Author Topic: [Help] I think my white fox has a broken diode...how do I fix it?  (Read 4192 times)
Offline wngmv
  • Praise the sun!
« on: Thu, 22 December 2016, 13:43:56 »
Picture, bottom right corner. It corresponds to the left control key. I didn't notice that until I finished (my first ever) soldering project. Is there a way to fix this? I'm really disappointed with this...
Offline Tactile
Re: [Help] I think my white fox has a broken diode...how do I fix it?
« Reply #1 on: Thu, 22 December 2016, 14:09:26 »
It's fixable but it'll take soldering skill. If you don't want to try installing an SMD diode you can just add any diode & solder the leads to the pads like this:
155925-0
REΛLFORCE
Offline wngmv
  • Praise the sun!
« Reply #2 on: Thu, 22 December 2016, 14:33:04 »
Thanks. I am very new to soldering AND English isn't my first language....Can you explain why SMD diode is more difficult to solder, and if I don't want to do that, what kind of diode should I buy? I really appreciate that. I'm not sure what does the diode do, and from my reading it has something to do with NKRO, and consider this is the ctrl key just regular diode wouldn't have problem with multiple keys being pressed?
I really appreciate your help.
Offline Tactile
« Reply #3 on: Thu, 22 December 2016, 14:47:52 »
REΛLFORCE
Offline Tactile
« Reply #4 on: Thu, 22 December 2016, 14:54:07 »
If you don't want to do that a 1N4148 diode will work fine in that spot.
REΛLFORCE
Offline wngmv
  • Praise the sun!
« Reply #5 on: Thu, 22 December 2016, 15:05:51 »
Just notice the trace got pulled with it to..
« Reply #6 on: Thu, 22 December 2016, 19:06:36 »
Looks like you're not using the ISO key next to left shift so you could take D48 off and use that, you will have to scratch some of the coating off along the trace at the top where the pad has lifted.
The easier fix would be to get a 1n4148 diode as tactile said. You can solder it between the pad under the S62 label and the top of D63, with the bar on the diode facing away from the switch.
« Reply #7 on: Thu, 22 December 2016, 20:53:33 »
take a knife,  follow the trace on both sides,  scratch it lightly until you expose some copper.. solder to the copper.
Offline Dyaems
« Reply #8 on: Fri, 23 December 2016, 02:46:17 »
whitefox is fully programmable, right? if it is, and if you have a key on the pcb that is unused, you can do similar thing to what i did on a PS2AVRGB PCB:
and reprogram that "unused" key to Lctrl. The F key has a switch mounted, and the other one does not have any keys on it, i just soldered the wire to the solder pad.
HTH
« Last Edit: Fri, 23 December 2016, 02:48:36 by Dyaems »
   B.face X2
  65g Zealios
« Reply #9 on: Fri, 23 December 2016, 02:56:47 »
HTH
This will work but you need to isolate the non-damaged pin or that key will be connected to two columns - looks like you removed the solder from the broken switch and managed this?
If wngmv has a solder sucker it's an option, good thinking :thumb:
« Reply #10 on: Fri, 23 December 2016, 05:22:05 »
HTH
Hrrrmm when jumping to another key,  you'd probably want to slice up the traces from the solder holes, because you need that solder to hold the switch firmly.
Offline Dyaems
« Reply #11 on: Fri, 23 December 2016, 21:22:46 »
the F key does not work whatsoever, i was guessing the diode was broken because it was not working even if i short the solder holes with a tweezer. the one on the pic was not finished, hoping OP will get the idea.
i didn't think of this although the traces are really hard to see, so i came up with the one on the picture. it was not done when i took a picture, i soldered the switch "as usual" along with the wire so that the switch does not wobble.
   B.face X2
  65g Zealios
