Author Topic: [QUESTION][HELP]Teensy Loader not recognize Teensy Board.  (Read 8090 times)
Offline Manchias
« on: Thu, 16 March 2017, 03:13:23 »
I have just purchased an ergodox keyboard. However there is a problem that can't help me keymap it.
I connect ergodox keyboard to my pc. Everything went find. The keyboard work perfect. However, once I press the button to enter program mode, the small windows " press button on teensy to manually enter program mode " on Teensy Loader doesn't disappear.
Seem like the Loaderd doesn't recognize my Ergodox keyboard.
Anyone have the same problem or any solution ? Please help.
Offline profet
Re: [QUESTION][HELP]Teensy Loader not recognize Teensy Board.
« Reply #1 on: Fri, 17 March 2017, 04:49:15 »
Which Ergodox did you buy? Where did you buy it?
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline Manchias
« Reply #2 on: Fri, 17 March 2017, 16:11:42 »
I got it from a guy in Vietnam. Asked him and he said he has never tried to keymap before.
Offline profet
« Reply #3 on: Fri, 17 March 2017, 16:43:42 »
Sound alike you got a Counterfeit teensy. It may not be compatible with the teensy loader.
Offline Manchias
« Reply #4 on: Sat, 18 March 2017, 23:45:19 »
Please let me know if there is a way to program a counterfeit teensy :(
Offline Manchias
« Reply #6 on: Sun, 19 March 2017, 10:10:38 »
After check with all counterfeit teensy on google, I'm not sure if mine is counterfeit or not :(
« Last Edit: Sun, 19 March 2017, 10:15:13 by Manchias »
Offline Manchias
« Reply #7 on: Sun, 19 March 2017, 10:13:28 »
take a picture of the teensy
Here is the picture of the teensy
http://imgur.com/a/IGPXQ
Offline profet
« Reply #8 on: Sun, 19 March 2017, 10:44:58 »
It's Counterfeit. Notice the 2 pins labeled "F6"
Offline Manchias
« Reply #9 on: Sun, 19 March 2017, 11:20:09 »
Yup ... seem like a counterfeit one. Do you have a way to keymap it :(
Offline profet
« Reply #10 on: Sun, 19 March 2017, 11:37:39 »
nope... and honestly... I'd rather people not support counterfeit products. PJRC (producers of genuine Teensy products) have contributed so much to this community. Cheating them by buying/supporting counterfeit products does a disservice to the mechanical keyboard community.
Offline joenappable
« Reply #11 on: Fri, 11 May 2018, 22:09:38 »
I have the same problem like you. It seem like lastest version of teensy loader doesn't support counterfeit teensy 2.0. But luckily, i have the previous version (1.15) teensy loader. And it supports counterfeit board.
Offline hoggy
  • * Ergonomics Moderator
« Reply #12 on: Sat, 12 May 2018, 02:27:46 »
I've moved the thread, hope that's okay.  It's not that I don't think the thread belongs in ergonomics, it's that I feel you'll be better served here.
Chris
