Author Topic: How Cherry has fallen  (Read 6505 times)
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« on: Sat, 03 December 2016, 23:49:09 »
I'm going to leave the analysis to the readers. But really, Cherry, you were so. damn. good. at linear switches.
This is what we have now for MX Black switches. Notice how it's a bit different. Perhaps this is enough to convince everyone that there really is a difference between older and newer MX Black switches.
But that's not what this post is about. Take a look, this is a NIB Cherry MX Red RGB switch.
What's going on in Cherry's factories?
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline HaaTa
  • Kiibohds!
Re: How Cherry has fallen
« Reply #1 on: Sat, 03 December 2016, 23:49:25 »
Here's a NIB standard Cherry MX Red for comparison.
Kiibohd
Offline Mattr567
« Reply #2 on: Sun, 04 December 2016, 00:29:50 »
The graph's are really telling. The bar/standards are much lower now since mechanical keyboards aren't the norm and competition is extremely low. Gamer's don't care, they can put out crap and no one bat's an eye. Or maybe it's something to do with their QA or machinery. Besides the well-known material change, but I think it is unlikely that material is the only factor.
How does something like Alps SKCL Green compare graph wise?
IBM P77, SKCC Green, 1984
Offline HaaTa
  • Kiibohds!
« Reply #3 on: Sun, 04 December 2016, 00:37:08 »
I'm working on measuring some Alps switches, should be ready in the next day or so.
Kiibohd
Offline ika
« Reply #4 on: Sun, 04 December 2016, 00:37:32 »
How does a Gateron or Zealios switch look in comparison? I'm guessing the "jaggies" are artifacts of roughness in the plastic/friction.
Offline HaaTa
  • Kiibohds!
« Reply #5 on: Sun, 04 December 2016, 00:43:57 »
Also, for those not aware, the force curves are sorted.
Gateron
Zealios
All
Still need to measure more though.
Kiibohd
Offline supamesican
« Reply #6 on: Mon, 05 December 2016, 07:57:20 »
They started focusing on gamer boards, which always prioritize flashy over quality. As such they went from THE company for linear switches to the bottom of the barrel just barely above dell pack in keyboards. They are one of the main reasons even on my custom gaming pcs I never buy gaming branded stuff, been burned before, not again.
« Reply #7 on: Mon, 05 December 2016, 08:56:00 »
A little discussion of methodology would help.  Is this a single press?  Are you measuring a statistically significant population or just a single switch?  How well used is the vintage switch or is it NIB?
« Reply #8 on: Mon, 05 December 2016, 10:17:18 »
This has nothing to do with quality control.
They probably just made the stem slightly thinner because that makes the travel feel smoother out of the box. having less contact with the slide housing.
Actuation and release point does NOT have to be together,  this has never affected the realistic use case of the switches..
Offline daerid
    • Rossipedia
« Reply #9 on: Mon, 05 December 2016, 10:20:12 »
I gotta go with tp here. Vintage blacks have had years and years for the places where the plastic parts touch to wear down super smooth. I wouldn't be surprised if the "new" cherry switches end up having a graph much like the first after a few decades.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Mon, 05 December 2016, 10:31:37 »
People have reported the same thing with unused vintage black keyboards. That said, it might be interesting to compare with this machine.
I guess this is one of the great keyboard mysteries, like the Alps lubricant xD .
Offline supamesican
« Reply #11 on: Mon, 05 December 2016, 12:14:13 »
Dont even get me started on alps lube... I dont get it but it works.
Offline jcoffin1981
« Reply #12 on: Mon, 05 December 2016, 13:00:13 »
I have a couple questions.
1. What is the difference between a Cherry Red and a Cherry Red RGB?  I thought they were the same switch simply with multicolor lights.  The RGBs seem to be stiffer and the standard Reds have a much higher actuation point.
2.  This is probably for the OP HaaTa-  I read your posing about the building of your machine to get these force curves.  How do you simulate an actual keystroke?  How hard and fast (or slow) the stroke is will affect the measurements.  Some people type kind of softly and kind of float the strokes like me (cant stand the clacking sound) and others like to slam the keys down and bottom out.  This also subjectively changes the feel as well.
3. Is there any switch with which you found unacceptable variance?
Offline cicada
  • Formerly iamacicada
« Reply #13 on: Mon, 05 December 2016, 13:14:39 »
Would be great if you guys could educate me on this xD.
« Last Edit: Mon, 05 December 2016, 13:16:56 by iamacicada »
Offline HaaTa
  • Kiibohds!
« Reply #14 on: Mon, 05 December 2016, 13:19:20 »
Top housing plastic is clear (probably polycarbonate, which is a rougher plastic). The bottom housing is this sort of translucent plastic, looks similar to some Gateron switches (pretty sure this is where all the friction is coming from).
It's a motor that moves at a constant rate. I can't move it that quickly or I risk the machine destroying itself every time bottom out is detected (it's a very strong motor with a smooth screw drive). I agree, speed will affect things like friction, but what you notice at high speed are the larger events (e.g. tactile point, bottom out) rather than this bumpiness. There's also more data for your brain to process more quickly when typing fast, so you might just be subconsciously throwing that information away while trying to figure out what to type next.
This also poses the question, "Do you have to type fast for you keyboard to feel good?".
Hmm, I don't really have a large enough sample size to answer this question. I do make sure each switch feels like it's supposed to before making measurements (i.e. trying a bunch of them, choosing one that feels the most similar across all the switches). I don't want to choose one that's broken or damaged because I'm not keyboard switch quality control. I'm trying to provide the community with characteristic force curves that they can compare with other switches.
Kiibohd
Offline Urbi
« Reply #15 on: Thu, 08 December 2016, 14:48:12 »
So are there more versions of "vintage blacks"?
I e.g. have a little bit more than two dozens Raptor Gaming K1 (Cherry G80-1800). All but one have Cherry MX Blacks and all but one were bought in 2012. But they were produced in different years (probably 2005-2011) and I feel distinctive differences between older keyboards (2005-2008 maybe) and newer (2010-2011?). The newer ones feel kinda scratchy in comparison.
Offline invariance
  • ...here with all the other boson's
« Reply #16 on: Mon, 12 December 2016, 07:36:40 »
What would also be interesting is if the same switches could be tested every say 1M actuations to see what difference there is over time.
Of course this would require some rig to perform accelerated key presses, unless someone is up for the challenge.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline n0rvig
« Reply #17 on: Mon, 12 December 2016, 15:49:43 »
Whoa?! What magic is this! Awesome!
Also, Vintage blacks are not Used blacks. There's more to them than just wear & tear. They are more stable and appear to have a tiny amount of lubricant on them.
« Last Edit: Mon, 12 December 2016, 16:48:53 by n0rvig »
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #18 on: Tue, 13 December 2016, 04:42:55 »
How about brand new vintage blacks being super smooth out of the box?
I also have modern MX Reds that went through hell and back (used by a person like me for 5 years) and they're still scratchy like a sandpaper compared to old switches, so it must be something else than just use that makes vintage blacks smooth.
