Author Topic: Revolutionary trick for touch typists !!!  (Read 3351 times)
Offline Geroximo
« on: Sat, 03 September 2016, 18:37:06 »
Hi to all you touch typists out there!
Today I discovered this incredible keyboard hack which changed my life forever.
I just had to share it with you: Enjoy!
Offline ideus
  • Björkö.
Re: Revolutionary trick for touch typists !!!
« Reply #1 on: Sat, 03 September 2016, 18:41:13 »
Off Topic!
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Sat, 03 September 2016, 18:42:35 »
I did not know that Apple users used G and H as their home keys.
Offline xondat
  • i'm not a star
« Reply #3 on: Sat, 03 September 2016, 18:44:54 »
I'll do this to a GMK set just to see whether it works or not
Offline katushkin
  • Just the guy
« Reply #4 on: Sat, 03 September 2016, 18:45:46 »
Better off doing it to a set of OG dyesubs tbf.
Offline Geroximo
« Reply #5 on: Sat, 03 September 2016, 19:05:09 »
I already did this to all of my OG Cherry and GMK sets, because these sets come with scoops instead of homing bars.
It works like a charm and them glue drops feel so much better than the nasty scoops!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Sat, 03 September 2016, 19:17:18 »
They basically used anything but the F and J as home keys over time :p . They had a nub on the right arrow key at some point :p .
« Reply #7 on: Sat, 03 September 2016, 21:57:19 »
I don't home on my keyboard on the bars.
I home by edge detection as I move my way towards the keyboard
As soon as I sense an edge, I instantly know where to travel from there.
Offline ika
« Reply #8 on: Sat, 03 September 2016, 22:23:22 »
I did this to a JTK set and it was perfect. Came right off when I sold it, you couldn't tell it was there.
« Reply #9 on: Sun, 04 September 2016, 05:29:52 »
Because all sentences start with a capital letter, the first key I home in on is left Shift.
Offline WarCommand
« Reply #10 on: Sun, 04 September 2016, 08:37:24 »
Super glue not only works better, but it comes off really easily with a tiny bit of paint thinner.
« Reply #11 on: Sun, 04 September 2016, 09:36:16 »
There are lots of types of paint thinners,  some eat plastic,  so, /Careful
Offline WarCommand
« Reply #12 on: Sun, 04 September 2016, 10:05:40 »
No worries, if it's a lighter cap you can use a sharpie to write the letters back on there
