Author Topic: Tiny Radar Chip for Gesture Recognition: Google ATAP’s Project Soli  (Read 9088 times)
Offline wolfv
The radar module is 8mm x 10mm, and that includes the antenna array.
It's more precise than any other 3D hand-gesture sensor .
https://atap.google.com/soli/
« Last Edit: Fri, 24 June 2016, 13:35:17 by wolfv »
Offline Tactile
Re: Tiny Radar Chip for Gesture Recognition: Google ATAP’s Project Soli
« Reply #2 on: Fri, 24 June 2016, 14:21:55 »
Well, it might be "more precise" but I'm not sure most folks need it. This guy isn't having any trouble with hand gestures (among other controls).
REΛLFORCE
Offline wolfv
« Reply #3 on: Fri, 24 June 2016, 14:57:31 »
The radar can see through the key caps.
Put the radar array under the key caps near the index-finger key.
That way the user doesn't have to reach for a mouse.
« Last Edit: Fri, 24 June 2016, 15:04:56 by wolfv »
« Reply #4 on: Fri, 24 June 2016, 17:02:11 »
/Interested... hrrrrrrrmmmmmmmmmmm
« Reply #5 on: Fri, 24 June 2016, 18:00:52 »
That is awesome. :eek:
Offline Bucake
« Reply #6 on: Fri, 24 June 2016, 18:15:29 »
youtube
wow.
i'm officially not allowed to call my setup a gaming setup.
and that probably goes for 99% of us
« Reply #7 on: Sat, 25 June 2016, 09:24:40 »
youtube
wow.
I've tried projectors a while back.. light pollution was the main problem.. screen wise..
But another problem is that with projection,  if everything else is dark besides the screen, this is not good, because then when you hit a bright scene it hurts your eyes,  and when it suddenly goes dark, you can't see anything..
IMHO.. In retrospect,  the Theater is only dark, because it HAS TO BE dark..
Being dark is not actually a Desired feature in terms of Visuals..  It's a throwback, similar to black text on white paper..
It was a limitation of video technology of the time..   NOT a desired trait...
