Author Topic: Best way to fix Cherry stabs when the wire disconnects?  (Read 1835 times)
Offline ArchDill
« on: Wed, 18 January 2017, 12:59:55 »
The wire came out of 1 side on my daily driver. Best way to fix it? just try and place it back using tweezers or is there a better solution? Thanks!
Re: Best way to fix Cherry stabs when the wire disconnects?
« Reply #1 on: Wed, 18 January 2017, 13:03:01 »
Normally I use some tweezers or a really thin flat head screwdriver. Sometimes it's necessary to desolder a switch or two if it's really out of place, but it's still better than the "guarantee" option which is to desolder every switch.
« Reply #2 on: Wed, 18 January 2017, 15:43:11 »
what?
just pop it back in..
take the cap off, put the wire back into the stabilizer nubs.
Then put the keycap back on to the wire ends,   then back onto the switch.
Offline keytohopiness
« Reply #3 on: Wed, 18 January 2017, 17:25:49 »
what?
Cherry stabs, not Costar.
Offline ArchDill
« Reply #4 on: Thu, 19 January 2017, 10:27:05 »
On a work trip right now. I should be home tonight and can bust out the ifixit kit and fix it, hopefully.
