Author Topic: How come there's no Soft Drive..  (Read 5508 times)
« on: Sun, 07 August 2016, 12:54:39 »
It just seems like,,  well if you've named something Harddrive,  you should've named something Softdrive..
I mean, if volatility is the underpinning,  then they should've name Ram the Softdrive..
Offline user 18
Re: How come there's no Soft Drive..
« Reply #1 on: Sun, 07 August 2016, 13:18:49 »
Is "floppy drive" (or floppy disk, I suppose) the word you're searching for?
Avatar by ashdenej
« Reply #3 on: Sun, 07 August 2016, 15:25:42 »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Sun, 07 August 2016, 15:33:34 »
floppy is hard though.
Why tp4 is single in 4 words.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Sun, 07 August 2016, 15:41:19 »
The trick is to turn your software into hardware, naturally. Similarly your soft drive into a hard drive.
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Sun, 07 August 2016, 15:54:08 »
I laughed. Loudly  :)) .
Offline user 18
« Reply #8 on: Sun, 07 August 2016, 16:32:53 »
The data storage medium in a floppy disk is a flexible (floppy) magnetic disk. The data storage medium in a hard disk is a rigid (hard) magnetic disk.
They have pills for this now, you know
Avatar by ashdenej
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #9 on: Sun, 07 August 2016, 19:53:51 »
well "hard" drive refers to hardware and Soft drive would refer to software and since you dont really store data in software thats probably why its not a thing.
of if you want to make it dirty... reasons.
Projects
« Reply #10 on: Mon, 08 August 2016, 06:00:48 »
A "hard drive" is only hard in comparison to a floppy drive.
A so-called hard drive can be bent and folded too.  I just tried it on a platter on my desk I'm using as a coaster.  Now I have a bent coaster.
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Mon, 08 August 2016, 07:26:11 »
Floppy drives aren't, and never were, floppy, though :p .
In fact, I have a 5 1/4 inch floppy drive on my desk at home. It's massive, and most of it is cast out of a single piece of metal Oo .
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #12 on: Mon, 08 August 2016, 07:57:41 »
print all the data of the HDD onto paper. Bind the paper with spiral binding. SDD. You're welcome
« Reply #13 on: Mon, 08 August 2016, 09:28:57 »
But that would be 'hard copy' then, right?  ;D
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Mon, 08 August 2016, 09:41:50 »
Offline mrhead
  • Thread \ (•◡•) / Stopper
« Reply #15 on: Mon, 08 August 2016, 10:10:50 »
I distinctly remember the 5 1/4" floppies from our C64 being flexible.  Especially when you insert it before the head has moved out of the way.
Offline chyros
  • a.k.a. Thomas
« Reply #16 on: Mon, 08 August 2016, 10:53:24 »
Yes, the floppies themselves were floppy, hence the term "floppy disk" :p . The drives are ****ing anvils though XD .
Offline mrbishop
  • Evil Genius
« Reply #17 on: Mon, 08 August 2016, 11:12:16 »
i'm just going to say this
tp gonna tp
Projects
« Reply #18 on: Tue, 09 August 2016, 05:41:00 »
Yes, if you want to get technical.  It was actually a "floppy disk drive", the adjective applying to the disk, not the drive.
The disks were definitely floppy, especially the 8" ones.  The 5.25" were the same construction, but seemed more solid as there was less surface area to flex.  3.5" floppies did not, in their entirety, bend much due to the rigid plastic case.  But the magnetic disk inside was very floppy.
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Tue, 09 August 2016, 06:31:27 »
Haha the 8" ones are too old even for me xD . I know of them, but even the PC I had in the late 80s had 5 1/4" disks :D . I still run into them at the recycling centre from time to time! But never an 8" one (yet).
Offline FrostyToast
  • Litshoard
« Reply #20 on: Tue, 09 August 2016, 07:25:40 »
Floppy disks are named what they are because the disk itself inside its plastic housing is flexible.
Most people just see the case and question why the floppy disk has the name it does, but they don't know what's on the inside.
Quote from: elton5354
« Reply #21 on: Tue, 09 August 2016, 15:04:07 »
And it's what's on the inside that counts :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #22 on: Tue, 09 August 2016, 17:01:43 »
I ripped open a few 3.5in floppies when I was younger and more destructive--can confirm :D
Offline chyros
  • a.k.a. Thomas
« Reply #23 on: Tue, 09 August 2016, 19:32:29 »
I found a 5 1/4 inch one with DOS on it a while ago at the recycling centre - oh, the memories! :D
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #24 on: Tue, 09 August 2016, 19:35:31 »
I paid a visit to my local recycling center a few days ago to find lots of CRT TV/Monitors and a few HP port replicators. Not even the kind of replicators with HDDs :-[
« Reply #25 on: Tue, 09 August 2016, 21:55:43 »
I has a bunch of DDS tapes used for backups long ago.
All my DDS drives died years ago (maybe around 10 years ago), and the tapes have been sitting there unused since then.
So I had a cleanout and opened them all up and despooled all the tape, then cut it into random chunks.
Tape everywhere :))
