Author Topic: Help with fixing a lifted pad?  (Read 2874 times)
Offline Zombii
  • Let’s All Love Lain.
« on: Sat, 18 March 2017, 20:51:24 »
Hey everyone, I'm not certain if this is the correct subforum or if 'Making Stuff Together' was a more appropriate fit, but this board is more active, so I thought I'd post here. If a mod feels like it should be moved, please feel free to do so!
While working on my LSv1 I accidentally lifted a few pads off some stubborn LED spots while swapping switches. I didn't realize this until I went back in to resolder the SIP sockets in the new switches to the board and found that a few of the pads were lifted. Does anyone have any advice on either jumping the LEDs so that they can still work, or soldering directly to the trace in order to get the LEDs working? I'd really like to try and get all my LEDs working as well as I can.
I don't have any photos at the moment, but I'll try to get some as soon as I can.
Offline Zombii
Re: Help with fixing a lifted pad?
« Reply #2 on: Sat, 18 March 2017, 21:26:47 »
Album with pictures: http://imgur.com/a/TcTXu
Apologies for the ****ty quality, all I have is my phone and the lighting is not very good
« Reply #3 on: Sat, 18 March 2017, 21:30:07 »
good god man
can either try and get solder deep into the hole or run a jump wire
i don't know enough about soldering to tell you how to do these things, but i've seen them mentioned as fixes for this problem before
Offline Zombii
« Reply #4 on: Sat, 18 March 2017, 21:32:30 »
good god man
Feels bad, the one switch on the entire board where the soldering is egregiously bad (due to the ****ty solder used by whoever put that specific switch in in the first place) and it's the one where I have a problem that requires me to post it :/
This board was the first time I've ever soldered something on my own, and other than that one switch, it actually looks pretty good besides some flux residue that I haven't cleaned up yet.
« Reply #5 on: Sat, 18 March 2017, 21:33:47 »
i mean i'd have the same reaction if i posted pics of my own soldering work
it works but it's not pretty
« Reply #6 on: Sat, 18 March 2017, 22:06:08 »
is this board traced on both sides or just 1 side.
Offline Zombii
« Reply #7 on: Sat, 18 March 2017, 22:30:02 »
I think it's traced on both sides
Offline Delirious
« Reply #8 on: Sat, 18 March 2017, 22:51:14 »
I'm looking at the front of the PCB using Photoeletric's picture from this thread, try this
Offline Zombii
« Reply #9 on: Sat, 18 March 2017, 22:56:21 »
That's what I was thinking. My worries come from whether or not it it will cause any difference in the brightness of the LEDs. I would assume it wouldn't, since in theory you'd just be fixing the 'broken' connection as long as you weren't using a ridiculously thick wire.
It's late here right now, but I'll pick up some thin gauge wire tomorrow and try that fix, I need to get some more thin solder anyway.
« Reply #10 on: Sat, 18 March 2017, 23:34:37 »
It shouldn't..
but if you got a picture of the front of the pcb Nude... that'd help determine if it'll happen.
Offline Zombii
« Reply #11 on: Wed, 22 March 2017, 23:43:28 »
Status update: It worked!
Thanks guys.
