Author Topic: WOULD THIS BE A BETTER NATURAL ANGLE KEYBOARD?  (Read 6822 times)
Offline Yotaka
« on: Wed, 18 January 2017, 06:33:51 »
How do you guys think about this? The key positions are based on the nature stretch angle of our Metalcapal.
157896-0
« Last Edit: Fri, 03 February 2017, 03:18:32 by Yotaka »
Offline Jokrik
Re: Would this be a better natural angle keyboard?
« Reply #1 on: Wed, 18 January 2017, 06:35:45 »
oh wow
that looks interesting, I am currently using something similar but this one has more of a curvy stretch on the keys
Offline 1391406
« Reply #2 on: Wed, 18 January 2017, 10:08:21 »
My hands don't curve inward to that degree in a resting position.
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #3 on: Wed, 18 January 2017, 10:31:42 »
While the main part of the keyboard looks okay, the keys that are not part of the curve, look painful to reach - especially the function key row. That row would be a lot easier to work with if it followed the same curve, in my opinion. You'd lose the aesthetics, but hey.
There are also a lot of keys on the right side, that make little sense to me: the arrow keys, and that whole cluster. You'd have to move your hand to reach them anyway, which pretty much defeats the ergonomic goal (in a similar way the function key row does).
The big ass spacebar, Enter and Backspace above are also things I dislike. A similar arrangement works fine on the TypeMatrix (for reference, I used one for 3+ years or so), where the layout is a matrix layout. If you have a curve like on this keyboard... I don't think they would be as comfortable. And having such a huge space bar means that your thumbs will have little else to do than smashing that one key, and that's a waste of a strong digit.
Not to mention that there is no possibility of tenting the keyboard, either. There is no wave, like on the Sculpt, yet, that is a very important ergonomic factor. (The Sculpt also has a similar curve, and has the function row curved too - for a good reason)
From an ergonomic PoV, I think TypeMatrix, Sculpt, ErgoDox, Kinesis (even the Freestyle!) are superior to this, for different reasons:
- TypeMatrix does not have any curves, but the function row is easier to reach.
- Sculpt has a better curve, and the middle is raised, making it more comfortable.
- ErgoDox is split, and allows adjusting the tenting/tilting, and also allows you to use your thumbs more efficiently.
- The Kinesis Advantage has a thumb cluster, and the key wells are superior to the curve. Though the function row there is similarly awful.
- The Kinesis Freestlye can be tented, and is split - a bigger gain than the curve in itself.
There may be other options, and other reasons, and while the layout may be an improvement over most, traditional keyboards, for those who want to improve their ergonomics, there are already other, better options as far as I see.
Offline Yotaka
« Reply #4 on: Wed, 18 January 2017, 20:07:39 »
Thank you, this is still in optimization. So we are here to hear more from you guys.
We focus on our typing area(picture below), that's true that functions are hard to reach,we are thinking of a way to solve this.
Each ergonomic keyboard has its focus point, we intended to make the typing area more comfortable that base the nature stretch of our metalcarpal.
 157965-0
Offline Yotaka
« Reply #5 on: Wed, 18 January 2017, 22:20:53 »
This layout was designed upon our hand's natural physiological structure and kinematic characteristics.
Our goal is to offer a relaxed typing experience.
« Last Edit: Thu, 19 January 2017, 03:54:42 by Yotaka »
Offline Yotaka
« Reply #6 on: Thu, 19 January 2017, 23:53:07 »
oh wow
That's Great, and how do you feel about this curve?
Offline nmur
  • ಠ_ಠ
« Reply #7 on: Fri, 20 January 2017, 00:10:20 »
the greatest increase in typing relaxation with my ergodox came from tenting it.
a split keyboard is much more flexible when it comes to wrist angle and wrist rotation
« Reply #8 on: Fri, 20 January 2017, 15:46:18 »
I think there is some great confusion in the keyboard community..
YES this is better than the standard staggered rows..
HOWEVER,  even with layout change, it has little to no ergonomic value, because the WRIST angle is the bottleneck..
If you have a split layout without tenting,  then you haven't improved keyboarding's largest deficit, which is wrist comfort.
Offline Yotaka
« Reply #9 on: Fri, 20 January 2017, 21:14:17 »
Yes, you made a solid point. We do consider the tenting, and might make a tenting version in the future.
But for this standard version, we wanna produce a ergonomic keyboard for general users, that is why we keep most the layout and functional keys in the old ways and old position, so they can get easier to adapt on this.
« Last Edit: Sat, 21 January 2017, 00:55:43 by Yotaka »
Offline hoggy
  • * Ergonomics Moderator
« Reply #10 on: Sat, 21 January 2017, 00:07:06 »
I think there are some quite nice elements to the design.
Would you consider splitting the space bar in two, one for space and one for enter?
It would be pretty cool if you could implement 'shift and space' so the space bar is a dual role key, shift if used with another key, but space on key up if no other key is pressed.
I'd buy one for sure.
Offline Yotaka
« Reply #11 on: Sat, 21 January 2017, 01:57:13 »
Thank you.
And actually there are so many people talking about split its spacebar, so now we are considering to split the spacebar and put the shift and Ctrl in the center(picture shows below). We will choose either standard or split later, depends on which one that most people prefer.
158177-0
Offline Data
« Reply #12 on: Sat, 21 January 2017, 19:49:23 »
It's a nice idea and appears to be well executed. It doesn't look like there'd be enough hand separation for me, but I'd have to try it out to be sure.
Offline Yotaka
« Reply #13 on: Sun, 22 January 2017, 21:29:25 »
Thank You for giving this a try. You can really know how it feel when you get it on your hand.
Offline hoggy
« Reply #14 on: Mon, 23 January 2017, 12:21:36 »
If you increased the size 'north/south' then you could use standard key caps.  I'd guess that would make the board more desirable for the members here.
Offline Yotaka
« Reply #15 on: Mon, 23 January 2017, 20:59:35 »
You mean bigger the size of F key row and the bottom row? Hmm, that's interesting. Might reduce the problem of "hard to get F row"?   Thank You, we might try to make it, see how it look at the design software first.
Offline Yotaka
« Reply #16 on: Thu, 02 February 2017, 20:36:39 »
Yea. That's what we are going to do, we will have split keyboard later, especially for gamer.
Offline Yotaka
Re: WOULD THIS BE A BETTER NATURAL ANGLE KEYBOARD?
« Reply #17 on: Tue, 14 February 2017, 02:09:01 »
More details and features in this site:
https://www.x-bows.com
