Author Topic: hard storage for boards  (Read 11325 times)
Offline alienman82
« on: Tue, 08 November 2016, 10:19:15 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:37 by alienman82 »
Offline R1N3
Re: hard storage for boards
« Reply #1 on: Tue, 08 November 2016, 10:22:52 »
Pelican™ when you need to transport anything you care about that could possibly break.
Offline 1391406
« Reply #2 on: Tue, 08 November 2016, 10:36:32 »
Link?
Offline R1N3
« Reply #3 on: Tue, 08 November 2016, 10:38:39 »
Link?
http://www.pelican.com/us/en/
Offline alienman82
« Reply #4 on: Tue, 08 November 2016, 10:48:50 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:35 by alienman82 »
Offline R1N3
« Reply #5 on: Tue, 08 November 2016, 10:54:00 »
Link?
I was thinking something cheaper and smaller, but I'll consider this
Up front it's definitely a hard hit to your wallet. You'll have it for the rest of your living life though, and then your children's children's children will still be using them.
Offline 1391406
« Reply #6 on: Tue, 08 November 2016, 11:42:44 »
I found these on Aliexpress.
Offline 1391406
« Reply #7 on: Tue, 08 November 2016, 11:45:05 »
And these.
Offline 1391406
« Reply #8 on: Tue, 08 November 2016, 11:49:44 »
Offline alienman82
« Reply #9 on: Tue, 08 November 2016, 11:53:34 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:26 by alienman82 »
Offline alienman82
« Reply #10 on: Tue, 08 November 2016, 11:55:14 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:25 by alienman82 »
Offline hurst
« Reply #11 on: Tue, 08 November 2016, 14:45:45 »
Poker chip case.
Offline alienman82
« Reply #12 on: Tue, 08 November 2016, 14:57:12 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:15 by alienman82 »
Offline ReverbSlush
  • 16/52 RNG score
« Reply #13 on: Tue, 08 November 2016, 15:06:15 »
Probably mentioned before but firearm cases can be a good fit.  I have a soft shell gun case that is perfect for a TKL... I picked it up from a garage sale for a few bucks.
Edit: I know you want hard shell :)  Just thought I would suggest another avenue for discovery.
« Reply #14 on: Tue, 08 November 2016, 15:15:43 »
CNC foam ftw....
ALTHOUGH it's probably unnecessary, since the majority of what people collect is just junk.. hahahahahah
not in Alienman's case,  since he actually has worthwhile stuff..  but --most people---
« Reply #15 on: Tue, 08 November 2016, 15:38:38 »
« Reply #16 on: Tue, 08 November 2016, 15:44:06 »
https://geekhack.org/index.php?topic=34960.0
wouldn't this not be good for the keys because it may depress them over time, in long term storage causing odd spring tension issues ?
Offline alienman82
« Reply #17 on: Tue, 08 November 2016, 16:13:49 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:10 by alienman82 »
Offline pr0ximity
« Reply #18 on: Tue, 08 November 2016, 16:41:08 »
$100 is a fair price to pay to protect a $1k kustom :P
I was lucky enough to get one of the OTD ones and can confirm they're quite nice if you're able to find one second-hand. I only have the one but would love another.
Offline alienman82
« Reply #19 on: Tue, 08 November 2016, 16:43:16 »
removed.
« Last Edit: Thu, 01 March 2018, 13:43:08 by alienman82 »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #20 on: Tue, 08 November 2016, 16:53:15 »
I have one of those hardshell cases. Not really using it right now since my only TKL is in use, but I would love one for a 60% or 1800 keyboard.
I'll probably ask these guys on eBay since they seem to have a lot of specialised cases. Perhaps they can make us one. :P
|||My other keyboards :
x
Offline Data
« Reply #21 on: Thu, 10 November 2016, 07:33:18 »
I took some measurements and figured I could fit 3 TKL-size boards in a Pelican 1500 case.  Great for travel.
Offline alienman82
« Reply #22 on: Mon, 14 November 2016, 18:20:10 »
removed.
« Last Edit: Thu, 01 March 2018, 13:40:04 by alienman82 »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #23 on: Mon, 14 November 2016, 20:44:05 »
That's a nice case man. Which peli did you go for?
Offline alienman82
« Reply #24 on: Mon, 14 November 2016, 20:49:59 »
removed.
« Last Edit: Thu, 01 March 2018, 13:39:56 by alienman82 »
Offline katushkin
  • Just the guy
« Reply #25 on: Mon, 14 November 2016, 21:08:04 »
Ahhhh sweet. I was looking at that or the 1500. In the mean time I will just use my suitcase  :))
Offline alienman82
« Reply #26 on: Mon, 14 November 2016, 21:15:54 »
removed.
« Last Edit: Thu, 01 March 2018, 13:39:54 by alienman82 »
Offline loud_asian
« Reply #27 on: Tue, 15 November 2016, 00:43:12 »
How easily were you able to form the foam around your keyboard?
I'm thinking about picking up a 1550 and cramming like 4 60% boards inside
Offline alienman82
« Reply #28 on: Tue, 15 November 2016, 08:17:55 »
removed.
« Last Edit: Thu, 01 March 2018, 13:39:49 by alienman82 »
Offline jcoffin1981
« Reply #29 on: Tue, 15 November 2016, 19:39:43 »
Very nice case, though probably overkill.  I actually keep most of the original packaging from electronics and hardware.  It increases resale value, and it also works great when you need to move.
On my PC I have probably a 3lb heatsink and a super large case tower.  I have all the original boxes, bags, styrofoam, etc and can stick it back in these when I move.  Better than trusting the movers.
Offline alienman82
« Reply #30 on: Tue, 15 November 2016, 19:40:56 »
removed.
« Last Edit: Thu, 01 March 2018, 13:39:31 by alienman82 »
