Author Topic: /sigh................  (Read 5201 times)
« on: Fri, 18 November 2016, 23:45:37 »
Made the popcorn..
Checked fridge..  No butter..
Re: /sigh................
« Reply #1 on: Fri, 18 November 2016, 23:50:37 »
ugh.......
dry poipcron..
bleccch..
Offline fanpeople
« Reply #2 on: Sat, 19 November 2016, 00:07:50 »
Just so you know, i got sooooo much butter
« Reply #3 on: Sat, 19 November 2016, 00:15:00 »
how have you come across such luxury....
Tp4 not rich like -fanpeople-
Offline fanpeople
« Reply #4 on: Sat, 19 November 2016, 00:26:13 »
Fanpeople not rich, he just does not consume butter at a rate that is unsustainable.
« Reply #5 on: Sat, 19 November 2016, 00:30:15 »
I do not eat too much butter..
I do not have a problem..
are u calling me fat..
Tp4 just fluffy..
Offline fanpeople
« Reply #6 on: Sat, 19 November 2016, 00:38:34 »
Tp4 just fluffy..
Offline ANightOnCloudNine
« Reply #7 on: Sat, 19 November 2016, 01:34:46 »
tp4 i think you're just fat sorry
« Reply #8 on: Sat, 19 November 2016, 01:36:39 »
although im a total hypocrite cause i just ate half of a medium pizza
« Reply #10 on: Sat, 19 November 2016, 02:45:16 »
why don't you just get buttered popcorn?
« Reply #11 on: Sat, 19 November 2016, 03:30:05 »
It no haz the real butter..
« Reply #12 on: Sat, 19 November 2016, 13:28:22 »
got more butter at de'costco..
Ohyea..
clarifying in the pan...  soooooonnn..
« Reply #13 on: Sat, 19 November 2016, 14:54:31 »
Uhhhh wtf are you talking about. 90% of the microwave butter popcorn says right on the box 'Made with real butter'
Just don't get the Movie Theater Style. In fact I seem to remember a law passing years ago forcing microwaveable popcorn to use real non-trans butter and change the lining material of their bags.
« Reply #14 on: Sat, 19 November 2016, 14:58:23 »
I don't think they use the real stuff.. probably 1 drop of real + the rest of 2 tablespoons of soybean oil
If they do ,  it's not enoug..'
Tp4 requires at least heart atk level 9 butter.
Offline fanpeople
« Reply #15 on: Sat, 19 November 2016, 15:23:35 »
Look at it this way tp, if you had done what turtle man suggested but before this point in time, at least you would have some form of butter flavor on your corn. If you had stuck to tp logic which you did, that pre lubed popcorn does not have real or not enough butter, it does not hold as YOU HAVE NO BUTTER ANYWAY SO YOU HAVE PLAIN OLD POP CORN.
« Reply #16 on: Sat, 19 November 2016, 15:33:13 »
The box I haz says made with real butter on it..  But you eat it, and there's clearly NO BUTTER...
« Reply #17 on: Sat, 19 November 2016, 15:38:15 »
add pepper to the popcorn, not too much tho.
« Reply #18 on: Sat, 19 November 2016, 15:39:02 »
Hrrrrm.. never tried this before..
will do.. now..
Offline fanpeople
« Reply #19 on: Sat, 19 November 2016, 15:40:48 »
The  write to your local member of parliment demanding an inquiry into their false advertising
« Reply #20 on: Sat, 19 November 2016, 16:23:50 »
you could use nut butter...
Offline YoshiCaps
  • yes, oh god no.
« Reply #21 on: Thu, 24 November 2016, 09:48:37 »
ugh.......
dry poipcron..
bleccch..
hi.
Offline DanielT
« Reply #22 on: Thu, 24 November 2016, 09:55:46 »
But do you have salt? If you don't I have enough to go around :p
Offline YoshiCaps
  • yes, oh god no.
« Reply #23 on: Thu, 24 November 2016, 09:59:43 »
Garlic or celery salt will do nicley, not just nacl.
hi.
Offline YoshiCaps
  • yes, oh god no.
« Reply #24 on: Thu, 24 November 2016, 17:24:49 »
Tp4 just fluffy..
I'm somewere between my 10000000 pound lyfe and a plank length thin.
hi.
« Reply #25 on: Fri, 25 November 2016, 01:40:47 »
update on the pepper? how you like it?
« Reply #26 on: Fri, 25 November 2016, 01:48:59 »
didn't work..
at first I sneezed,  then I kinda choked and coughed.
« Reply #27 on: Fri, 25 November 2016, 02:03:40 »
didn't work..
probably not the best idea when you have a cold, try again when you dont have one and see how you like it,
Offline Blackehart
« Reply #28 on: Wed, 30 November 2016, 15:10:34 »
Oh TP,
Butter is for peons!
Valentina hot sauce is where it's at!
^_^
Offline atarione
« Reply #29 on: Wed, 30 November 2016, 17:23:51 »
I worked at a movie theater in High School... true fact I can't stand popcorn to this day..  if you want to never want to see popcorn again get a job at a movie theater.
