Author Topic: Kinesis Advantage2 LF - worst batch of Cherry RED I've ever come across, wtf  (Read 3114 times)
Offline tiger
This is worse than sandy/gritty. More like sea corroded springs and 1 pixel resolution 3D printed grit. Press a key and get a mile of braille feedback - wtf.
I've used Cherry MX Red switches in the past, and none have been this terrible. Anyone else come across such a poor example of quality control ($420 after tax, come on Kinesis. COME ON!)? Or has Cherry switches utterly gone to the dogs?
Offline davkol
  •  Post Editing Timeout
Re: Kinesis Advantage2 LF - worst batch of Cherry RED I've ever come across, wtf
« Reply #1 on: Thu, 01 September 2016, 03:55:07 »
I guess it's worth trying RMA.
Otherwise, the thumb keys were PCB-mounted IIRC, thus you could try to open a switch and check the insides or swap them for something else (e.g., if you have okay-feeling reds lying around).
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Thu, 01 September 2016, 06:08:48 »
typical modern mx, just put clear gaterons in or something.
Offline tiger
« Reply #3 on: Thu, 01 September 2016, 13:19:22 »
Really? So Cherry MX switches are all this bad? Oh man :(
Offline davkol
« Reply #4 on: Thu, 01 September 2016, 13:39:19 »
The gateron circlejerk is strong.
Yes, modern Cherry MX are gritty. Yes, gaterons are usually smoother. However, even gaterons are nowhere near smoothness of vintage blacks or clean linear[ized] complicated Alps, and modern Cherry MX shouldn't be nearly as bad as some cheap clones (early modern Kailh or various crap from the 90s).
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Thu, 01 September 2016, 13:39:37 »
modern mx is pretty much always scratchy to a degree. their older stuff is better, but the quality has dropped. alot of clones are much better alternatives to mx now.
« Reply #6 on: Thu, 01 September 2016, 21:43:56 »
Try another keycap set..
For me , many times the gritti-ness comes from the keycap stem
Offline Screwdriver
« Reply #7 on: Thu, 01 September 2016, 23:13:23 »
My KUL-87 with Reds is pretty damn smooth. No grit at all.
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
