Author Topic: What's next?  (Read 2396 times)
Offline Cyypher
What's next?
« on: Mon, 11 July 2016, 11:54:31 »
I'm new here, well new to posting. But figured since I just bought my first kit, its time to take my fascination to a new level.
So here is the question. I own the keyboards below. What's next to add to my collection? I been thinking about a 75% Keycool or Noppoo Choc Mini but I'm open to suggestions. I prefer the smaller boards without TK.
1 X Realforce 87u
1 X Filco Majestouch Ninja's (104 key -  MX Black)
1 X Filco Majestouch Ninja TKL  (MX Black)
1 X Corsair K65 TKL (MX Red)
2 X MagicForce 68 Mini (Gateron Red and Clear)
1 X Pok3r RGB (pre-order from MK)
Offline Wingpad
  • The Kumquat Kid
Re: What's next?
« Reply #1 on: Mon, 11 July 2016, 22:57:52 »
That's a nice collection you've got there! As it stands, you have MX/MX-compatible Linears (in varying layouts) and a Topre board. I would recommend looking into MX/MX-Compatible Clicky/Tactile switches, Buckling Springs or Alps switches. You might also want to look into building or customizing a keyboard of your own, for many users it seems like the next step. Welcome to GeekHack!
« Last Edit: Mon, 11 July 2016, 22:59:43 by Wingpad »
Offline mike52787
  • Alps Aficionado
Re: What's next?
« Reply #2 on: Mon, 11 July 2016, 23:00:55 »
Next step: alps or BS
Re: What's next?
« Reply #3 on: Mon, 11 July 2016, 23:38:57 »
What's the 87u? 55g?
If not. That's next.
If it is. Hhkb.
Offline clankgy1
  • Formerly digifiend
Re: What's next?
« Reply #4 on: Tue, 12 July 2016, 00:01:14 »
If it is. Hhkb.
Also, I don't see any Matias, Alps, or MX Clears.  Also,if you are kit building, you might consider ergo clears or Zealios.  Plenty of itches to be scratched.
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Offline Wingpad
  • The Kumquat Kid
Re: What's next?
« Reply #5 on: Tue, 12 July 2016, 00:07:59 »
Also, I don't see any Matias, Alps, or MX Clears. Also, if you are kit building, you might consider ergo clears or Zealios.
+1 for Kit Building with Ergo clears/Zealios, I was going to mention them but I felt like I listed too many things as it is.
Re: What's next?
« Reply #6 on: Tue, 12 July 2016, 02:08:38 »
Try a split keyboard that is tent-able..   Such as the Ergodox.. or that matias one..
Basically, you don't want m0re flat keyboards, because they're very much the same.
Re: What's next?
« Reply #7 on: Wed, 13 July 2016, 05:50:48 »
Buckling spring (Model M first, then Model F).
Alps - way too many to choose from.
Hall effect?  If you can find one.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: What's next?
« Reply #8 on: Wed, 13 July 2016, 06:39:13 »
^What he said :p . You've still got the best things ahead of you! :D
Make your first Alps board a white, salmon, orange or green one (depending on if you prefer clicky, tactile or linear), and MAKE SURE IT'S NOT DIRTY. Also, you might want to try Montereys or Space Invaders, particularly if you like clicky.
