Author Topic: Dell S2417DG vs Dell S2716DG, worth the $250 difference?  (Read 10532 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Thu, 09 March 2017, 02:10:07 »
I have been using my small 16" laptop for the longest time and I'm getting a new monitor soon, and I was wondering what you guys would recommend?
I'm contemplating whether the approximately $200 dollars difference is worth it at 24" vs 27"
I haven't used a 24" or 27" monitor before so I can't really state a preference off hand, I sit about 2 and a half feet away from my monitor, give or take.
EDIT: It appears amazon just has really messed up prices, the price difference isn't quite as large.
« Last Edit: Thu, 09 March 2017, 02:12:56 by Air tree »
Offline YoungMichael88
  • HHKB Wannabe
Re: Dell S2417DG vs Dell S2716DG, worth the $250 difference?
« Reply #1 on: Thu, 09 March 2017, 02:19:10 »
I've been using 27" monitors for years now. To me it's the perfect size for a desk. Any bigger and I don't think I would like it. Unless of course we were talking about ultra wide monitors or something like that.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #2 on: Thu, 09 March 2017, 02:34:47 »
24 will be a fantastic upgrade to what you're used to, but then you will long for a 27. I've got 3 24' and they are perfect, but I wish I had 3 27's!
SIDENOTE: Is the resolution in these 2 models different?
Offline Air tree
« Reply #3 on: Thu, 09 March 2017, 03:02:13 »
Both are 2560x1440 144hz/165hz and G-sync monitors.
I've heard of less inverse ghosting problems and overshoot problems with the 24 inch model, so I don't know.
« Reply #4 on: Thu, 09 March 2017, 03:48:09 »
i find that for my standing desk, because i can stand a bit further away from it,  a 40 inch tv works best.
Buhhhhhhhh.. at the desk with the chair a 30 to 36 inch would still work well..
don't worry too much about resolution,  Almost nothing is worth seeing in HD except movies and dota/hearthstone
So what I do is run everything in 1280x800 on my 30 inch,  and when I'm awtching a movie, i'd hotkey to 2560x1600.
« Reply #5 on: Thu, 09 March 2017, 03:49:57 »
also,  get a ULMB monitor..
It's just so much better... motion clarity is everything for moving pictures.. be it games/ movies.
it's the single most important feature..
Offline missalaire
  • Great Finder of Great Finds
« Reply #6 on: Sat, 11 March 2017, 00:37:36 »
Dell S2716DG
You are not going to notice the difference between 144hz and 165hz.
Offline Air tree
« Reply #7 on: Sat, 11 March 2017, 01:10:36 »
Dell S2716DG
More so about the size rather than 144hz and 165hz, I don't know if 24" is too small for 1440p.
But I'm leaning for the s2716dg since it's only $50 more on the dell website.
« Reply #8 on: Sat, 11 March 2017, 01:11:41 »
Dell S2716DG
don't get anything under 27
Offline cribbit
« Reply #9 on: Tue, 14 March 2017, 13:15:56 »
I've owned both the S27 and the S24. I currently use the S24, along with 3 other 24" 1440p panels.
If you don't absolutely need the desk space like I do, get the S27. The tiny extra hz of the S24 isn't noticeable. 27" is the sweet spot for 1440p, I only like 24" because I'm used to it.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
