Author Topic: Where to buy keycaps to fit Rosewill Rk-9000 bottom row (PBT)  (Read 2474 times)
Offline Encabulator
« on: Mon, 27 March 2017, 19:58:20 »
I got a standard 104 ANSI layout set of PBT keycaps for my rosewill keyboard.  Everything fit on the stabilizers with a bit of sanding, but the spacebar and right side of the bottom row don't fit. If anyone knows a good place to buy oddly sized dyed PBT keycaps for it please let me know. Thanks!
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Hyde
  • White Tofu Extraordinaire
Re: Where to buy keycaps to fit Rosewill Rk-9000 bottom row (PBT)
« Reply #1 on: Mon, 27 March 2017, 21:51:21 »
Uh as far as I know RK-9000 use standard bottom row.  So 99% of the aftermarket keycaps should just fit.
Can you link me where you bought your keycap set?
Also does your RK-9000 look exactly the same as this pictures?  https://mechanicalkeyboards.com/shop/images/products/large_29_RK-9000_C.jpg
Offline carmenohio
« Reply #2 on: Sat, 01 April 2017, 20:22:50 »
I have an RK-9000 and the bottom row is definitely standard.  I've used key caps from signature plastics, tai hao, & vortex without ever having issues with compatibility.  Maybe the set you purchased is for a non-standard layout?
« Reply #3 on: Sat, 01 April 2017, 21:50:56 »
rk9k is standard, which is why i recommend it so much
