Author Topic: repair logitech g502, hair wrapped around wheel  (Read 11473 times)
Offline typo
« on: Sun, 07 August 2016, 04:26:05 »
hi,
i have a bunch of hair and gunk wrapped around the sides of the wheel. it works but it will no longer freewheel. i know how to take it apart no problem. the problem i have is every time i took off the pads/feet on a logitech gaming mouse they were damaged upon replacement. is there any way i can get to the wheel without removing the pads or is there a way to remove and restick the pads without damaging them?
i love this mouse but see no reason to buy a new one if i do not have to since rgb hardly matters to me.
thank you
Re: repair logitech g502, hair wrapped around wheel
« Reply #1 on: Sun, 07 August 2016, 04:45:51 »
I managed to do this on my CM Storm, probably depends what the pads are made of.  I slid a credit card under the edge to minimise bending and put them in a sealed bowl to minimise dust on the sticky...
If you can find the screws without taking the pads off could you carefully cut holes in the pad with a scalpel leaving the rest of the pad intact?
Worst comes to worst you can always get replacement pads :thumb:
Offline typo
« Reply #2 on: Sun, 07 August 2016, 16:57:26 »
ahh, i destroyed the darn thing. oh well. i was so happy with it i bought another but bummer.
Offline typo
« Reply #4 on: Thu, 11 August 2016, 21:25:20 »
I busted the wheel trying to clean it! Not worth it considering you can get the mouse for 40 bucks and I know of no replacement parts.
Offline Bucake
« Reply #5 on: Fri, 12 August 2016, 01:48:37 »
how exactly is it "busted"?
did you actually break a part?
Offline typo
« Reply #6 on: Fri, 12 August 2016, 21:24:51 »
Yeah, I snapped the clear plastic "cradle" in half duh.
« Reply #7 on: Fri, 12 August 2016, 21:42:57 »
super glue,  these parts don't operate under much force,  you should be able to glue it and it'd work just fine.
Offline typo
« Reply #8 on: Fri, 12 August 2016, 23:23:15 »
I just did it. Ill be darned, seems to be holding! Thanks buddy!
Offline duynguyenle
  • Personal text? What personal text???
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline typo
« Reply #10 on: Sat, 13 August 2016, 17:54:22 »
Wow! Thank you!
