Author Topic: Key to Internet  (Read 4095 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Key to Internet
« on: Sat, 15 October 2016, 10:18:14 »
Bam. Internet button. What is going on with the rest of this keyboard? :'(
Offline alienman82
Re: Key to Internet
« Reply #1 on: Sat, 15 October 2016, 10:19:58 »
removed.
« Last Edit: Thu, 01 March 2018, 13:56:36 by alienman82 »
Re: Key to Internet
« Reply #2 on: Sat, 15 October 2016, 10:38:57 »
Perfect timing..
Tp4 in the basement this weekend..
Playing with old computers
This is my all Beige setup
150478-0
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Key to Internet
« Reply #3 on: Sat, 15 October 2016, 10:41:55 »
Perfect timing..
I'm looking for an internet button but I don't sees one. You need an internet button :-*
Re: Key to Internet
« Reply #4 on: Sat, 15 October 2016, 10:48:15 »
Perfect timing..
the only keyboard i have with an internet button is a wireless logitech..
I can't use that keyboard on this pc, because this pc is a work pc, and I need to minimize the installed software as to not increase latency.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Key to Internet
« Reply #5 on: Sat, 15 October 2016, 11:00:38 »
Perfect timing..
Working from the patio?
Re: Key to Internet
« Reply #6 on: Sat, 15 October 2016, 11:15:29 »
Perfect timing..
patio furniture in basement..
I used to have a serious shopping problem.. too much stuff
Offline fanpeople
Re: Key to Internet
« Reply #7 on: Sat, 15 October 2016, 11:44:54 »
Patio furniture? Really? Really? You binge bought patio furniture.
I guess i really want to know? Do you even have a patio? Was it ever outside? I thought tp didn't go outside so why would it need outside furniture?
Re: Key to Internet
« Reply #8 on: Sat, 15 October 2016, 11:53:30 »
for a while, I was excited about using a patio tent, so it's like a patio, but inside..
Buhhhh.... after a while, i was like.. tp4 overheating.. requires AC
So... I've discontinued that nonsense..
Offline fanpeople
Re: Key to Internet
« Reply #9 on: Sat, 15 October 2016, 11:55:41 »
Well that explains everything.
Re: Key to Internet
« Reply #10 on: Sun, 16 October 2016, 23:43:11 »
What's the oldest computer ya'll still using..
I still use my P4 3ghz.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Key to Internet
« Reply #11 on: Mon, 17 October 2016, 03:48:20 »
Core 2 Duo 2.4ghz :eek: Rocket speed
Re: Key to Internet
« Reply #12 on: Mon, 17 October 2016, 10:41:56 »
That's basically a 1.9ghz sandy bridge,
Which is actually the speed found in many of the --budget lappies-- today..  (2016)..  hahahahahhaha
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Key to Internet
« Reply #13 on: Mon, 17 October 2016, 12:22:03 »
My cpu has ZERO THREADS so like, it would probably average to about 0ghz sandy bridge. ARM processors can outpace my Core 2 Duo :)). When I bought this computer I wanted something to play a bit of WoW and watch some movies/tv. Little did I know I would be rendering CGI stills with the damn thing. I still have my i5-560m from my old lappy. Too bad I can't use it :'(
What's up with the beige box? Still lining up the red strip on the ribbon cables or what?
I forget which direction it was supposed to go. I think the red strip is supposed to be towards the 4pin molex? My recall of those days is a bit fuzzy. When I first started to build my older bro made a big deal about it. Then, a few years later, it didn't matter because they only went in one way? Once again, my Netzero days. Lots of cheetos. zero f's
Re: Key to Internet
« Reply #14 on: Mon, 17 October 2016, 22:08:38 »
hahaha
red strip was a long time ago..
And, manufacturers don't label things uniformly these days..
The other day,  I was opening up two different compressors,   one had positive labeled with dashed lines,  the other had negative labeled with dashed lines..
Re: Key to Internet
« Reply #15 on: Mon, 17 October 2016, 22:34:27 »
Ahh yes, the oft forgotten but integral 'Shopping' button. And the power to finance with a single click? Amazing.
Re: Key to Internet
« Reply #16 on: Sat, 22 October 2016, 02:07:23 »
You know.. 1024 x768 resolution on the CRT is ideal for WMO..
This must've been the designed resolution for use..   Simply PERFECTION.
Re: Key to Internet
« Reply #17 on: Sat, 22 October 2016, 05:31:04 »
I've got a P4 3GHz that I was using a while back, but my main machine has a 2.26GHz Core 2 Due.  My secondary machine has a 2.93GHz Core 2 Duo.
Re: Key to Internet
« Reply #18 on: Sat, 22 October 2016, 12:05:08 »
ddr... 6GB/s   pretty ok for win xp..   vs 30GB/s on the new computers.
Offline YoshiCaps
  • yes, oh god no.
Re: Key to Internet
« Reply #19 on: Sat, 22 October 2016, 12:27:48 »
I have an old compaq persario membrane with internet keys.
hi.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Key to Internet
« Reply #20 on: Sat, 22 October 2016, 12:49:08 »
That keyboard pic on the top page is definitely not mine. Some kind adventurer left it somewhere on the internet for google to find.
Offline YoshiCaps
  • yes, oh god no.
Re: Key to Internet
« Reply #21 on: Sat, 22 October 2016, 12:49:48 »
it looks like two boards......
hi.
