Author Topic: OT: Non-Standard Typists, what boards do you use?  (Read 2058 times)
Offline NewToKeyboards
« on: Sat, 27 August 2016, 06:16:33 »
I am not sure how many other people out there are not standard typists, and by that I mean you do not float your hands above the board, and you do not use home row. But I was wondering what keyboards do you all use and who out there does not use the 'proper' typing technique? I know that out of the keyboards that I have had there were two that had a lip right at the front of the board that would cut into your hands if you had your hands on the desk whilst typing, but the K70 that I have does not have that lip, even without the wrist rest.
Thanks for the input in advance!
NTK
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: OT: Non-Standard Typists, what boards do you use?
« Reply #1 on: Sat, 27 August 2016, 07:31:15 »
Screw the "proper typing technique", I just type the way I type :p . It's fast enough for me, so nay bother xD .
Offline SBJ
  • Tactile pls
« Reply #2 on: Sat, 27 August 2016, 09:05:12 »
Truth!
Type the way you want to type, the way that makes sense for you and the way you get good results.
« Reply #4 on: Sat, 27 August 2016, 16:35:37 »
There is only 1 /ERGODOX
Sounds good to me!
Truth!
I tried learning home row not too long ago, but I really was not a fan of trying to change my technique that I have built up over time :P
