Author Topic: How many Slices of Cheese  (Read 6985 times)
« on: Mon, 10 October 2016, 18:16:16 »
Have always felt 2 slices is just not enough..   like them double whopper rip-offs @ burgerking
Drawn the line at 5 slices though,  beyond that point, really gums up the sandwich and you can't taste any of the other ingrediants.
Your thoughts ?
Offline Dr_Alphabet
Re: How many Slices of Cheese
« Reply #1 on: Mon, 10 October 2016, 18:33:44 »
This question is very situational.... What kind of sandwich? What kind of cheese? Singles or hand cut? Be more specific, man, geez... I take cheese seriously
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Look at me. Look at me. Look what I can do. I'm amazing - Peter Gabriel
« Reply #2 on: Mon, 10 October 2016, 18:45:58 »
Hrrrrrmmmm..
I suppose the metric is   cheese to bread ratio..
For me it's 5x slices of cheese to 2 slices of white bread..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Mon, 10 October 2016, 18:51:54 »
Two cuts, each cut the size of a domino. Maybe some NY style Cheddar when I can find it :)
Offline Dr_Alphabet
« Reply #4 on: Mon, 10 October 2016, 18:53:56 »
Unless it's a grilled cheese or some kind of melt, 5 is too much. 3 or 4 max, depending on the type of sandwich and cheese. When your stack of cheese is thicker than a slice of the bread your using, it's too much cheese.
« Reply #5 on: Tue, 11 October 2016, 07:10:09 »
If you are heating the sandwich, melted cheese quickly turns into a layer of lubrication that makes the whole thing unmanageable. Cooled down sufficiently afterwards, however, the cheese can be a glue that keeps it together.
- D Trump 2026-10-24
Offline Fictiouz
  • That "White" Guy
« Reply #6 on: Tue, 11 October 2016, 07:15:42 »
I think with burgers a simple 1:1 ratio between patty and cheese is a safe bet. If talking regular sandwich with sliced meat 1:4 or 1:5 ratio between cheese and meat slices is a pretty safe bet. It gets complicated when talking other situations.
« Reply #7 on: Tue, 11 October 2016, 07:58:51 »
And someone complained about having "the dad bod" ...
You use one slice. ONE!
Use good cheese, real cheese with flavour and there is no need to use more.
« Last Edit: Tue, 11 October 2016, 08:01:20 by Findecanor »
« Reply #8 on: Tue, 11 October 2016, 08:46:04 »
Uh oh
The cows onto me..
« Reply #9 on: Wed, 12 October 2016, 04:28:07 »
I have one slice of cheese in each of my two sandwiches for lunch.  That seems enough for me - sometimes I can still taste the cheese over the other fillings.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #10 on: Wed, 12 October 2016, 09:18:01 »
I only go one slice for sandwiches, since that's enough to taste. Any more than that and I'll feel like a fatty.
I'd go 2 slices for grilled cheese, though, especially if I'm doing two types of cheese.
For burgers, none, since I buy them from the local deli with mozzarella and bacon already in the there and it is superb right off the grill.
« Reply #11 on: Wed, 12 October 2016, 12:33:52 »
3 for the sandwich, the rest of the package for snacking while making said sandwich.  No such thing as too much cheese.
« Reply #12 on: Wed, 12 October 2016, 12:35:07 »
Checks out.
Offline mike52787
  • Alps Aficionado
« Reply #13 on: Fri, 14 October 2016, 06:14:24 »
No such thing as too much cheese you say?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Fri, 14 October 2016, 06:16:57 »
It works because McDonald's cheese has clay-like properties
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #15 on: Fri, 14 October 2016, 12:34:54 »
I don't think any of that is actual cheese :p .
« Reply #16 on: Fri, 14 October 2016, 13:20:54 »
I don't think any of that is actual cheese .
Americans sometimes refer to cheese and cheese-like-plastic-substances interchangeably.
Offline Data
« Reply #17 on: Fri, 14 October 2016, 13:56:45 »
I never eat "cheese food" or "cheese product".  Real cheese only.
The number of slices is proportionate to the meat. The mass of the cheese should never be more than roughly half the mass of the meat, and never less than one tenth.  Usually I can get by with 1 slice, but I buy good cheese sliced generously.  If I'm making a Dagwood then I usually double-up.
Offline chyros
  • a.k.a. Thomas
« Reply #18 on: Fri, 14 October 2016, 14:03:56 »
LOL xD
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #19 on: Fri, 14 October 2016, 14:27:20 »
1 - 2 slices on a cold sandwich. 1 per meat patty for burgers
Offline fanpeople
« Reply #20 on: Fri, 14 October 2016, 14:29:33 »
Cheezenips
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #21 on: Fri, 14 October 2016, 14:59:34 »
Cheezenips
#nevarforget #freekirkle2015
Offline YoshiCaps
  • yes, oh god no.
« Reply #22 on: Sun, 23 October 2016, 14:59:55 »
Your thoughts ?
a lot xD
hi.
Offline Elth
« Reply #24 on: Sun, 23 October 2016, 19:17:56 »
Depends what I'm putting said cheese on.
Grilled cheese sandwich = at least 3
Regular sandwich = 2
Hamburger = 2
