Author Topic: Keyboard mats  (Read 5023 times)
Offline macguy80
Keyboard mats
« on: Tue, 14 March 2017, 00:58:21 »
On many of the sound videos I see on YouTube, many people use keyboard mats, and sometimes even add a towel on top of that, to lessen the sound from the desk.
So do you guys do that just for the videos, or do you find you actually prefer the sounds of typing with a mat and/or towel added? I've never even thought of getting a mat until now.
Offline klennkellon
  • I like bottoming out
Re: Keyboard mats
« Reply #1 on: Tue, 14 March 2017, 02:02:14 »
I do. I have a glass desk so the vibrations reverbing through it are very audible and the desk kind of "rumbles" as I type on it. Putting it on a towel makes typing sound less.... violent, for lack of a better word.
Re: Keyboard mats
« Reply #2 on: Tue, 14 March 2017, 07:26:17 »
Might as well be shameless and plug my product again.
Between some sound absorption and increased stability, I continue to think that these EPDM mats have a good balance of qualities.
https://geekhack.org/index.php?topic=59308.msg1359377#msg1359377
- D Trump 2026-10-24
Offline invariance
  • ...here with all the other boson's
Re: Keyboard mats
« Reply #3 on: Tue, 14 March 2017, 07:32:07 »
I'm using a sheet of butyl rubber.
Originally purchased for car sound deadening but works equally as well as a keyboard mat.
Non-adhesive type of course.  :)
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Geroximo
Re: Keyboard mats
« Reply #4 on: Tue, 14 March 2017, 12:59:46 »
I couldn't live without a mat under my keyboard.
Offline macguy80
Re: Keyboard mats
« Reply #5 on: Tue, 14 March 2017, 15:01:25 »
Thanks for that! I appreciate the plug. One question: Since this is rubber, is there a rubber smell? I find I'm quite sensitive to that scent in particular, even after playing only a few minutes with a dog toy, for example.
Re: Keyboard mats
« Reply #6 on: Tue, 14 March 2017, 15:05:16 »
Well there's ur problem.
Dog toys are for dogs..
///hahaha
Offline macguy80
Re: Keyboard mats
« Reply #7 on: Tue, 14 March 2017, 15:29:32 »
Walked right into that one, I guess!
Re: Keyboard mats
« Reply #8 on: Tue, 14 March 2017, 18:43:59 »
My sense of smell is not as good as it used to be, but as far as I can tell there is hardly any smell at all.
https://en.wikipedia.org/wiki/EPDM_rubber
PS - I agree that dogs are disgusting
Offline macguy80
Re: Keyboard mats
« Reply #9 on: Tue, 14 March 2017, 18:56:43 »
I never said that, and never would, cause I love my dog. But I hate the smell of rubber after throwing the squeak toy for her for five minutes ;)
If I do decide to get one, would you say that the AEK I got from you falls into the Large tier, as opposed to the Extra Large?
Re: Keyboard mats
« Reply #10 on: Tue, 14 March 2017, 19:32:18 »
Yes, tell me whether you want it undersized by 1/4", exact fit, or oversized by 1/4". I have an AEK here to measure by.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: Keyboard mats
« Reply #11 on: Tue, 14 March 2017, 19:34:04 »
I came here to recommend the mats from Fohat.digs. I need to get some more for myself to be honest haha.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Keyboard mats
« Reply #12 on: Tue, 14 March 2017, 20:18:36 »
I've recently started adding the foam into the keyboard itself - between the pcb and case. Its definitely a change in sound and feel. I dont need the mat underneath which for me helps a lot. I tend to move stuff out of the way on my desk at home quite regularly to work on something, cut something, solder something, etc. and having a mat to pull up means I've got to move everything off it first.
Anyway, heres a few foam inside ideas:
http://i.imgur.com/o5Tgzcr.jpg MiniVan 40%
http://i.imgur.com/POkeTKS.jpg Sentraq 60%
http://i.imgur.com/7wpxLvZ.jpg HHKB
http://i.imgur.com/9NPE1bx.jpg?1 V80
I had to buy a lot of foam to figure out what I was looking for.
-Dana
Re: Keyboard mats
« Reply #13 on: Wed, 07 June 2017, 23:06:36 »
I use a folded sheet of drawer liner.
Apart from stopping the keyboard/s sliding across the desk, it does absorb a lot of the echo from the desk.
Although I am not using it with this SSK as I prefer the sound of the springs buckling through the office :)
