Author Topic: How to dimm a LED?  (Read 6456 times)
Offline Geroximo
How to dimm a LED?
« on: Sat, 03 September 2016, 09:41:11 »
Hi mates,
How do I dimm a LED?
Not a keyboard LED, but a LED which I want to use for ambient light.
I want to use a single LED diode to ambient light my keyboard drawer and power it through USB.
The light should be very dimm.
How can I achieve that?
Just use a stronger Resistor?
Offline Tactile
Re: How to dimm a LED?
« Reply #1 on: Sat, 03 September 2016, 10:05:35 »
To reduce the brightness, you're right - a larger resistor value.
To make it variable brightness requires extra circuitry.
REΛLFORCE
Offline Geroximo
« Reply #2 on: Sat, 03 September 2016, 11:15:07 »
Thank you very much.
« Reply #4 on: Sun, 04 September 2016, 05:12:38 »
It's called PWM
Thank you for making me finally research how PWM actually works :)
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
« Reply #5 on: Wed, 07 September 2016, 17:54:17 »
A simple potentiometer should work. It's a variable resistor, so it will work like a dimmer switch that can change whenever you'd like without changing the circuit.
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
Offline Tactile
« Reply #6 on: Wed, 07 September 2016, 18:36:50 »
Yes, but it should have a resistor in series to ensure that the minimum resistance when the pot is turned down does not go outside the LED specs. I've zapped a few LEDs and I don't like that plastic smell they emit when they fail.  :p
REΛLFORCE
Offline notbrain
« Reply #7 on: Mon, 24 October 2016, 19:20:55 »
If you don't want to go the resistor route, you can also just coat the LED in some transparent black paint. Or a trick from my modeling days is to get some dark nail polish and don't mix it--use the clear dark liquid as paint or mix a small batch of transparent by separating out the color and extra base (clear). You can dim more by adding coats until it's as you like it.
