Author Topic: [HELP] Left shift Cherry stab keeps coming out  (Read 1905 times)
Offline ArchDill
« on: Fri, 03 February 2017, 02:59:32 »
Hey all. Left cherry stab keeps coming out. Anything I can do to help this?
Offline nmur
  • ಠ_ಠ
Re: [HELP] Left shift Cherry stab keeps coming out
« Reply #1 on: Fri, 03 February 2017, 03:01:08 »
is the bar coming out of the clips? or are the stabs coming out of the pcb?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #2 on: Fri, 03 February 2017, 03:01:55 »
PCB mounted?
You might just have a broken housing due to pushing it in with too much force when building.
Sent from my Nexus 5X using Tapatalk
Offline ArchDill
« Reply #3 on: Fri, 03 February 2017, 03:36:59 »
PCB mounted?
The bar keeps coming out of the housing. I read somewhere that you can jam put something in there that will hold it in there. I travel with this board sometimes and it constantly happens.
« Reply #4 on: Sat, 04 February 2017, 04:07:18 »
u need a new stabilizer..
Worry not, you don't have to desolder the whole thing
What you can do is cut off the bottom pegs of the new stabilizer housing, put some tape surrounding the housing, and just wedge it into the slot..
So it's going to be wedged into the plate..
If you're pcb mounted, then well that's even easier, just buy a new stabilizer. hahahaha
