Author Topic: Statick shock damage report, any help appreciated!  (Read 2872 times)
Offline djodars
« on: Fri, 03 February 2017, 07:30:11 »
Hi there,
Found this forum by googling my issue; Yesterday, my girlfriend accidentally discharged a pretty big static shock on my keyboard and now, some of the keys aren't working properly. (Currently half typing on the virtual keyboard :P)
Here's an image of "Switch Hitter": http://i.imgur.com/AQOpxpj.png
As you can see, the " F12 , - , b , n , é , AltGr , Menu and left , right , down arrows " aren't working.
When I plug my keyboard, the AltGr key is " toggled on " but I managed to untoggle it. Now is there anything I can do to repair it? I know nothing about the inside of a keyboard, is it only the switches or is it the controller, the board, etc.?
Thank you for your help!
Offline Wingklip
  • I am the one the one the one the one the one
Re: Statick shock damage report, any help appreciated!
« Reply #1 on: Fri, 03 February 2017, 09:15:33 »
How on earth did that happen? (Pun intended)
I thought most keyboards had ground cables to discharge static safely. You'll likely have to short out all the pins to ground to discharge it completely. Also try spraying everything with water if your components don't have iron in them as it is a very fast way of static discharge, and much safer than individual discharging pins.
If all else fails, replace the IC's
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
Offline djodars
« Reply #2 on: Fri, 03 February 2017, 11:16:27 »
I think our apartment is pretty dry so when we're sitting on the sofa, we always build static up. We normally touch a metal handle or something like that before going on the computer but she must have forgotten this time.
I opened my keyboard earlier to push on the daughter board ( recommended by keyboardco ) but it didn't work.
So, how would I go about shorting the pins? and when you say spraying water, do you mean on the board itself and then I leave it to dry for a few hours?
Offline Wingklip
« Reply #3 on: Fri, 03 February 2017, 19:38:54 »
Humidify the air as much as possible by spraying water, also you can try spraying the PCB lightly. Make sure it is a fine mist as that helps to slowly discharge static. Best to use distilled water if you don't want to rust anything, but it shouldn't case that in small amounts.
TLDR humidify the room
Offline TalkingTree
    • My projects
« Reply #4 on: Sat, 04 February 2017, 02:38:25 »
Knowing what keyboard is it would help greatly. Other than that, I'm inclined to believe the ESD broke some of the diodes.
« Reply #5 on: Sat, 04 February 2017, 03:40:57 »
Hrrrmmm...
Well in general, you want to make sure your HOUSE's electrical box is properly grounded, as in that 3rd pin should have a connection to earth ground, such as an earthing rod, or a metal segment of your water in/out
Because the keyboard (well designed ones at least)  should be grounded through its usb connection with the PC..
Now, the PC must be grounded, and the PC connected to (Your HOUSE) must then also be grounded..
That's why in certain other countries (older houses) which don't have an earth ground, all their metal electronics, like macbooks, pc cases, cellphones feel Fuzzy to the touch,  this is due to electricity riding on the surface of the device..
Offline djodars
« Reply #6 on: Sat, 04 February 2017, 05:05:42 »
It is a Filco Majestouch Yellow editio: http://www.keyboardco.com/keyboard/filco-majestouch-2-nkr-tactile-action-usa-yellow-keys-keyboard.asp
Offline TalkingTree
    • My projects
« Reply #7 on: Sat, 04 February 2017, 05:36:55 »
The only way to inspect the diodes is to open the case, voiding the warranty, and desoldering all the switches.
Offline Wingklip
« Reply #8 on: Sat, 04 February 2017, 09:45:37 »
If this doesn't work test everything with a multimeter
Offline keytohopiness
« Reply #9 on: Sat, 04 February 2017, 09:50:28 »
More likely the controller.
Offline Wingklip
« Reply #10 on: Sun, 05 February 2017, 23:02:59 »
More importantly, how on earth did she manage to ground when touching something with a 1.5mm thick layer of PBT or abs keycap, the mechanical stem below it, before even getting to anything remotely metallic? Quite peculiar. I have seen that Greennoch model M's had a grounding wire to the spacebar. Evidently this was not the case for this keyboard  :-X
