Author Topic: Internet is down  (Read 4428 times)
Offline fanpeople
Internet is down
« on: Thu, 15 December 2016, 22:47:32 »
So first day of holidays, come home from work and internet is kill. Call Telstra, they say it will be fixed between now and Monday.
So.... what should i do, already mowed the lawn and currently sitting at computer watching memtest do its thing.
Suggestions? No booze, too lazy to drive to the shop.
Re: Internet is down
« Reply #1 on: Thu, 15 December 2016, 22:51:25 »
Find female...
Speak good...
Win prize... !!
Offline fanpeople
« Reply #2 on: Thu, 15 December 2016, 22:52:57 »
Find female...
Speak good...
Win prize... !!
Negative, wifes at work. Anything else
« Reply #3 on: Thu, 15 December 2016, 22:55:50 »
Find female...
Speak good...
Win prize... !!
Why not ?
Plan 2.0..
Call Side-Girl
Win Prize..
Offline fanpeople
« Reply #4 on: Thu, 15 December 2016, 23:04:04 »
Nah, going to clean car instead
« Reply #5 on: Thu, 15 December 2016, 23:06:29 »
Good plan..
Clean car..
Go to Side Girl's house..
Have her make sandwich..
Win prize..
Offline fanpeople
« Reply #6 on: Thu, 15 December 2016, 23:12:18 »
Good plan..
Clean car..
Win prize..
Actually considering taking a dremel to my computer case. Not sure why,  would weight reduction make it go faster?
« Reply #7 on: Thu, 15 December 2016, 23:14:02 »
Good plan..
Clean car..
Win prize..
mmm.... they're usually riveted.. prolly could just drill out the panel..
I've always had trouble getting good edges with the dremel when making inside cuts.
Offline fanpeople
« Reply #8 on: Thu, 15 December 2016, 23:19:06 »
Good plan..
Clean car..
Win prize..
The case is like a 60 dollar cooler master 300 something that i have had since 2010. Want caselabs but but not want wait 10 weeks
« Reply #9 on: Thu, 15 December 2016, 23:27:34 »
We got the Antec p280s here a while back for $40 each..   so  I've got bunch of those for all my pcs..
I like the large cases, because I hate trying to squeeze wires somewhere or cut my hands in a tight space..
Offline fanpeople
« Reply #10 on: Thu, 15 December 2016, 23:30:32 »
Yeah i kinda want something compact, the large case appeal has started to wear off for me. Although id probebly get something like the bullet and then throw it through a window when something doesnt fit.
Offline fanpeople
« Reply #11 on: Thu, 15 December 2016, 23:35:22 »
Ok so my exhaust fan is at the rear but my cooler is angled with fins facing towards the top. Do you think it would be better for cooling to put exhaust fan at top as opposed to rear. Pic for visual
155506-0
« Reply #12 on: Fri, 16 December 2016, 00:49:16 »
No. you want to cover it up if anything..
Because dust settles downwards.
Offline fanpeople
« Reply #13 on: Fri, 16 December 2016, 01:26:21 »
What if i put vomputer on its side. Ps just went shopping
« Reply #14 on: Fri, 16 December 2016, 01:29:21 »
well...... if you're gonna change orientation.. Up side down is best because the vapor chamber for the gpu works better in that orientation..  and those top vents are covered.
Offline fanpeople
« Reply #15 on: Fri, 16 December 2016, 01:57:27 »
What if i get drunk and then do some case modding with all the computer **** still inside. Ps ive been drinking
« Reply #16 on: Fri, 16 December 2016, 02:12:41 »
// Looks to the corner closet where you hide your burner side-girl fone //
Offline fanpeople
« Reply #17 on: Fri, 16 December 2016, 03:11:09 »
dam it tp, do you want me to lose half my superanuation
« Reply #18 on: Fri, 16 December 2016, 10:30:31 »
Few times I've been around that track
So it's not just gonna happen like that
'Cause I ain't no hollaback girl
