Author Topic: I can type 100+ wpm but I need to learn how to type properly  (Read 5390 times)
Offline JackieOReally
« on: Fri, 31 March 2017, 00:03:10 »
I learned to type 18 years ago and have always been a fast typist. But just today I realized that when I type I cover the right side of the keyboard almost exclusively with my right index finger.
I discovered this because I bought a Vortex Core and I'm really struggling with it, and that mostly comes from my index finger trying to do all the work. To use a 40% it seems you're better off staying on home row and not wandering (probably because of all the layers, it takes a few fingers to do things so the wandering index doesn't work).
So I'm asking for help. Where can I learn how to type properly? Is there any good resources? Which fingers are meant to hit which buttons? Has anyone else managed to retrain themselves? I did some googling but the tutorials looked a bit naff so I thought I'd report back to the mothership for advice.
I've been trying to use other fingers today but it's just a mess and I'm at the end of my tether.
Offline hoggy
  • * Ergonomics Moderator
Re: I can type 100+ wpm but I need to learn how to type properly
« Reply #1 on: Fri, 31 March 2017, 00:34:43 »
It's not going to be a pleasant experience.  You'll lost a good fraction of your typing speed for a while too. If you're not in pain, I'd suggest carrying on as you are, but since you seem pretty committed and it would be easier with multiple layers.
Try blanking the keycaps on the right side.
 Those exercises are pretty naff because of the qwerty layout.  You need to develop muscle memory, so exercises are pretty much the only way to touch type.  Sadly, I'd be surprised if any of the tutorials covered improving your typing on just one hand.
This is the perfect time to consider a new layout.  Both Dvorak and Colemak make much better use of the home row and are much more comfortable to use than qwerty once you've adapted.  If you are going to relearn, you could be learning a better layout.
Good luck!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Fri, 31 March 2017, 00:59:14 »
If you're not in pain I'd say you're totally fine. I type 'properly' and I can barely reach 80wpm on a good day lol
« Reply #4 on: Fri, 31 March 2017, 01:18:36 »
Can I ask how that would help? I wouldn't think that would encourage typing with more fingers would it ?
« Reply #5 on: Fri, 31 March 2017, 01:27:52 »
Good luck!
I did look Into that but I couldn't find any proof that layouts are any more ergonomic or efficient.
Offline cutterline
« Reply #6 on: Fri, 31 March 2017, 02:55:42 »
It's simple but hard to do, you have to forget what you've learn so far and re-learn the whole thing because you are fixing bad habit.
I'll also recommend Hoggy's method as it might be easier to just learn a new layout because you're gonna reset your muscle memory anyway.
The downside is shortcuts are mainly designed for qwerty layout.
Offline Polymer
« Reply #7 on: Fri, 31 March 2017, 03:02:54 »
I agree with using a different layout...
If you're going to have to relearn how to type, might as well do it with a much more efficient layout...
Offline Targa-TV
« Reply #8 on: Fri, 31 March 2017, 03:58:16 »
This reminds me of the time I got my index and middle fingers smashed in a door and I discovered that I could type with my ring finger and pinky. lol
So I would suggest blocking your index or limiting its movements in some way but my experience is limited to full size or tenkeyless keyboards so I don't know how effective that might be.
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline hoggy
« Reply #9 on: Fri, 31 March 2017, 12:14:24 »
Sadly, proof is hard to come by.  There seems to a weird desire amongst some to prove that qwerty isn't all that bad as if it would violate some sort of economic axiom...  throwing mud at existing studies is quite popular.
I find that Dvorak is significantly more comfortable, but that's my personal experience. Comfort is the real reason why should swop, changing for speed isn't great and hell, copy/paste and macros will beat any layout change.
Offline Macsmasher
« Reply #10 on: Fri, 31 March 2017, 12:56:17 »
Anything is going to be more comfortable than qwerty. I chose Colemak primarily because it maintains the same undo/cut/copy/paste shortcuts as qwerty.
« Reply #11 on: Fri, 31 March 2017, 13:18:01 »
I like qwerty because i'm used to it and that's what's most comfortable for me
Offline hoggy
« Reply #12 on: Fri, 31 March 2017, 14:02:20 »
Absolutely.  Switching for me was difficult and took a long time. I don't recommend it unless there's a benefit.
« Reply #13 on: Fri, 31 March 2017, 17:04:28 »
I was the same way but I typed around 60 wpm so I switched to Dvorak to learn to type properly because my bad habits were too well seated in my typing to un learn them. After learning Dvorak and correcting my typing I'm now up to 75ish wpm. Switching layouts can cause issues if you always share a computer but if you want to learn how to type properly switching layouts may be the easiest solution.
Edit: I just noticed this has already been said, also the shortcuts on Dvorak are almost as easy as Qwerty but they change from left handed to right handed.
« Last Edit: Fri, 31 March 2017, 17:06:22 by Joey Quinn »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Fri, 31 March 2017, 17:07:54 »
I tried Dvorak for about 10-30min per day for two weeks and could not get past 20wpm. Seems like it's all or nothing for layout switching. The balance was better imo
« Reply #15 on: Fri, 31 March 2017, 17:18:12 »
Yeah, for the first week I switched between Dvorak and Qwerty I was still typing maybe 10 wpm with Dvorak. When you fully commit to a new layout the first week is a struggle but after that you start to pick up speed pretty quickly, after maybe 3 weeks I was at 50+ touch typing Dvorak with pretty low errors. Once you have the layout down a few typing tests a day can make a huge difference.
The balance of Dvorak is great, because it minimizes finger movement it's really comfy once you get the hang of it.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #16 on: Fri, 31 March 2017, 19:41:11 »
Please tell me you hit the spacebar with your right index finger too.
« Reply #17 on: Fri, 31 March 2017, 20:42:30 »
Nope. I'm not a complete sicko.
« Reply #18 on: Fri, 31 March 2017, 20:44:41 »
this is what puts me off. I'm a programmer and I can barely get my work done on time as it is, let alone typing 20wpm on Dvorak.
Offline Targa-TV
« Reply #19 on: Sat, 01 April 2017, 02:14:38 »
I tried Dvorak for a couple hours every evening for a few days when work was slow but I got too frustrated looking at the legends.
I agree that it is very comfortable to have all the vowels on home row and I too was picking up speed after I memorized some of the combinations but I kept touch typing every 10 letters.
Plus going back to Italian layout to have the accents was a nightmare..
« Reply #20 on: Sat, 01 April 2017, 02:57:39 »
Only a Maximum-Sicko would say that..
/Reported !!
Offline chyros
  • a.k.a. Thomas
« Reply #21 on: Sat, 01 April 2017, 05:21:28 »
Stille alone >.< .
« Reply #22 on: Sun, 02 April 2017, 04:32:48 »
If you fully commit to Dvorak you should be at 50 wpm within 2-3 weeks and from there 70-80 is pretty easy to work towards.
How fast do you type with Qwerty?
Offline davkol
  •  Post Editing Timeout
« Reply #23 on: Sun, 02 April 2017, 07:55:07 »
You can use one layout through the day and practice the other one at night. There's absolutely no problem here. It will take several weeks of focused daily practice (something like 2×30 minutes), though.
There are two main pitfalls: Most people's practice methods are completely abysmal (been there, done that), hence the high failure rate. The other problem is that you'll have to relearn keyboard shortcuts, but there are workarounds (Dvorak-QWERTY layout in MacOS and similar open-source reimplementations; DreymaR's Extend layer or function layers in general).
Offline hoggy
« Reply #24 on: Mon, 03 April 2017, 03:26:35 »
Another pitfall you might face is that entering passwords suddenly becomes very difficult.
Sent from my Nexus 7 using Tapatalk
