Author Topic: Drain Grease ? [Sloppy Joe Discussion]  (Read 15909 times)
« on: Fri, 24 February 2017, 10:41:28 »
Tp4 has always made ,  The Full-Phat,  Sloppy Joes..
've never drained the oil,  even using the 20% fat ground beef..
The oil is what gives it a smooth rolling texture..
Why would they recommend you drain the grease..
BEHOLD___  Full-Phat
......... the Orange-Pool !!
161337-1
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Drain Grease ? [Sloppy Joe Discussion]
« Reply #1 on: Fri, 24 February 2017, 11:00:35 »
If I am using 85/15 I don't,  but I will with 80/20.
Side note, don't use 73/27 for burgers on a charcoal grill.  It doesn't flare, but puts the charcoal out.
« Reply #2 on: Fri, 24 February 2017, 11:32:16 »
with 80/20,  it's only 90 grams of fat per 1 pound of Beef..   810 calories..
with 85/15,  it's 63 grams of fat per ..  567 calories..
All falls neatly within daily acceptable fat intake, assuming one doesn't eat more than a pound of SJ a day.. hahahaha
Offline Melvang
« Reply #3 on: Fri, 24 February 2017, 12:04:21 »
I do it for texture in the reheat.
