Author Topic: Flooring Halp.. !! (any Geekhack Flooring xperts out there)  (Read 2398 times)
« on: Mon, 24 October 2016, 13:04:16 »
Hi Flooring gurus..
Doing up the basement..
Tp4 haz old carpet glue,  it's the yellow stuff, (not black stuff), single layer, ~1mm thick
Can I put down epoxy flooring right over it ?
I know in the garage, you need to get a really prepped surface because heavy cars will be rubbing on it,
But this is the basement,  will the epoxy work ok without resurfacing the concrete / removing the old carpet glue ?
The glue has already dried, it's non tacky..
Offline alienman82
Re: Flooring Halp.. !! (any Geekhack Flooring xperts out there)
« Reply #1 on: Mon, 24 October 2016, 14:48:55 »
removed.
« Last Edit: Thu, 01 March 2018, 13:52:08 by alienman82 »
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #2 on: Mon, 24 October 2016, 15:16:03 »
I would strongly recommend removing the glue. It can usually be removed easily with a 4" or larger razor scraper, like the ones used for removing wallpaper. Then follow up with an acid wash or whatever the manufacturer recommends.
 Another concern is that, being in a basement, you may have a problem with hydrostatic pressure eventually causing the epoxy's adhesion to the concrete to fail. It might her a good idea to test for slab moisture by taping down a 2'x2' piece of plastic for 48 hours. If it is dry underneath when you remove it, you should be good .
« Reply #3 on: Mon, 24 October 2016, 19:11:38 »
Um... well the foundation has drain tiles and a sump pump so.. I think i'm good on water..
I'm just really lazy...  but it seems like I may have to go rent that concrete prep tool from home depot..
sigh...................................................
I'm never gonna save enuff bux for a gtx 1080
« Reply #4 on: Mon, 24 October 2016, 20:19:05 »
You misspelled the word 'help' in your post title.
Offline kurplop
« Reply #5 on: Mon, 24 October 2016, 20:27:01 »
You may well have success without thorough prep. When I'm hired to do things like that, I can't afford to have a failure. Because of that I have to assume the worst.
Two things that may happen are poor adhesion and the  telegraphing of any bumps or ridges from the existing adhesive.
« Reply #6 on: Mon, 24 October 2016, 20:54:03 »
you haz pm...
Offline kurplop
« Reply #8 on: Mon, 24 October 2016, 23:02:26 »
kurplop, why u no respond to PM...
Just got back online. PM answered.
