Author Topic: Need some Swedish help  (Read 2744 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« on: Wed, 14 December 2016, 08:40:06 »
Hey guys,
I need some help with a Swedish website (inb4 use Google translate) because it seems to be the only paracord vendor on the entire internet that sells paracord anywhere near the Dolch brand colour.
Here is the colour and website in question: http://hollydesign.se/butiken/paracord/paracord-fallskarmslina-light-sea-green/
My problem is when I go to check out all the stuff is in Swedish and it won't translate. I also think I may need a Swedish proxy as I can't work out if they do international shipping.
If someone could help me out that would be awesome. I don't actually know how much I would need, maybe like 10 metres?
Offline soilheart
Re: Need some Swedish help
« Reply #1 on: Wed, 14 December 2016, 09:03:59 »
Sounds weird that that is the only place where that color is available...
Anyway, send me a PM and I'll look into it when I get home on a few hours.
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline katushkin
  • Just the guy
« Reply #2 on: Wed, 14 December 2016, 09:10:46 »
Thanks dude!
« Reply #3 on: Wed, 14 December 2016, 09:25:18 »
Hrrrmm...  well ok...  but it might look different than the PC color once you get it...
Offline katushkin
  • Just the guy
« Reply #4 on: Wed, 14 December 2016, 09:27:11 »
That's the issue I have been having with paracord colours so far. I have bought about seven or eight different colours in the hope that they are the Dolch colour but to no avail.
« Reply #5 on: Wed, 14 December 2016, 09:58:37 »
8 is a lucky number..  if you're a sifo..
« Reply #6 on: Wed, 14 December 2016, 17:41:25 »
That is most likely a stock image they got from the manufacturer, so I did a Google image search pasting the image's URL and found which other sites have the same image. There wasn't much, but I did find these:
http://abaloriumsantander.com/cordinocordon-escalada/2496-cordino-color-turquesa-multicolor-4mm-n%C3%BAcleo-extraible.html
http://www.koralkykomponenty.cz/cs/paracord-padakova-snura/27548-paracord-c30-4mm.html
Anyway, I could buy it for you and compare to my real Dolch. While the cord itself costs peanuts, be prepared that it might cost a bit in shipping though.
Offline katushkin
  • Just the guy
« Reply #7 on: Wed, 14 December 2016, 19:36:23 »
Fantastic, thanks for that extra search. If soilheart is unable to proxy some for me in the new year then I will come to you to ask for your help definitely :) He's worked out the pricing for me and it should only be about 75SEK all told so not bad at all :)
Unfortunately, I am not. Now I have no idea what I'm going to do with all this ****ing paracord...
