Author Topic: Any recommendations for a monitor arm + sit/stand keyboard tray?  (Read 6217 times)
Offline hoggy
  • * Moderator
« on: Fri, 11 November 2016, 02:30:28 »
My current solution is getting pretty tired.
I've come across this monitor arm
https://www.amazon.co.uk/Ergotech-Freedom-Arm-PC-Silver/dp/B00CEHME92
I'm also looking at the 3M sit/stand tray, but under the desk there's a metal bar in the way of the track - giving me around 11 inches of room and 3M's tray seems to need 20 odd inches of room.
Any suggestions, please?
Offline AMongoose
  • happy workman user
Re: Any recommendations for a monitor arm + sit/stand keyboard tray?
« Reply #1 on: Fri, 11 November 2016, 05:44:59 »
I got a duronic DM651X2 because it was a lot cheaper than the ergotech one and it works great.
Offline Damonskv
« Reply #2 on: Fri, 11 November 2016, 06:38:45 »
Try to look at the solutions offered by the company http://www.lcdarms.com .A few years ago, I had a very specific task - choose lcd arm for a 27 inch iMac ))), find this company, in the end happily use their product for more than 5 years. I think they have a solution for any problem, sizes, types of mounts.
Offline chuckdee
« Reply #3 on: Fri, 11 November 2016, 08:35:43 »
There's a drop going on that I've been considering on massdrop: https://www.massdrop.com/buy/ergotech-sit-stand-freedom-desk?mode=guest_open
It's a pretty big spend, but it really looks good.  It's also ERGOTECH like the one in the OP.
Offline Phenix
« Reply #4 on: Sat, 03 December 2016, 17:07:21 »
the company Ergotron makes such stuff.
For europe its easier to buy from them, I have an ergotron LX monitor arm and love it
Winter is coming.
Offline hoggy
  • * Moderator
« Reply #5 on: Wed, 07 December 2016, 11:27:13 »
