Author Topic: Nature White or equivalent  (Read 4186 times)
Offline atomicus
« on: Wed, 05 April 2017, 18:39:32 »
Is it possible to buy Cherry MX Nature White switches anywhere? Or failing that, is there an equivalent. I see Gateron have the Black and Yellow, both rated at 50g and linear, so either of those would appear to be the closest match?
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Nature White or equivalent
« Reply #1 on: Wed, 05 April 2017, 19:59:32 »
I believe the scratchy linear clear i got with my Vortex 22key tester from Massdrop is in fact one of the new "nature white" switches. It feels to me like the 199?-2016 Black switch to me. If i had more than one, i'd send it to you but this ones already installed in my tester.
-Dana
Offline Harms
« Reply #2 on: Wed, 05 April 2017, 20:12:12 »
Gateron Yellow is the Cherry Nature equivalent. Gateron Yellow actuates around 50g and bottoms out at 65g. Nature white also bottoms out at 65g. Therefore, Gateron Yellow is your best bet :).
Gaterons are known to be smoother anyways, so it is a win-win situation.
« Reply #3 on: Wed, 05 April 2017, 20:28:55 »
what are nature whites..
//outta the loop
Offline atomicus
« Reply #4 on: Wed, 05 April 2017, 20:35:52 »
//outta the loop
They are basically the middle ground between Cherry Reds and Blacks.
Offline atomicus
« Reply #5 on: Wed, 05 April 2017, 20:44:48 »
What's the bottom out force of Gateron Black then, as both it and the Yellow have 50g actuation. I read somewhere the Gat Blacks feel a bit heavier than the Yellows, so I'm guessing that bottom out figure is higher?
Offline atomicus
« Reply #6 on: Wed, 05 April 2017, 20:45:09 »
double post
Offline Harms
« Reply #7 on: Thu, 06 April 2017, 02:59:51 »
The bottom out force Gateron Black is 70g. So, yes it is higher by a tad.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #8 on: Thu, 06 April 2017, 08:21:37 »
According to something I read (can't exactly remember where), the 'MX Pink' switch that was used in some Filcos is the non-RGB equivalent to Nature Whites. If I remember correctly, you can buy those individually.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
« Reply #9 on: Thu, 06 April 2017, 08:38:00 »
No, MX Pink would be the alternate name for Silent Reds which are red switches with built in dampeners.
Offline _haru
« Reply #10 on: Thu, 06 April 2017, 08:49:26 »
I thought the same. I'll see if I can try and find that incorrect source...
