Author Topic: O-Rings for Reds?  (Read 4658 times)
Offline Screwdriver
O-Rings for Reds?
« on: Tue, 16 August 2016, 15:35:28 »
So I picked up a KUL-87 MX Red board from a friend and am revisiting a previously hated switch. I am liking the silence of the stroke, but would like to silence the bottom sound. Not looking to shorten the stroke as much as deaden the sound. So a o-ring that quiets the bottoming, does not shorten the stroke much and is not too mushy.
What do you folks recommend?
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
Re: O-Rings for Reds?
« Reply #2 on: Sun, 21 August 2016, 09:24:35 »
70 is pretty hard.
I would say the thinnest and softest ones that you can find. This is my preferred mod for Cherries.
- D Trump 2026-10-24
« Reply #3 on: Sun, 21 August 2016, 15:22:36 »
If you want silent,  Get the MX silent from Corsair..
The oring only silent downstroke, but upstroke is still pretty loud.
Offline Erikdayo
« Reply #4 on: Mon, 22 August 2016, 09:51:40 »
I can confirm that the MX Silent switches are much quieter than I ever imagined. The issue is that if you like the lightness of Reds you might not like the Silent version. While they are supposedly weighted the same I felt that the Silent switches felt a bit heavier. I no longer have Blacks for comparison, but I think they feel closer to Blacks than Reds.
Offline Screwdriver
« Reply #5 on: Mon, 22 August 2016, 09:57:49 »
I like the weight of the Reds....and am not looking for a totally silent stroke, just a slight muffle on the bottom clack.
Gonna order a few different o-rings and give them a try.
Offline Erikdayo
« Reply #6 on: Mon, 22 August 2016, 10:06:37 »
I like these ones for Reds. I feel like they help a bit without really changing the feel of the switch.
https://www.amazon.com/Cherry-Rubber-O-Ring-Switch-Dampeners/dp/B00AZQ3966/
Offline ThoughtArtist
« Reply #7 on: Mon, 22 August 2016, 14:42:11 »
Clack or die
Offline quake4mhg
« Reply #8 on: Mon, 22 August 2016, 14:46:20 »
The smallest thin one without shorten the distance. And hardness/softness is personal preference.
Or put a matte under keyboard?
« Reply #9 on: Mon, 22 August 2016, 14:54:07 »
Get these: https://www.amazon.com/008-Buna-N-Ring-Durometer-Black/dp/B000FMWLR8
Then remove them later and feel liberated.
Offline klennkellon
  • I like bottoming out
« Reply #10 on: Mon, 22 August 2016, 17:13:42 »
MX Silent are lovely. The ones I tried were super smooth and the weighting felt somewhere between MX Reds and MX Blacks, about as good as my linear Alps.
Offline ddot
  • Master of Suspense
« Reply #11 on: Mon, 22 August 2016, 23:21:26 »
If you want cheap, you can't beat ebay.  Here's one option.
If you want something a little thicker and/or a little softer, check out Lpwl in the vendor area and see what he can do for you.  His sample pack might be a good way to start.
Offline Moistgun
  • Slippery When Wet
« Reply #12 on: Tue, 23 August 2016, 00:19:36 »
My solution to anti clacking was just to go heavier.
linears are my ****.
I didnt wanna lose the travel though so, added some weight by using blacks, and now i dont bottomout.
Offline Screwdriver
« Reply #13 on: Tue, 23 August 2016, 10:24:04 »
Thanks, those are the ones I decided to buy.
« Reply #14 on: Fri, 26 August 2016, 06:04:16 »
+1 for Lpwl.
There are some great pictures in one of his threads, and he's probably more than happy to help you out.
