Author Topic: is that fine for lubing ?  (Read 5156 times)
Offline UrNsFace
« on: Sun, 21 August 2016, 11:40:36 »
http://www.ebay.com/itm/141914801732?ul_noapp=true
will that be fine for lubing my quick fire rapid keyboard ?
Re: is that fine for lubing ?
« Reply #1 on: Sun, 21 August 2016, 15:17:15 »
Don't lube..
Cherry MX is not designed to lube..  Any lube you put on won't stay in place very long..
And if you are not switching out to a quick swap plate,   it's way too much labor.
Offline UrNsFace
« Reply #2 on: Sun, 21 August 2016, 15:40:01 »
Don't lube..
i have seen many people lubing costar stabilizers
i needed to wash my space bar but didnt think about washing the lube that was on the mounts on both sides
now its rattling and loose
so i hope that lube will do the job
Offline riko
« Reply #3 on: Sun, 21 August 2016, 15:42:18 »
What do you want to lube? The stabilizer or the stem of your cherry switch?
Sent from my LG-D855 using Tapatalk
Offline UrNsFace
« Reply #4 on: Sun, 21 August 2016, 15:46:04 »
the costar stabilizer
will that lube i have given a link to is good and wont hurt the keyboard?
Offline henz
  • What?
« Reply #5 on: Sun, 21 August 2016, 15:51:48 »
i use grease from time to time in mx switches, works for me :)
Offline UrNsFace
« Reply #6 on: Sun, 21 August 2016, 16:04:46 »
what kind of grease ?
and what do you think about the one i asked about from ebay ?
« Reply #7 on: Sun, 21 August 2016, 16:10:52 »
This stuff works great, and a tube will lube many dozens of tabs.
https://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
- D Trump 2026-10-24
Offline UrNsFace
« Reply #8 on: Sun, 21 August 2016, 16:52:00 »
the problem they wont ship it to israel.....
how will  the lube i have given a link to  will do ?
Offline riko
« Reply #9 on: Sun, 21 August 2016, 20:22:49 »
The lube well work.
« Reply #10 on: Sun, 21 August 2016, 21:08:39 »
People usually use white lithium grease for stabilizers.
Offline UrNsFace
« Reply #11 on: Fri, 26 August 2016, 07:39:38 »
ok so i have ordered that lube from ebay...
Offline jcoffin1981
« Reply #12 on: Sat, 27 August 2016, 10:17:43 »
I would be a little leary of a grease produced in China or India, especially when they do not disclose what is actually in it, just that it contains silicone.  There are some materials that are not good for plastic.
I purchased this Dielectric Grease and it worked great for lubing friction points on cherry stabilzers.
https://www.amazon.com/gp/product/B000AL8VD2/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I also purchased this, but have not used it yet. Traxxas Silicone Grease
https://www.amazon.com/gp/product/B0006O5GHW/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Offline UrNsFace
« Reply #13 on: Sat, 27 August 2016, 18:59:48 »
he traxxas shipping to israel is 14$
and the other one isnt shipped to israel
what can i do... hope what i have ordered wont ruin my keyboard
Offline UrNsFace
« Reply #14 on: Sat, 27 August 2016, 19:02:12 »
http://www.ebay.com/itm/Traxxas-Silicone-grease-1647-/262511503520?hash=item3d1ee7a8a0:g:Eh0AAOSwgY9Xe6F6
oh but i can order that from here
should i ?
« Reply #15 on: Sun, 28 August 2016, 21:06:27 »
There is not always a problem with lubricant components themselves, but most "lubricant products" have more liquid components that help keep them liquid to apply and penetrate easily. The combination of solvents and plastics are unpredictable, especially long-term. Have you seen an old keyboard with its cable wrapped around it for years in storage, and the plasticizers in the cable literally melted into the keyboard case?
Offline jcoffin1981
« Reply #16 on: Tue, 30 August 2016, 14:59:47 »
I mean it's *probably* okay, but who can say for sure.  The seller says it's safe for electronics and plastics.  I would just use it sparingly at the friction points so it doesn't drip and travel to unwanted areas.
