Author Topic: Concrete Blocks.. Civil Engi-Halp  (Read 1364 times)
« on: Sat, 17 September 2016, 07:38:21 »
Emphasis on Flatness.. Need flatness
Buy premade and drill holes..
Vs....
DIY Cast
Thoughts?
Do ya'll think premade is cast more _flatly_ than DIY.. since they prolly got better molds?
Is it hard to drill concrete without cracking it ?..  does a cast hole work better/ more rigid-ly/ structurally sound than a drilled hole ?
Re: Concrete Blocks.. Civil Engi-Halp
« Reply #1 on: Sat, 17 September 2016, 08:31:59 »
Not much to go on but drilling holes in masonry is no fun.
If you can get pavers in the right size and shape, and you only need a few small holes, drill.
If you know how to cast your own and need many, that will be easier.
- D Trump 2026-10-24
