Author Topic: Hair Wax/Pomade  (Read 7572 times)
Offline kenmai9
  • Unicornforce
  • Skrrr
Hair Wax/Pomade
« on: Thu, 11 August 2016, 19:14:11 »
anyone got slickback/undercut hairstyle and can recommend good wax? i currently use gatsby pink along with american crew (can't remember which one, but it has elvis on the cover lol) one but want to try something else. i got asian hair so its super thick and i need a strong hold one
Please advise.
« Last Edit: Thu, 11 August 2016, 19:18:27 by kenmai9 »
Re: Hair Wax
« Reply #1 on: Thu, 11 August 2016, 19:22:14 »
I have used many wax/fiber brands over the years and the best are Redkin and American Crew imo. I usually use AC since it's a little cheaper, but both are excellent for hold.
I have recently gotten into getting my mane big with a Hollywood-looking coif upfront and feathering on the sides and have discovered hair powder. Hair powder is ****ing amazing when paired with a light fiber, it's magic in a bottle.
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #2 on: Thu, 11 August 2016, 19:28:14 »
Did some research on asian peeps and their difficulties, and was given this as recommendation (Layrite Super Hold): https://www.amazon.com/gp/product/B0041W9S4W/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B0041W9S4W&linkCode=as2&tag=atft-20
Do you have a link to the stuff you use? Also maybe a pic of your hair or something similar to yours?
Need pics for reference.
Re: powder, that sounds cool. i hate when the part in the front looks flat. my hair is really heavy so its hard to get the exact look i want
« Last Edit: Thu, 11 August 2016, 19:29:55 by kenmai9 »
Offline graefeln
Re: Hair Wax/Pomade
« Reply #3 on: Thu, 11 August 2016, 19:57:45 »
I've been a fan of Lockhart's for a few years now - you can find them on Etsy. Not really sure how the stronger holds will work with your hair type; my hair is relatively fine and I find that a light/medium works well for me. I am also a fan of Brylcreem (preferably the UK version), but I know that would be too light for you as that doesn't even really hold my hair in place (it's more of a dressing than a pomade).
I've found that the petrolatum-based pomades are more to my liking - nice hold and good shine - but they don't wash out as easily. After a couple days of buildup, I throw in either the Brylcreem or some Groom & Clean for a day or two and it helps degrease.
A heavy-weight pomade maybe compounding the problem - depending on the brand, maybe try switching to a medium or mixing a medium and heavy.
« Last Edit: Thu, 11 August 2016, 20:01:16 by graefeln »
Offline rm-rf
Re: Hair Wax/Pomade
« Reply #4 on: Thu, 11 August 2016, 20:25:02 »
wood glue. and spray paint.
Re: Hair Wax/Pomade
« Reply #5 on: Thu, 11 August 2016, 20:30:32 »
Tp4 = Sifo- Expert Hair stylist..
Get a Perm..
Go to a Korean hair place..  They'll know exactly what to do..
Just pick something from the Kpop magazine which they'll have stacks of.
Re: Hair Wax/Pomade
« Reply #6 on: Thu, 11 August 2016, 20:36:14 »
Waxes are generally for INDOOR operation only..
They will not keep to wind,  especially given how heavy and Dense Sifo Hair is.
All Outdoor operations require Hair spray.. NOT flexihold,  the Hard stuff..
It will still look natural and textured as long as you spray from a longer distance, and deposit thin layers upon thin layers.  (wastes alot of product, but it's the only way)..
Strongest hold on budget for spray is the G2B freeze spray..  really cheap, really strong.
Re: Hair Wax/Pomade
« Reply #7 on: Thu, 11 August 2016, 20:37:49 »
Also keep in mind..
When using gel, wax,    most people just do an even coat throughout the entire area..
HOWEVER, this is mostly Wrong,   Certain areas of hair require more or less because hair grows at different angles relative to the force of gravity..   Keep that in consideration when you shape your hair.
Re: Hair Wax/Pomade
« Reply #8 on: Thu, 11 August 2016, 20:40:14 »
Gel typically does not mix well with wax,  as it won't stick to the hair once the wax is already coating it..
All of those Stylish videos you see on Youtube with the jap stylists applying their wax.. EVERY SINGLE one of those guys have had their hair permed for shape beforehand..
You can tell by the way their hair will keep to odd angles easily, which natural straight hair WILL NOT DO..
Re: Hair Wax/Pomade
« Reply #9 on: Thu, 11 August 2016, 20:40:34 »
Hence why, if you're really looking to go stylish, you need a Perm..
Re: Hair Wax/Pomade
« Reply #10 on: Thu, 11 August 2016, 20:41:05 »
Grow your hair to around 2.5-3 inches all around..  and call in for a session..
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #11 on: Thu, 11 August 2016, 20:41:23 »
I love you tp4
Sent from my ONEPLUS A3000 using Tapatalk
Re: Hair Wax/Pomade
« Reply #12 on: Thu, 11 August 2016, 20:43:04 »
The majority of the styles you see which has great lift and texture, also require a hair iron, either straightener, or curler, this is ONTOP of a perm..
Re: Hair Wax/Pomade
« Reply #13 on: Thu, 11 August 2016, 20:45:19 »
You can get away with a Blowdryer,  but you really have to know what you're doing....
Re: Hair Wax/Pomade
« Reply #14 on: Thu, 11 August 2016, 20:47:15 »
Also, I can't stress this enough..
DO NOT use 2-in-1 shampoo..
Get the separate components..  Tp4 uses the Pantene Curl Perfection conditioner, works well for Thick Sifo-Hair..   They used to have this medium-thick formula, which worked similarly,maybe even a little better, but they no longer sell it..
All of Pantene's shampoo with the exception of Volumizing works about the same in terms of final outcome of Styling..
Re: Hair Wax/Pomade
« Reply #15 on: Thu, 11 August 2016, 20:49:32 »
Wash and Deeply Lather hair with Shampoo..   Add just a handful of water,  Lather again..
Rinse thoroughly..
Squeegee as much water out of hair as possible..
Now use 2 Table spoons of conditioner..  thoroughly coat hair..
LEAVE IN..
Wash the rest of your body..
Rinse hair of conditioner as Final step..
Re: Hair Wax/Pomade
« Reply #16 on: Thu, 11 August 2016, 20:54:08 »
@ N-Turtle..
Hair Powder is completely useless on Sifo-Hair..  unless you're the rare Sifo with very thin hair strands.
I should clarify..
It's possible to use it to get roots to stand up WHILE you style it,   But an easier method would just be tilting your head, and spray..
Re: Hair Wax/Pomade
« Reply #17 on: Thu, 11 August 2016, 20:59:17 »
@ N-Turtle..
I should clarify..
yeah my hair is super fine, I need to bulk it up with wax or fiber before I style it or else it's just a bird's nest all day. but powder gives my hair lift and shape I never thought was possible with my hair type.
Re: Hair Wax/Pomade
« Reply #18 on: Thu, 11 August 2016, 21:04:40 »
@ N-Turtle..
I should clarify..
If it's really thin.. You can skip conditioner all together..     The majority of the time, conditioner reduce volume..
Try Hair spray..
Tilt head horizontally,, fluff it , and spray.
Re: Hair Wax/Pomade
« Reply #19 on: Thu, 11 August 2016, 21:13:24 »
@ N-Turtle..
I should clarify..
Try Hair spray..
No way, hairspray is gross! Like I said I like to keep my hair airy and fluffy like a coiffed lion's mane, but still have it hold it's shape throughout the day which is a bit of a conundrum but I've finally found a balance after years.
Dry upside down with a blow dryer (air dry if there is time) then use a fiber wax as a base for rigidity. After that dries I brush out the excess wax with a fine round-brush and form the shape, them I layer in the hair powder and comb it out untill soft. Then I use a styling comb to get the front lift and side-feathering. Takes like 20 minutes every morning :))
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #21 on: Fri, 12 August 2016, 00:03:47 »
I'm not getting a perm lol. My hair is fine. I just wanted to try a new wax hahahah. I ordered that layrite and tresseme spray so that the wind doesn't fk my **** up.
I do my hair while it's damp. No time to blow dry. I do first the American crew to shape it, then use the Gatsby wax to fortify it. Then comb to my liking. It worked pretty well today. Im always experimenting.
I'll let you know how the new product works next week.
Offline SBJ
  • Tactile pls
Re: Hair Wax/Pomade
« Reply #22 on: Fri, 12 August 2016, 00:28:10 »
I use a brand called NAK they make something called "Slik Pomade" - it does the job and smells uh-mazing.  ;D
I don't know what the English translation is exactly but it's something like "Candy Pomade"
Re: Hair Wax/Pomade
« Reply #23 on: Fri, 12 August 2016, 02:37:29 »
Well, certainly possible..
Post a foto so we can tell if you need a perm.
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #24 on: Fri, 12 August 2016, 09:59:57 »
« Last Edit: Fri, 12 August 2016, 10:05:16 by kenmai9 »
Re: Hair Wax/Pomade
« Reply #25 on: Fri, 12 August 2016, 10:22:05 »
Looks good Kmai.
If you don't want to get a perm.
You will at least need to get the long parts thinned out via thinning shears.
You've got the normal thick heavy Sifo-Hair..  Without thinning.. it's hard to get texture..  And the hair generally carries too much momentum while in motion, for wax..
Wax may work if you're just sitting there,  but bob your head any place, it'll come apart fast.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hair Wax/Pomade
« Reply #26 on: Fri, 12 August 2016, 12:59:33 »
Axe Whatever. Four grains of rice amount + some water--mess it up and I'm done
In the future, I might try some unscented types because even after 6-7 years I'm still not a fan of the smell :p
« Last Edit: Fri, 12 August 2016, 13:03:26 by csmertx »
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #27 on: Fri, 12 August 2016, 16:27:25 »
Looks good Kmai.
What does perm do? Make it curly or wavy??
How would that help me?
Re: Hair Wax/Pomade
« Reply #28 on: Fri, 12 August 2016, 16:49:40 »
That could be a Choice for the outcome of the perm.
But the main reason, is that it weakens the hair fiber some what, so you can style it more easily.. more texture and volume
The secondary reason, would be to add certain directionality for easier management into the style you want.
____ For example, if your hair pulls to the left, but the style you want goes to the right, or straight up, or up and back,  a Perm can make a hard shift in the direction of the hair to get into that shape.
Offline bazh
Re: Hair Wax/Pomade
« Reply #29 on: Mon, 15 August 2016, 06:07:44 »
I've been using Suavecito lately
HHKB Pro2 white
Newbie again
Re: Hair Wax/Pomade
« Reply #30 on: Mon, 15 August 2016, 11:34:05 »
We really got to thank the guys who made the 2-block cut style popular.
IMHO, it's the most efficient mens' hairstyle..
Tp4 overheats all the time when using the Internet..  Short sides significantly aid in heat dissipation..
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #31 on: Tue, 16 August 2016, 18:43:34 »
so i got this stuff over the weekend. i did my hair really fast this morning because i was late, so i didnt really try hard on it.
this is 7 hours into the day, with wind outside rekking me, but still looks p good imo
also the back little hair thing is a problem, idk how to fix it. told my dood to cut it shorter but it still doesn't behave.
i'm probably due for a haircut this weekend or next..
Re: Hair Wax/Pomade
« Reply #32 on: Tue, 16 August 2016, 20:08:41 »
why are you so angry..
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #33 on: Tue, 16 August 2016, 20:39:03 »
Because my forehead is oily
Re: Hair Wax/Pomade
« Reply #34 on: Tue, 16 August 2016, 21:33:36 »
Eat less Carbs..
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Hair Wax/Pomade
« Reply #35 on: Tue, 16 August 2016, 21:53:56 »
Eat less Carbs..
I'm on keto lol. Im just oily boi
