Author Topic: Electrical Tape ?  (Read 4604 times)
Electrical Tape ?
« on: Wed, 24 August 2016, 14:11:03 »
So I finally used up the roll I bought in 1997..
What's a good brand these days..
I think, I'd still like gummy but not TOOO gummy.
Offline Moistgun
  • Slippery When Wet
Re: Electrical Tape ?
« Reply #1 on: Wed, 24 August 2016, 14:12:43 »
TP
Its electrical tape.
you dont need to worry about the brand of everything you buy.
Offline kingpilcrow
« Reply #2 on: Wed, 24 August 2016, 14:15:23 »
Uh oh, TP4 escapes Off Topic form.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Wed, 24 August 2016, 14:21:10 »
Go home tp you're drunk
Offline Moistgun
  • Slippery When Wet
« Reply #5 on: Wed, 24 August 2016, 14:33:57 »
isnt he always
« Reply #7 on: Wed, 24 August 2016, 19:11:22 »
TP
Well,  considering the last roll lasted 19 years..
I figure I'd get a good one for the next 19 years ..
Offline Moistgun
  • Slippery When Wet
« Reply #8 on: Wed, 24 August 2016, 21:57:06 »
TP
You got me there.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #9 on: Thu, 25 August 2016, 00:13:49 »
Just don't use it much...
Offline TerryMathews
« Reply #10 on: Thu, 25 August 2016, 19:13:14 »
Bezerkfan. It doesn't stick around.
« Reply #11 on: Thu, 25 August 2016, 19:18:25 »
Nonono...
Only cuz  the --Rootwyrm brand flux-- caused Bezerkfan-tape to not stick on the Solder joints..
This what happens when you get cheap and ****ty flux
« Reply #12 on: Thu, 25 August 2016, 20:47:00 »
Nonono...
Some tape retains its integrity no matter what gets underneath it, you know the better quality stuff.
« Reply #13 on: Thu, 25 August 2016, 21:18:50 »
Nonono...
Incorrect,  there's a specified limitation to any tape..
More importantly we need to clean off the Gunk that is --Rootwyrm-- before applying the Good Berserkfan Tape..
« Reply #14 on: Thu, 25 August 2016, 21:28:55 »
You have an interesting idea of what constitutes good; I wouldn't have you repairing any electronics at my house if this is how you judge quality.
« Reply #15 on: Fri, 26 August 2016, 03:14:29 »
The electrical tape was Good,  However,  the Procedure and proper handling was poor.
It's true that while the job had been too large for the small electrical tape to handle..  It was indeed the Bad Flux which caused the most problems...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #16 on: Fri, 26 August 2016, 03:24:07 »
I've very few positive experiences with electrical tape aside from taping up bike equipment (finishing handlebar tape, in a pinch bike seat repair, yadda yadda). I'm just not convinced that there is an electrical tape brand better than wire nuts or soldering & shrink wrap.
Online fohat.digs
« Reply #17 on: Fri, 26 August 2016, 07:58:15 »
I like electrical tape a lot. It is a great all-purpose repair like duct tape, only more discreet. Strong and waterproof.
I keep black, white, and red around all the time.
- D Trump 2026-10-24
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #18 on: Fri, 26 August 2016, 08:13:19 »
I've seen electrical tape used in previous installations (I was an A/C installation mechanic for nearly six months - I couldn't take the heat :-[) and I would usually find bite marks and feces around the electrical tape. I know there has been lots of progress in incorporating chemicals that taste horrible to rodents but I still can't trust electrical tape.
Electrical tape worked beautifully for securing the handlebar tape on my old World Sport drop bars, though. Definitely held up to lots of rain :thumb:
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #19 on: Fri, 26 August 2016, 15:39:46 »
isnt he always
isn't he always what? Home or drunk?
Or both
« Reply #20 on: Fri, 26 August 2016, 15:42:04 »
isnt he always
Or both
/Not drunk..
Although...  it is friday..
Nawh.. gotta stay fresh so I can play video games this weekend.
