Author Topic: Which thumb do you hit the spacebar with?  (Read 33229 times)
Offline cribbit
« on: Mon, 29 August 2016, 18:30:17 »
Most people only ever use one of their thumbs for spacebar while typing. Which do you use?
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Re: Which thumb do you hit the spacebar with?
« Reply #1 on: Mon, 29 August 2016, 18:35:58 »
Right. Rarely left.
Offline cribbit
« Reply #2 on: Mon, 29 August 2016, 18:41:43 »
Also, approximately between which two keys do you hit? For example, I hit my right thumb betweeen n and m most of the time.
Offline davkol
  •  Post Editing Timeout
Offline Quaranta
« Reply #4 on: Tue, 30 August 2016, 02:56:28 »
I hit the space bar with my right thumb between N and M most of the times, but also many times with my left thumb between C and V. My spacebar's dust also says I sometimes hit between V and B, I think with boths  thumbs.
A bit off topic, but recently I've been to three different doctors (MDs) and I was surprised to see that, even they were kind of proficient typing (not typists, but they used most of their fingers), they hit the space bar with their right index finger. I found it interesting, and I can't guess why.
Offline pieman103021
« Reply #5 on: Tue, 30 August 2016, 03:14:33 »
Just did a quick test, I hit it with my right thumb just under the M key, or the B key if I am in vim(programming).
S60x w/ Mod-Ms, Ducky Blanks | xd60 | kbp v60 mini
Fedora | bspwm | emacs
Offline fanpeople
« Reply #6 on: Tue, 30 August 2016, 03:22:37 »
Middle thumb
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Tue, 30 August 2016, 06:44:05 »
Sadly, I use my left thumb. Quake ruined everything :-[
Offline henz
  • What?
« Reply #9 on: Tue, 30 August 2016, 06:47:03 »
i can do both, supposedly you should use right thumb when writing qwerty, and left with dvorak.
Offline Salt Peanuts
« Reply #10 on: Sat, 03 September 2016, 20:15:11 »
Left thumb for spaces in middle of sentences.  For double spacing after a period, I have a terrible habit of using my right index finger.
« Reply #11 on: Sat, 03 September 2016, 21:21:32 »
I know it's wrong for QWERTY based, but left because of gaming. I try to use my right whenever I can but not while racing.
Offline ReverbSlush
  • 16/52 RNG score
« Reply #12 on: Sat, 03 September 2016, 21:24:11 »
I know I use both but the shine on my HHKB says:
*more often right thumb, between B and N
*less often left thumb, directly under V
Offline deductivemonkee
  • Professional Lurker
« Reply #13 on: Sat, 03 September 2016, 21:32:10 »
Right, and if I am using my usual typing habit which I need to break, my right index finger.
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline itzmeluigi
  • ПБТ
« Reply #14 on: Sat, 03 September 2016, 23:27:26 »
Left 100% of the time.  Never have used right.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #15 on: Sun, 04 September 2016, 00:17:27 »
yeah I am pretty sure I only use my right thumb somewhere between the n and the B key depending on how far cross the keyboard my right hand goes.
I was convinced before I actually looked at myself typing that I used my left thumb to hit the spacebar. I did actually used to use my right index finger to hit the spacebar until a while ago...
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #16 on: Sun, 04 September 2016, 01:17:06 »
Forehead 90% of the time, right thumb 10% of the time.
Offline klennkellon
  • I like bottoming out
« Reply #17 on: Sun, 04 September 2016, 02:28:11 »
I use my left thumb for spacebar and also to press V.
Offline xondat
  • i'm not a star
« Reply #18 on: Sun, 04 September 2016, 07:53:51 »
Right thumb, when typing on the alphas, but when I want to do something like this - I use my left thumb. Right thumb is always under N, and left thumb is usually resting on the edge or just hovering, but when I use it I press around C and V.
I can understand people using the left thumb, as it's probably been developed through playing games. I'm sure I would've been the same but for jumping I always used scroll up :))
Offline Giorgio
« Reply #19 on: Sun, 04 September 2016, 07:57:09 »
The left.
And it is the left for all those who use cad or any software that requires shortcuts, since your right hand is on the mouse.
Offline nephiel
« Reply #20 on: Sun, 04 September 2016, 08:21:02 »
In my case it was always left thumb, so I split the spacebar and put Fn on my right thumb.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline Shikarikato
« Reply #21 on: Sun, 04 September 2016, 16:54:47 »
i feel like just to add to statistics
neither
i only use my right index finger and i press right in around n and m pretty consistently
depends on where my hand is at the time
if im typing slow i can sometimes hit the spacebar with my left thumb but i find it so awkward
Offline Giorgio
« Reply #22 on: Sun, 04 September 2016, 17:17:30 »
G80-3000 and G80-1800 have the spacebar switch more on the right, this should give more stability when you press it with the left thumb, or with the right?
« Last Edit: Sun, 04 September 2016, 17:19:10 by Giorgio »
Offline Skywalker
  • INFP
« Reply #23 on: Tue, 06 September 2016, 10:44:31 »
If the next word begins with a letter typed by my left hand, I hit the spacebar with my right thumb. And vice versa. I think that was hammered into my head when I was taught to touch-type.
The exception to this rule is when I am capitalizing words: since the next key after the spacebar is shift, I end up hitting the spacebar with (as an example) the left thumb, then hit shift with the right pinky and and then whatever letter with whatever left hand finger. I think I was taught that this is more efficient, but it seems kind of unnecessary now that I am explaining it.
WASD V2 - MX Browns | Topre Realforce 87UB 45g
Offline Niomosy
« Reply #24 on: Tue, 06 September 2016, 17:15:54 »
If gaming, it's going to be exclusively the left hand.  In normal typing, almost entirely the right hand between the B and N keys.
« Reply #25 on: Tue, 06 September 2016, 21:17:22 »
Well,  Referencing my typing speed guide,   right thumb is the way to go for even distribution of keyload..
But it PROBABLY doesn't matter for Maximum speed because all transitions are pre-emptive .. so, you don't really lose much speed..
It may just be a matter of comfort to use right thumb.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #26 on: Tue, 06 September 2016, 21:21:08 »
loooolll.. referencing your own speed guide..the game is strong with this one...this public defender of GH.
« Reply #27 on: Tue, 06 September 2016, 21:33:46 »
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
« Reply #28 on: Thu, 08 September 2016, 14:14:14 »
I just about always use my left thumb.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
Offline Nai_Calus
  • CLACK
« Reply #29 on: Mon, 12 September 2016, 08:27:29 »
Left thumb exclusively, under B slightly to the left.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline yowaffle
« Reply #30 on: Mon, 12 September 2016, 09:01:00 »
right thumb all the way :thumb:
V60 [MQC] | KC60 [Zealiostotles] | Leopold FC660c [Topre] |  Ducky Shine 4 [MX Brown] | MiniVan [Zealios]
Offline jaffers
« Reply #31 on: Mon, 12 September 2016, 09:01:45 »
I don't think I've ever used my spacebar with my left hand
Offline greenteei89
« Reply #32 on: Mon, 26 September 2016, 08:12:07 »
Right thumb when typing and left when gaming.
Offline Parva Ovis
« Reply #33 on: Fri, 30 September 2016, 00:10:44 »
Exclusively left thumb, usually under V, but occasionally as far right as B or as left as between V and C.
Offline kasakka
« Reply #34 on: Sat, 01 October 2016, 13:54:27 »
Same for me. Usually landing somewhere under M key or between C and V when hitting it with my left thumb. I really wish we had more keyboards that supported a split spacebar or one that allows a 1u key between two larger keys. Would give neat options.
Offline Jesse36m3
« Reply #35 on: Mon, 03 October 2016, 10:41:47 »
I've always thought about the double spacebar, that would be neat. I'd imagine it would go down a bit smoother since you wouldn't be applying force to one corner.
Offline doom2
« Reply #36 on: Wed, 05 October 2016, 13:18:45 »
Left! You can clearly see it on my laptop keyboard.  :D :D :D
« Reply #37 on: Wed, 05 October 2016, 15:22:45 »
It's pretty smooth as long as you're on Costar stabilizers.  Cherry stabs are not as smooth.
Offline drudru
« Reply #38 on: Wed, 05 October 2016, 23:40:07 »
Right - I was trained that way in typing class.
Offline PollandAkuma
« Reply #39 on: Fri, 07 October 2016, 19:20:27 »
Right thumb! Way more satisfying than my left IMO.
Offline Grona
« Reply #40 on: Fri, 07 October 2016, 23:55:47 »
Left thumb mostly, even though i'm right handed.
Offline Dyaems
« Reply #41 on: Sat, 08 October 2016, 03:02:25 »
Left thumb, unless right thumb is needed (in some rhythm games)
   B.face X2
  65g Zealios
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #42 on: Sat, 08 October 2016, 03:36:55 »
Left thumb. Probably muscle memory from playing games
« Reply #43 on: Sun, 09 October 2016, 04:04:34 »
Good point!
I use my left thumb when gaming, but (as OP asked) right thumb for typing.
Offline captaineleven
« Reply #44 on: Mon, 10 October 2016, 10:33:03 »
I started out with right thumb for the longest and then I switched to left thumb because why not. But lately with how much more I'm typing, I think I'll switch back to the right so that it evens out the workload.
So fancy!
Offline Hypersphere
« Reply #45 on: Mon, 10 October 2016, 10:41:52 »
About 50:50 left:right. Left between V and B; right directly under N.
BTW, would prefer spacebars to be very small and perhaps split. It would be nice to eliminate the need for spacebar stabilizers. Same goes for all the keys that are now large and stabilized.
Offline benderkey
« Reply #46 on: Mon, 10 October 2016, 10:58:34 »
Right.
You should do a poll.
