Author Topic: What are the best games for Linux?  (Read 4918 times)
Offline dante
« on: Mon, 17 April 2017, 09:30:31 »
And by best I mean the following:
1. Super easy to install.  (ie: Not having to burn through a weekend going through configuration files/etc. to get it to work.)
2. No compromises whatsoever over a Windows/Mac port.  In fact in some cases it may be superior (frame rate etc...)
3. Do not have to search for a special/uncommon graphics card/chipset to make it work.
Offline iLLucionist
  • Topre is Love.
Re: What are the best games for Linux?
« Reply #1 on: Mon, 17 April 2017, 16:01:14 »
I'm obsessed with tetris curently. Anybody got advice for a GOOD tetris client? I tried a couple, but they all sucked.
I've been watching classic tetris world championship lately (CTWC).
Offline ddot
  • Master of Suspense
« Reply #2 on: Mon, 17 April 2017, 16:35:00 »
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Tue, 18 April 2017, 10:56:50 »
Battle for Wesnoth, Nethack,… It's probably in the repos. There's quite a lot of stuff in the repos, usually.
Even getting majority of proprietary games ported/released after ca. 2007 to run is simple, if you know how library linking works (i.e., know which libraries distributed with the game you should remove).
Offline lzrdwzrd
« Reply #4 on: Tue, 18 April 2017, 11:38:33 »
Steam on linux works really good these days and they have a decent selection of games.
Doesn't get much easier to install.
I would recommend "Pillars of Eternity" if you are into RPGs or SOMA if you like sci-fi horror ( like bioshock with less shooting )
SteelSeriesLeopoldZowie
6gV2 (mx black)FC660C/EGFK1
« Reply #5 on: Tue, 18 April 2017, 15:58:42 »
Tp4 were xcited for tetris at one point..
Then I saw them weeabooland xperts play tetris grandmasters..
Then I decided it will never happen for me.
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Tue, 18 April 2017, 16:50:22 »
I know what you mean. Again, like with FPS. My solving abilities suck nowadays. I don't know how I pulled it off when I was 9.
