Author Topic: It is hard to play CS:GO w/ my cat sitting in front of my monitors  (Read 5348 times)
Offline atarione
as you can see my cat Fitz has decided to hang out in front of my monitor making playing CS:GO much more difficult .. he is all sitting on the mouse cord which isn't helping.. but as you can see he is a pretty awesome cat ..so I just deal with it..
Offline atarione
Re: It is hard to play CS:GO w/ my cat sitting in front of my monitors
« Reply #2 on: Tue, 10 January 2017, 02:21:45 »
Has it increased your battle strength.
eventually i just let him play instead.. he is pretty good..
« Reply #3 on: Tue, 10 January 2017, 04:12:53 »
ur only getting ~200fps in that photo there..   cats require more frame rate , they have faster motion processing ability.
Offline ygor
  • eat a butt, monkey lord
« Reply #4 on: Tue, 10 January 2017, 05:10:11 »
Savage. Probably just wants a good seat for the one taps. CoolCat
Offline atarione
« Reply #5 on: Fri, 13 January 2017, 15:10:14 »
so.. this is totally my cat's jam now.. last 3days any time I try to play this happened..
« Last Edit: Fri, 13 January 2017, 18:16:23 by atarione »
« Reply #6 on: Fri, 13 January 2017, 16:54:46 »
so.. this it totally my cat's jam now.. last 3days any time I try to play this happened..
He's learning how to kill humans..
Did you upgrad ur graphx card yet ? still playing with that 200fps ?
Offline atarione
« Reply #7 on: Fri, 13 January 2017, 18:15:37 »
no still lowly HD7950..   mhh.. he might well be learning how to kill humans... his previous techniques had proved ineffective..
157564-0
« Last Edit: Fri, 13 January 2017, 18:51:39 by atarione »
« Reply #8 on: Fri, 13 January 2017, 18:25:06 »
no still lowly HD7950..   mhh.. I might well be learning how to kill humans... his previous techniques had proved ineffective..
7950 can still do 300fps with competition settings.
what's ur cpu.
Offline atarione
« Reply #9 on: Fri, 13 January 2017, 18:50:27 »
CPU is non OC'd i7-4770K w/ 12GB RAM (mushkin redline ... i think?? I don't remember honestly).
Offline HPE1000
  • Keycap Paparazzo
« Reply #10 on: Fri, 13 January 2017, 19:01:57 »
he is just wondering why you are playing reserve maps
« Reply #11 on: Fri, 13 January 2017, 19:12:57 »
oh boy, that's no good..
You don't want mismatching ram.. it introduces extra latency due to the non parallel memory channel configuration
the 4770k should do 300 out of the box.. might be some spyware on there..
See if you can bump to 4.2-4.4ghz on stock volts.. ,  unpark cpu,  lock to 100% during gaming, use timer-resolution to reduce latency..
Up the volt to 1.355 and try 4.7-4.8..   it's important you unpark,,  and also turn off all the power protection/ power gating in the motherboard..
if you got one of those boards that scale back active vrms , turn that off too..
Offline clacktalk
  • circa 2015
« Reply #12 on: Fri, 13 January 2017, 19:15:33 »
u should get another cat to deal with this cat.
another, bigger cat
diary of a clacktalk
radio_killah: too much frank
Offline atarione
« Reply #13 on: Fri, 20 January 2017, 13:08:48 »
Fitz has continued to enjoy jumping up and watching the gaming.. he apparently likes all sorts of games because he jumps up and does the same thing to my wife when she plays whatever casual facebook games she plays ...
cats love esports apparently..
« Reply #14 on: Fri, 20 January 2017, 15:10:01 »
Make sure to check in @ geekhack everyday..
We are worried cat might reach Human Killing_ Xpert Level..   Then it might try out its immense skills
Offline atarione
« Reply #15 on: Fri, 20 January 2017, 18:20:03 »
SOON HOOMAN!!!! SOON..
as you can see Fitz is helping me use the internet... trying to figure out why "kill all humans" is in my google search history...
also now you know why my keyboard always has god dang cat hair in it... oh well... don't buy a used filco from me if you are allergic to cats apparently...
