Author Topic: I'm So FAT.. (Paging --Melvang--)  (Read 7578 times)
« on: Wed, 10 August 2016, 20:43:23 »
Shattered the Crank on my Exercise Bike...
The slot where the pedal screws into the crank broke into 2 pieces.. It's freakin' Stainless steel..
Now I'm gonna become EVEN FATTER than How fat I Already am... Because I can't use the Exercise bike..
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: I'm So FAT
« Reply #1 on: Wed, 10 August 2016, 20:47:13 »
Damn son, you're gonna have to start buying Medium shirts now :))
Re: I'm So FAT.. (Paging --Melvang--)
« Reply #2 on: Wed, 10 August 2016, 20:55:43 »
Dear: Expert Handyman --Melvang--
In your opinion ,  Do you think I could reliably weld this,  given this small surface area...
I only have access to an electric cheapo welder atm..
145005-0
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Thu, 11 August 2016, 03:46:20 »
Why not buy an ACTUAL bike and go outside and cycle? :p
« Reply #4 on: Thu, 11 August 2016, 03:55:48 »
I did that for a bit..
Too time consuming..
If I'm exercising for 25 minutes..
Going outside requires at least 10 of those minutes..
Pants, Socks, Shoes,
Open Garage,
Wheel out bike,
Close Garage,
Wheel in bike,
Open Garage,
Close Garage
Shoes, Socks, Pants..
Exercise bike,   Put on my plastic slippers and GO..
« Reply #5 on: Thu, 11 August 2016, 06:46:04 »
Open Garage,
Wheel out bike,
Close Garage,
Wheel in bike,
Open Garage,
Close Garage
They make stands to use the real bike inside. :D
« Reply #6 on: Thu, 11 August 2016, 06:53:05 »
Tried it..
It's super LOUD..
  • Live long and prosper
« Reply #7 on: Thu, 11 August 2016, 06:58:44 »
No way you'll be able to weld that, it's cast steel.
tp thread is tp thread
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Thu, 11 August 2016, 07:06:47 »
Open Garage,
Wheel out bike,
Close Garage,
Wheel in bike,
Open Garage,
Close Garage
No, just use cycling as your sole means of outside locomotion. Don't use a car or public transport EVER. You can pretty strong legs from that ;) .
Offline nugglets
« Reply #9 on: Thu, 11 August 2016, 07:27:24 »
Tried it..
It's super LOUD..
I have one, it's certainly audible... but not much louder than a resistance bike.
« Reply #10 on: Thu, 11 August 2016, 07:57:33 »
why can't weld cast steel ?
« Reply #11 on: Thu, 11 August 2016, 07:58:57 »
Anything more than 300 meters, As I live in 'Murica, I feel obligated to drive..
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Thu, 11 August 2016, 08:00:33 »
Yeah, don't do that :p .
Offline Blackehart
« Reply #13 on: Thu, 11 August 2016, 11:24:22 »
TP, allow me to present a counterpoint....
Perhaps you're too swole now? Your legs are so rock hard that your bike just couldn't handle all that force...
:p
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #14 on: Thu, 11 August 2016, 12:29:20 »
tp4, at least from the last photo you shared, you weren't fat enough to break cast steel.
tp, I think you may not be as fat as you think you are.  :))
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15 on: Thu, 11 August 2016, 12:42:20 »
Crank arms are super cheap tp. Just bring that one into one of those recycling bike shops and they'll hook you up. I've had a few strip out on me about the same time I broke a back derailleur hanger (tallest FL hills I guess). Pro Tip - stop over-tightening :-*
« Reply #16 on: Thu, 11 August 2016, 15:22:04 »
This is non-removeable,  the whole assembly is welded..
Offline Spopepro
« Reply #17 on: Thu, 11 August 2016, 16:19:13 »
The whole assembly isn't welded. It's likely tapered interference fit, and requires a special tool to remove.
There's no way you could bond or weld that and get it to work. Fankly, if something breaks like that I wouldn't use anything made by that company. That's super scary and I'd expect other stuff to start falling apart.
The "thing that turns regular bike into a stationary" is called a trainer, and there are different kinds. Some use an impeller or fan, are the cheapest version, and are loud as ****. Some use magnetic resistance, are a bit more expensive, and can be kind of loud. Some have a sealed fluid resistance thing, are the most expensive, but are nearly silent. The tires you use can also make a bunch of noise, as you'll need to use something cheap and smooth.
Or you could really go for it and get a set of rollers:
« Reply #18 on: Thu, 11 August 2016, 16:47:56 »
I assure you it's not a Taper Interference fit,  There is no slot for any tool Period..
The thing is welded from both sides..  You can tell the assembly is one piece from the factory, and then inserted into the chassis, then the outer rim welded on afterwards..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #19 on: Thu, 11 August 2016, 16:50:54 »
C'mon you're not fooling anyone with that cruiser brake
I'm surprised that you of all people would buy a bike that doesn't take a standard bottom bracket cartridge
« Reply #20 on: Thu, 11 August 2016, 17:46:30 »
It's an exercise bike..
I never honestly expected this to break..   I've completely underestimated how Fat I am..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #21 on: Thu, 11 August 2016, 17:56:15 »
Ohhhh, whoops THAT type of exercise bike
« Reply #22 on: Thu, 11 August 2016, 18:03:57 »
OR
you could ride your bike... outside!  :eek:
« Reply #23 on: Thu, 11 August 2016, 18:28:01 »
I'm so fat I sometimes take one microwave meal and just dump it on top of another one. They don't even have to be the same type, I've dumped bacon macaroni onto orange chicken I don't give a ****.
« Reply #24 on: Fri, 12 August 2016, 06:17:01 »
Pretty sure Every one did this.. At least when I ate microwave meals when younger..
I've moved onto pretty much exclusively Ramen though...
Offline jaffers
« Reply #25 on: Fri, 12 August 2016, 07:34:46 »
That looks more like powdered metal to me
« Reply #26 on: Fri, 12 August 2016, 08:07:44 »
I think this part was weakened due to the chroming.. Damn you Hydrogen..
Offline chyros
  • a.k.a. Thomas
« Reply #27 on: Fri, 12 August 2016, 09:28:06 »
What did hydrogen ever do to you? :p
« Reply #28 on: Fri, 12 August 2016, 10:07:17 »
Went out last night and saw a picture of me. I'm forming a double chin.  :'(
5'9" and 170lbs. Gotta start doing more cardio exercise and eating more proper portions.
Offline SBJ
  • Tactile pls
« Reply #29 on: Sat, 13 August 2016, 02:07:01 »
Proper portions is my problem as well.
I tend to get a little too much.
« Reply #30 on: Sat, 13 August 2016, 03:04:00 »
I heard eating more slowly helps with the portion control
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #31 on: Sun, 14 August 2016, 02:18:33 »
The resolution / focus of the original image isn't good enough for me to really tell if it is cast or not.  If it is cast, it *can* be welded, but it will require preheat, welding rod with a high nickle content, arc welder with DC, and then a post heat and wrapped in either weld blanket, or buried into half burned out charcoal to drastically slow down the cooling process.  The reason for all this is because of the metallurgy and structure of cast.  Any cast metal is full of small air pockets.  This essentially acts as tiny heat insulators and you get a very drastic heat change in the material and this creates stress points and can cause cracks, both along the weld, and into the surrounding material.  The pre heat, post heat, and slow cooling attempts to minimize it.  Even if it can be welded, i am very doubtful that the threads will line up close enough to work properly.  Even if you were to find a bolt with the same threads, you get enough movement with the heating and cooling, it just won't be the same.  Best bet if you do want to weld it, would be to try and find a helicoil of the proper size and have it drilled and fixed that way after welding.  Either way, since you had to ask about welding it, you will be much better off taking it to a shop if you really want this done.
Hydrogen doesn't play a part in chrome plating.  It is an electrochemical bath dip process.  Minimum 3 steps if I remember right.  Chrome won't stick to steel but will stick to copper, copper won't stick to steel, but will stick to nickle, and nickle will stick to steel.  So it is a plating process that dips in nickle, then copper, then the chrome.  I could be off on this, but if memory serves correct, this is how it goes.
If it is powdered metal as jaffers suggested, you are totally **** out of luck here.
« Reply #32 on: Sun, 14 August 2016, 04:52:02 »
Melvang haz Spoken...
Thanks Mel...
#TpFat4ever2016
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #33 on: Tue, 16 August 2016, 11:47:23 »
Maybe you underestimated how strong your legs are instead?
« Reply #34 on: Wed, 17 August 2016, 02:24:25 »
:p
txx for trying to make Tp4 feel better guys..
But Tp4 has no delusions about how fat Tp4 iz
