Author Topic: LEDs on the entire keyboard lost their brightness  (Read 12823 times)
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« on: Thu, 07 July 2016, 13:54:38 »
Hello, a friend of mine recently bought a Redragon Kumara K552 (I also have one) and his unit lost most of its brightness just after a few weeks:
Mine is still going strong after a month, but what may have caused that problem in the first place?
The keyboard in question uses single-color SMD LEDs (it's the first one of the kind I've seen).
Here's some internal pics as well:
P.S.
The reason why the keyboard has that much Resin on its PCB, it's due to the fact that Redragon claims the keyboard is "water-resistant". Bollocks, I say.
« Last Edit: Thu, 07 July 2016, 13:56:48 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline FoxWolf1
  • 154
Re: LEDs on the entire keyboard lost their brightness
« Reply #1 on: Thu, 07 July 2016, 14:57:56 »
Kind of a silly suggestion, but it couldn't hurt to make sure: have you checked that he didn't accidentally reduce the brightness setting or even toggle it entirely? If I'm reading the K552 manual correctly, fn + - and = are the brightness controls, and fn + scroll lock is the toggle.
Offline wetto
« Reply #2 on: Fri, 08 July 2016, 20:02:29 »
That's the first thing I told the owner as well.
Nope.jpg, the problem continues.
My collection:
Offline Data
« Reply #3 on: Sat, 09 July 2016, 11:48:31 »
Do the Fn brightness controls in fact work, even to just dim the LEDs down from their current maximum?  If any single part of the controls aren't functioning at some level then I would look at firmware first.  Assuming he can still toggle them on and off (meaning the controls still more or less work), it would either be a problem with the LED controller (chip) or power delivery to the LEDs, like maybe a bad capacitor or resistor?  Either way not easy to diagnose.
Edit: Some boards have a separate controller for the LEDs, especially for RGB.  But that doesn't appear to be the case here, or I'm not seeing it in any of your photos.  Could still be a bad cap I suppose.
« Last Edit: Sat, 09 July 2016, 11:53:25 by Data »
« Reply #4 on: Sun, 10 July 2016, 22:03:10 »
check the voltage across the led..
compare between ur working one vs the dim one.
Offline jcoffin1981
« Reply #5 on: Tue, 12 July 2016, 21:10:17 »
I'm looking at the images and it's obvious that the ambient lighting in the first image is considerably brighter, and the image is closer as well than in the second image.  It's therefore difficult to form a conclusion about the dimming of the lights.  I don't see a difference- they look the same to me.
On a side note, I found a video on Youtube that had one or two people claim that their lights appear dimmer a few weeks into ownership than when they first bought the keyboard.  I'm more inclined to believe that there is some function of the board that people are having difficulty adjusting the brightness of the LED's, rather than a defect in the design of the board.  However, this cannot entirely be ruled out.  In the images presented in the OP, the before and after kind of look the same, taking into account the differences in photo quality, distance, background lighting, etc.  All and all, this is a $40 dollar keyboard, which is unheard of in the mechanical keyboard world, with premium boards costing in excess of $250 dollars.
As an earlier poster suggested, taking a multimeter to the lights and seeing if there is a difference between the new board and the defective board.  This does still not rule out however human error in not mastering the lighting controls.
Offline Alex Meanberg
« Reply #6 on: Wed, 12 October 2016, 17:16:24 »
deleted
« Last Edit: Wed, 14 August 2019, 19:05:07 by Alex Meanberg »
Offline Lepidus
« Reply #7 on: Wed, 12 October 2016, 17:27:08 »
Sorry to hijack the original question, but I'm wondering if you could desolder the switches and replace them with Cherry switches. Has anyone tried that?
It is possible. But you need cherry RGB switches, with clear housings so the led can shine through. Regular cherry switches would still be compatible, but you would loose the backlight.
« Reply #8 on: Tue, 18 October 2016, 18:52:00 »
deleted
« Last Edit: Wed, 14 August 2019, 19:05:22 by Alex Meanberg »
