Author Topic: Final Death of Dropbox Public Folders - Alternatives?  (Read 17515 times)
Offline heedpantsnow
  • Old enough to know better
« on: Thu, 02 March 2017, 08:59:04 »
Dropbox stopped giving new users Public Folders access a few years ago.  This is a folder in your dropbox that you can link to any file from the web, directly.
Many people used it for sharing images on this and other sites, and even a few used it to host a small static website.
Dropbox is about to kill all those links on March 15th.  So any images I've ever posted on any forum will no longer work, since this is what I've used for...forever.
It was so convenient to just right click on an image in my public folder and get a link to it.  :mad:
Are there others in the same boat?  What are you going to use going forward?  I have Onedrive and GDrive, but "sharing" an image from those only gives you a link to another page where you can download the image, not a link to the image itself.
I'm back.
Re: Final Death of Dropbox Public Folders - Alternatives?
« Reply #1 on: Thu, 02 March 2017, 09:13:50 »
Imgur.
Offline dgneo
  • Supervillain
Offline gallowgeek
« Reply #3 on: Thu, 02 March 2017, 09:19:54 »
I would also add Photobucket to the list. Although I find Imgur easier to work with. You just need to sign up for an account.
« Reply #4 on: Thu, 02 March 2017, 09:58:19 »
Are there any cloud storage services that offer similar functionality?  I've used photobucket for years, and Imgur is similar, but there's no local folder for me to export a bunch of photos to from Lightroom.
I'm back.
Offline dgneo
  • Supervillain
« Reply #5 on: Thu, 02 March 2017, 10:00:15 »
You could use Flickr, there's the option to Export directly to Flickr (rather than needing a local folder): https://lr.tips/lightroom/lightroom-publish-flickr/
« Reply #6 on: Thu, 02 March 2017, 10:04:11 »
OK I'll check that out.  Does Flickr allow direct linking (link goes to actual image instead of webpage of image)?
I'm back.
Offline dgneo
  • Supervillain
« Reply #7 on: Thu, 02 March 2017, 10:05:16 »
Yessir, you need to pull the link out manually, but it does work (Share Image > BBCode > Copy URL of image from there).
Offline happylacquer
  • BS Apologist
    • BHOBuds
« Reply #8 on: Thu, 02 March 2017, 12:24:59 »
been sharing a mega acct with friends for years, works fine.
« Reply #9 on: Thu, 02 March 2017, 19:57:57 »
Imgur.
Does Imgur still have a pitifully small limit on the number of pictures you can upload with a free account?
« Reply #10 on: Thu, 02 March 2017, 20:31:52 »
I have been happy with Imgur, but I usually clean out obsolete stuff on a regular basis.
Is the definition of "a pitifully small number" a dozen or a hundred or a thousand?
Likewise Dropbox, I have never gotten close to filling up my limit.
- D Trump 2026-10-24
« Reply #11 on: Thu, 02 March 2017, 22:03:36 »
Imgur.
And a really low maximum file size
Offline bmmcwhirt
    • KB9YEN
« Reply #12 on: Fri, 03 March 2017, 12:39:43 »
Google Photos.
There is an app for ios, mac and windows and built in to android that lets you sync photos.
https://photos.google.com/apps
Offline davkol
  •  Post Editing Timeout
« Reply #13 on: Fri, 03 March 2017, 13:08:33 »
Imgur.
Still too high. Some people don't have common sense, when it comes to bandwidth. Crippling them by design helps.
Offline dgneo
  • Supervillain
« Reply #14 on: Fri, 03 March 2017, 13:15:00 »
Imgur.
Sounds like it's been a few years since you've been there, seeing as it's unlimited now. Also a limit of 20MB per picture.
I think you'll be okay.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #16 on: Fri, 03 March 2017, 13:25:07 »
Glad I have an old dropbox account!
Offline bmmcwhirt
    • KB9YEN
« Reply #17 on: Fri, 03 March 2017, 15:33:43 »
Doesn't matter how old it is, on Mar 15, 2017 all Basic(free) shared/public folders become private. You only get the public folder on paid accounts until September when that will also go away.
https://www.dropbox.com/help/16
« Reply #18 on: Mon, 06 March 2017, 19:50:59 »
I seem to have 347 images in my account, but it kept telling me it was "hiding" older images (or something like that - been a while since I used it) as I had too many images.
Offline Coreda
« Reply #19 on: Mon, 06 March 2017, 20:59:13 »
Just for clarity this doesn't affect directly shared files, only those in the dedicated Public folder, from everything I've read about it. So one can still share/link files publicly so long as you use the Share link for individual folders/files (which is what I do).
The only thing you need to change to make such shared links embeddable is the URL scheme:
Original:
Code: [Select]
https://www.dropbox.com/s/<charactershere>/<filenamehere>?dl=0
Replacement:
Code: [Select]
https://dl.dropboxusercontent.com/s/<charactershere>/<filenamehere>
« Last Edit: Mon, 06 March 2017, 21:07:22 by Coreda »
Offline Krakob
    • Krakblog
« Reply #20 on: Thu, 09 March 2017, 04:42:10 »
Original:
Code: [Select]
Replacement:
Code: [Select]
I think it's better to do ?raw=1 as that should give the same results as a file directly linked from public. I've tried messing with the dl parameter but ran into some issues, if I recall correctly.
Ducky Shine 2 (MX Blue, white backlight) • Obins Anne Pro (Gateron Brown) • Model M • XD60
« Reply #21 on: Thu, 09 March 2017, 07:48:26 »
Original:
Code: [Select]
Replacement:
Code: [Select]
I hope no one will be naive enough to expect Dropbox to keep file sharing the same for the foreseeable future.
They already broke their word from when they told us they were doing away with the Public folder feature "but existing files and links will continue to work". Why would I trust them to host my files now?  I have hundreds of images linked many hundreds of times to forums across the web. It's too much work to go and edit all those links; so those worklogs and such will just be broken.
Dropbox has made no effort to provide a way forward for existing files or links and has just said "they will have to be re shared". There are many people affected by this but anyone complaining about it on Dropbox's support community gets their post deleted.
I'm back.
Offline Coreda
« Reply #22 on: Thu, 09 March 2017, 08:43:11 »
You could honestly say this about any free hosting site. My post was simply clarifying that this doesn't affect non-Public folder shared links (which I have always used). Whether or not this gets changed in the future is unknown. The already dropped live HTML linking support prior to this so they're clearly cutting back on direct public links.
The only way to be in control of a host is to run your own tbh.
Flickr has been around a while so it's a decent choice. Direct linking requires you to also add a link back to the original Flickr page however, according to their ToS. Some ignore this but it's worth highlighting.
« Reply #23 on: Thu, 09 March 2017, 08:56:34 »
You are correct, but I would point out that I was a paid subscriber.  When you are receiving something for free, it's hard to complain when it gets broken.
When you are paying for something, things change quite a bit.  Obviously my hobby forum images are not that important, but at work if we paid a company for a certain feature, and invested in training, workflow, APIs, etc., and then the company mothballed it (and then refused to even grant legacy access), there's no way we would continue to work with them.
For example, Bitcasa did something similar to its non-commercial customers (including me) in 2014.  When its corporate clients saw this, they gradually started moving to other providers.  They've been on a downward spiral for the last two years, and there are now rumors they are shutting their doors.
I'm back.
Offline snsr
« Reply #24 on: Wed, 15 March 2017, 21:54:41 »
Definitely one of the best Dropbox features.
Similar: Cloudapp, Dropshare or an ftp/sftp/webdav program that makes a remote server (incl. S3, Azure, Google) work like a local drive e.g. Transmit.
Offline zslane
« Reply #25 on: Fri, 17 March 2017, 12:29:40 »
I used to just upload to my website hosted by Godaddy, but last year all direct links to my website stopped working here and I have no idea how to fix it. At first it seemed like it had something to do with security certificates or some such (GH's certificates expired last Fall), but even though that's been remedied, links to my website continue to fail.
I am also leery of trusting that direct links to "private" DropBox content will continue to work. I'm thinking of checking out imgur.
Offline digi
  • elite af tbh
« Reply #26 on: Fri, 17 March 2017, 12:33:40 »
I use Dropbox to host illegal music repositories for the general public.
Offline bmmcwhirt
    • KB9YEN
« Reply #27 on: Fri, 17 March 2017, 16:58:18 »
It all comes down to what features you want/need/can do without.
Here is a pretty good article on some alternatives.
https://www.cloudwards.net/top-10-secure-dropbox-alternatives/
Imgur is pretty good for images but I've been playing with google photos for the past week and it's a viable alternative.
For other things like sharing PDF or OOD files I've not found anything I like as much as dropbox yet but I'm not finished reading the above article yet. I'll probably be giving some of their recommendations a try to see what I think over the next week.
Offline Zombii
  • Let’s All Love Lain.
« Reply #28 on: Sat, 18 March 2017, 20:29:02 »
As a fellow poweruser of Dropbox for quite a long time I recommend using ShareX. It's an open source monitor capture/uploading tool that you can also use to upload files. You can configure all of the upload destinations yourself but I recommend imgur for images.
« Reply #29 on: Sat, 18 March 2017, 20:35:15 »
/thanks for the tip
//NSA appreciates your cooperation
//Forwarding confession to RIAA..
Offline Boskr
« Reply #30 on: Sun, 23 April 2017, 22:37:45 »
ShareX can do right click uploads to Imgur, which automatically puts the link on your clipboard.
Sent from my Pixel using Tapatalk
Levinson split 40%, Gat Greens, DSA Blank
GH60, Cherry Browns, OEM Granite
Razer BWX TE, Gat Blacks+RGB, DSA Blank, No Logo (522 Solder Joints!!!)
Razer BWX TE, Razer Greens+RGB, All Stock (girlfriend's)
MagicForce 68, Cherry Reds, TaiHao Dasher
Corsair K70, Cherry Reds+RGB, Stock Caps
Ask me about Soldering/Assembly/Other services in NC!
Offline iLLucionist
  • Topre is Love.
« Reply #31 on: Tue, 25 April 2017, 00:20:13 »
/thanks for the tip
See? Telemetry is not needed. We have other means of hunting people down. Hehe
