Author Topic: Soviet keyboard  (Read 5259 times)
Offline decker
Soviet keyboard
« on: Sun, 31 July 2016, 03:46:32 »
Hi,
So I love keyboard layouts and I found this picture :
Does anyone know what the command keys do or say ?
Can someone confirm also that on the upper symbols key the main symbol is shown on top.
I've started making a Qwertyish layout for it if you want to play too :
Soviet Qwerty
Offline kekman
  • quit life
Re: Soviet keyboard
« Reply #1 on: Sun, 31 July 2016, 04:25:00 »
i havent played enough dota to figure this out
Offline Aran.E99
Re: Soviet keyboard
« Reply #2 on: Sun, 31 July 2016, 05:55:06 »
СБРОС = CLEAR (delete)
СТОП = STOP (end)
ПОМ = POM (???)
УСТ = SET
ИСП = COI (???)
good find, it looks like a nice keyboard :) (just realized its the DT wiki image :p)
« Last Edit: Sun, 31 July 2016, 06:31:51 by Aran.E99 »
SMK 2nd Gen Blue Alps mount <3
Offline Screwdriver
Re: Soviet keyboard
« Reply #3 on: Sun, 31 July 2016, 23:56:13 »
I hear a Ctrl/Alt/Del sets off a 1950's era Soviet ballistic missile.
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
Offline klennkellon
  • I like bottoming out
Re: Soviet keyboard
« Reply #4 on: Mon, 01 August 2016, 05:23:59 »
The layout actually looks pretty usable, except for the right shift, every key is where it normally is. I doubt you could get this running easily at all, though.
Offline Aran.E99
Re: Soviet keyboard
« Reply #5 on: Mon, 01 August 2016, 05:38:19 »
if you are interested in one for .99p (missing some keys) this is the link. postage to the UK is high (probably high else where) http://www.ebay.co.uk/itm/Keyboard-for-Elektronika-MS-0511-UKNC-Computer-UNTESTED-MC-MC0511-MS0511-/331858126089?hash=item4d44492509:g:I9sAAOSwmtJXbYDr
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Soviet keyboard
« Reply #6 on: Mon, 01 August 2016, 06:32:15 »
Aren't these rubber dome? Oo
Offline Aran.E99
Re: Soviet keyboard
« Reply #7 on: Mon, 01 August 2016, 06:44:01 »
by the looks of it the keycap's stem acts as a plunger and pushes a membrane down which is returned with a spring that goes over the hole on the keyboard and sits under the keycap.
Re: Soviet keyboard
« Reply #8 on: Mon, 01 August 2016, 09:51:35 »
ur sure this is not an nes clone ?
