Author Topic: The Mystery of the Vanishing Print Settings (Adobe Acrobat Reader)  (Read 6851 times)
Offline dantan
I have been having a weird problem with Adobe Acrobat Reader recently.
Their print settings have vanished. So I can't see anything except to press ctrl-P and return to print. I can't control anything else because I can't see anything.
Updating AAReader, reinstalling, restarting computer all do not change the problem.
This isn't a printer problem. My printer firmware is current, and the settings problem does not feature in any other software I use.
Offline dgneo
  • Supervillain
Re: The Mystery of the Vanishing Print Settings (Adobe Acrobat Reader)
« Reply #1 on: Thu, 23 March 2017, 11:17:35 »
Sounds like you're missing a font, do you have the 'Segoe UI' font on your PC? Should be under C:/Fonts
« Reply #2 on: Thu, 23 March 2017, 13:39:34 »
hrrrrmmmmm.....
there are millions of reader apps.. just use something else.. hahahahaa
Offline dantan
« Reply #3 on: Fri, 24 March 2017, 09:57:26 »
Amazing, I really don't have that font!
between my upgrading to Win10, then downgrading and reinstalling lots of stuff thanks to problems with the upgrade, I also cleaned house and deleted a lot of things I thought were useless or had weird names...
Offline dgneo
  • Supervillain
« Reply #4 on: Fri, 24 March 2017, 09:59:19 »
Ah that'll do it.
I'd open up a Command Prompt as Administrator, and run sfc /scannow
It should take care of the missing font, and any other system files that may be missing. Give that a shot and let me know  :thumb:
Offline dantan
« Reply #5 on: Sat, 08 April 2017, 11:31:15 »
Ah that'll do it.
As good as your suggestions were, I decided not to take a chance.
Basically you can't trust Windows software to take care of Windows properly. They might end up doing something that totally locks up my computer.
« Reply #6 on: Sat, 08 April 2017, 15:31:01 »
Ah that'll do it.
I had to disable almost every windows service on my control box, because they were causing latency spikes..
Offline dantan
« Reply #7 on: Sun, 09 April 2017, 10:52:24 »
What are latency spikes?
See, I have a windows 7 computer, 5 years old. It was on Norton antivirus from day 1, and I have consistently scanned it. It should be pretty free of trojans and worms. I defragment the drive and get rid of unused software periodically. I also don't tweak the system very much. I certainly don't lower my firewall for free softwares. Licensed windows, win office, etc.
But my system still got windows bloat or whatever you call it. It slowed down a lot. I have way more RAM than I need, but the system is still way slower than it was when new.
Any suggestions?
« Reply #8 on: Sun, 09 April 2017, 13:51:48 »
Any suggestions?
do you have an ssd ?
Offline dantan
« Reply #9 on: Sun, 09 April 2017, 15:36:24 »
No, SATA HDD, also 5 years old like the desktop itself.
« Reply #10 on: Sun, 09 April 2017, 16:35:11 »
well there's ur problem.. hahahhahha
buy a cheap ssd.. i got 750gb for $99 on black friday from newegg.
non sale price is around 4 to 5gb per dollar,  so get a good 512gb for only $100..
Check with me before you buy it..  you don't want to end up with a ****ty ssd.
Offline Photoelectric
« Reply #11 on: Sun, 09 April 2017, 16:42:30 »
Try PDF-XChange Viewer instead.  It's fast, free, and you can do stuff like add signature, comments, mark-up, etc.
Offline dantan
« Reply #12 on: Sun, 09 April 2017, 21:57:40 »
My question was about the slowing down of my computer.
Are you suggesting that it is my ageing hard disk that is causing the slowing down?
« Reply #13 on: Sun, 09 April 2017, 22:02:27 »
buy an ssds,  all your problems will be solved
