Author Topic: Cutting stems for longer keytravel  (Read 2770 times)
Offline Geroximo
« on: Thu, 16 March 2017, 18:16:58 »
Anybody ever thought of that or tried it out?
I'm talking about cutting the end of the stem to increase keytravel. It probably wouldn't work for low profile keycaps as the keycap hitting the switch housing will limit the stroke, but for high profile keycaps it would work, wouldn't it?
Offline Zeal
    • Zeal Generation Inc.
Re: Cutting stems for longer keytravel
« Reply #1 on: Thu, 16 March 2017, 18:42:45 »
Wouldn't affect anything if you cut the poles off. The part that bottoms out is the internal bottom part "rails" of the slider, not the pole. There's actually a bit of gap at the bottom of the pole.
« Reply #2 on: Thu, 16 March 2017, 19:18:35 »
ya i thought the poles were just to keep it on straight
i would trust zeal on this
Offline zpcomstock17
« Reply #3 on: Thu, 16 March 2017, 23:08:29 »
The god of purple switches has spoken!
Offline Zeal
« Reply #4 on: Fri, 17 March 2017, 00:18:50 »
It's super obvious when you've got transparent housing switches to look through.  :rolleyes:
Offline Geroximo
« Reply #5 on: Fri, 17 March 2017, 06:04:52 »
I understand. Thx for the information.
Offline ninjadoc
« Reply #6 on: Fri, 17 March 2017, 06:12:08 »
Out of curiosity have you found anything that cut's switch plastic well? I need to trim some stems to get some keycaps to fit.
Offline Geroximo
« Reply #7 on: Mon, 27 March 2017, 05:36:31 »
Sorry for late reply.
No, I don't have any experience with cutting plastic.
