tried following this guide:
Though I am not sure why I would dip my spring into a high viscosity oil, it just makes it feel sluggish and heavier? Should it not be a thin oil for everything?
Maybe using thick oil for the stem ping or hole makes sense to me.
All I want is my linears to feel more smooth, but most of all I want the lightest press possible.
I already lubed 2 switches, and they feel significantly smoothier, but also 2-3 gram heavier. I kinda just want to make my switches feel smoother without the cost of feeling heavier as well, but maybe I am wrong. When I test this with switch stems ramming each other, they are almost the same.
The smoothier and softer feeling is also good as I believe it slightly reduces finger fatigue, allowing me to type faster/better and more comfortably as well, so that should be good.
So when I start experimenting  more with lubing, in case I screw up, any good way to clean the switches to start over?
And please share your experience and thoughts for linear lubing.
« Last Edit: Thu, 23 June 2016, 23:27:22 by Naweo »
Offline axtran
Re: Lubing and sticker questions...
« Reply #1 on: Fri, 24 June 2016, 08:35:03 »
I use Krytox 205 on sliders, thin DuPont Teflon Silicone Lubricant on housing hole, inside of stem, and its enough to trickle down on the spring.
Sent from my iPhone
MX Silent > MX Vintage Black > Everything Else
« Reply #2 on: Sat, 25 June 2016, 07:27:09 »
Dont' do it..  cherrk mx not meant to be lubed.. the lube just wears off, because there's no reservoir inside the switch which re-dips the nubs..
Offline lee+
« Reply #3 on: Sun, 26 June 2016, 07:09:03 »
This makes me think "get a decent keyboard to begin with" and "they should have done that in the factory".
Maybe fill the Cherry switches up with high-temperature grease from a grease gun.  That might work nicely unless the grease manages to keep the contacts from closing.
